RRF Update to 3.3 just killed my FW
2.0k
    The changes between 3.0 and up are pretty minor.
    The change between RRF2 and RRF3 are more substantial. What firmware were you running before?
    You can get an example config updated for 3.3 from the config tool to compare against. https://configtool.reprapfirmware.org/Start
      Andy Cohen
      @phaedrux I started with a late v2 and I'm lost with the new approach with the M950. Is there a web app I can use to gen the gcode?
      undefined 1 Reply Last reply 1 Feb 2022, 00:31 Reply Quote 0
        Phaedrux Moderator @Andy Cohen
        @andy-cohen said in RRF Update to 3.3 just killed my FW:
        Yes. I linked it in my last post.
        Here's what I normally tell people when they want to update from RRF2
        If you still have access to DWC. Upload these 3 zip files, one at a time in the system tab. Don't extract them first. Reboot after each. Use M115 in the gcode console to verify the firmware has been applied.
        https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
        https://github.com/Duet3D/RepRapFirmware/releases/download/3.3/Duet2and3Firmware-3.3.zip
        That will get your firmware and DWC up to date.
        You can see the change logs here:
        https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x
        For your config, might be a good idea to run through the configurator tool and generate a fresh set for RRF3.
        Backup your existing config files in the sys folder in case you want to switch back to RRF2. It’s easy to switch back and forth, just upload the zip file for the version you want and then upload your config files.
        These documents will come in handy during the conversion.
        https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview
        https://duet3d.dozuki.com/Wiki/Gcode
          Andy Cohen
          Thanks for the help.
          I was able to get it to kinda work. It still does not see my extruder heater, only the bed heater. This is the heater gcode in the config file I generated:
          undefined undefined 2 Replies Last reply 1 Feb 2022, 00:49 Reply Quote 0
            Andy Cohen @Andy Cohen
            @andy-cohen Here's the tool def:
            undefined 1 Reply Last reply 1 Feb 2022, 01:12 Reply Quote 0
              What does not see it?
              Can you send M122 and M98 P"config.g" in the gcode console or USB terminal and share the results?
              undefined 1 Reply Last reply 1 Feb 2022, 01:30 Reply Quote 0
                @andy-cohen Yeah... I see it... The web app did not make the P1 tool.
                  Andy Cohen @Phaedrux
                  @phaedrux OK... heaters and fans seem OK.
                  Now the motors. They won't home. Comparing with my original config, I see nothing that can be incorrect. Any ideas?
                  M92 X88.57 Y88.57 Z400.00 E125.459271 ; set steps per mm
                  M201 X1000.00 Y1000.00 Z20.00 E250.00 ; set accelerations (mm/s^2)
                  M906 X800 Y800 Z400 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
                  M84 S30 ; Set idle timeout
                  M208 X300 Y195 Z210 S0 ; set axis maxima
                  M574 X2 S0 P"xstop" ; configure switch-type (e.g. microswitch) endstop for high end on X via pin xstop
                  M574 Y2 S0 P"ystop" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin ystop
                  M574 Z1 S0 P"zstop" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin zstop
                  undefined 1 Reply Last reply 1 Feb 2022, 01:35 Reply Quote 0
                    S0 is incorrect.
                    If the signal needs to be inverted, use S1 and add a ! to the front of the pin name.
                    M574 X2 S1 P"!xstop"
                    undefined 1 Reply Last reply 1 Feb 2022, 01:48 Reply Quote 0
                      @phaedrux It moves but the limit switches are ignored. When told to Home X it moves it on an angle. It's a coreXY machine so I got something wrong..
                      Why oh WHY was soooo much changed?!?
                        You'll have to share your config and homing files at this point for any meaningful feedback.
                        Are you sure it's set to corexy kinematic?
                        undefined 1 Reply Last reply 1 Feb 2022, 02:17 Reply Quote 0
                          @phaedrux Heck... at this point I'm not sure of anything!
                          I also suspect the wifiserver FW needs to be updated as well as the ManelDue.
                          ; Configuration file for Duet WiFi (firmware version 3.3)
                          ; generated by RepRapFirmware Configuration Tool v3.3.10 on Mon Jan 31 2022 16:37:49 GMT-0800 (PST)
                          M550 P"My Printer" ; set printer name
                          M550 P"CloneDuet" ; Set machine name
                          M552 S1 ; Enable network
                          M586 P0 S1 ; Enable HTTP
                          M586 P1 S0 ; Disable FTP
                          M586 P2 S0 ; Disable Telnet
                          M552 S1 ; enable network
                          M586 P0 S1 ; enable HTTP
                          M586 P1 S0 ; disable FTP
                          M586 P2 S0 ; disable Telnet
                          M574 X2 S1 P"!xstop" ; configure switch-type (e.g. microswitch) endstop for high end on X via pin xstop
                          M574 Y2 S1 P"!ystop" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin ystop
                          M574 Z1 S1 P"!zstop" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin zstop
                          M558 P1 C"zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
                          M557 X10:300 Y-16.0:195 S20 ; define mesh grid
                          M563 P1 ; Define tool 1
                          G10 P1 X35 Y0 Z0 ; Set tool 1 axis offsets
                          G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C
                          undefined 1 Reply Last reply 2 Feb 2022, 01:16 Reply Quote 0
                            Andy Cohen
                            Yeah... you were correct.
                            There's no
                            "M669 K1 ; switch to CoreXY mode"
                            I added it and now it seems to work.
                              Can you send m122 and share the results?
                              undefined 1 Reply Last reply 1 Feb 2022, 03:28 Reply Quote 0
                                @phaedrux Attached.
                                In the meantime the PanelDue is a 5.0i but it does not seem to want to update via the Duet. It's 3 years old. Think I'll need to remove it from it's containment and hit a resent button?
                                M122
                                RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later
                                Board ID: 08DGM-917DA-G4MS8-6JKD0-3S06N-K9TVB
                                Used output buffers: 3 of 24 (12 max)
                                Static ram: 23876
                                Dynamic ram: 75052 of which 0 recycled
                                Never used RAM 15488, free system stack 184 words
                                Tasks: NETWORK(ready,14.4%,244) HEAT(delaying,0.0%,326) Move(notifyWait,0.1%,364) MAIN(running,85.2%,417) IDLE(ready,0.4%,29), total 100.0%
                                Owned mutexes: WiFi(NETWORK)
                                Last reset 00:04:26 ago, cause: power up
                                Last software reset at 2022-01-31 19:16, reason: StuckInSpinLoop, GCodes spinning, available RAM 12280, slot 0
                                Software reset code 0x4083 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f80f BFAR 0xe000ed38 SP 0x2000254c Task MAIN Freestk 900 ok
                                Stack: 004534c9 00455180 810f0000 00000000 3f000000 369dc3a0 3edbc06f 3331bb4c 40000000 b5ddd98d 388ab355 bb360b61 3e2aaaab 3f800000 00000000 00000000 4354c416 00000000 00000000 60000010 004534c1 200080c8 00408da7 00000000 200182c8 20004c8c 0041872b
                                Error status: 0x00
                                Step timer max interval 0
                                MCU temperature: min 37.4, current 39.2, max 39.6
                                Supply voltage: min 23.9, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
                                Driver 0: position 0, standstill, SG min/max not available
                                Driver 1: position 0, standstill, SG min/max not available
                                Driver 2: position 0, standstill, SG min/max not available
                                Driver 3: position 0, standstill, SG min/max not available
                                Driver 4: position 0, standstill, SG min/max not available
                                Driver 5: position 0
                                Driver 6: position 0
                                Driver 7: position 0
                                Driver 8: position 0
                                Driver 9: position 0
                                Driver 10: position 0
                                Driver 11: position 0
                                Date/time: 2022-01-31 19:26:17
                                Slowest loop: 7.69ms; fastest: 0.17ms
                                === Storage ===
                                Free file entries: 10
                                SD card longest read time 1.1ms, write time 0.0ms, max retries 0
                                === MainDDARing ===
                                === AuxDDARing ===
                                Segments left: 0
                                Movement lock held by null
                                HTTP is idle in state(s) 0
                                Telnet is idle in state(s) 0
                                File is idle in state(s) 0
                                USB is idle in state(s) 0
                                Aux is idle in state(s) 0
                                Trigger is idle in state(s) 0
                                Queue is idle in state(s) 0
                                LCD is idle in state(s) 0
                                Daemon is idle in state(s) 0
                                Code queue is empty.
                                === Network ===
                                Slowest loop: 182.04ms; fastest: 0.00ms
                                HTTP sessions: 1 of 8
                                • WiFi -
                                  Network state is active
                                  WiFi firmware version 1.26
                                  WiFi MAC address bc:dd:c2:89:a2:9b
                                  WiFi Vcc 3.38, reset reason Turned on by main processor
                                  WiFi flash size 4194304, free heap 24160
                                  WiFi IP address 192.168.1.92
                                  WiFi signal strength -37dBm, mode 802.11n, reconnections 0, sleep mode modem
                                  Clock register 00002002
                                undefined 1 Reply Last reply 1 Feb 2022, 05:40 Reply Quote 0
                                  I think you'll need to update it's firmware via usb as well so that it can communicate with RRF3 as well. I think the latest firmware is 3.4 for the paneldue. I think once you have it up to date with the firmware you'll actually be able to update it via DWC in the future.
                                  https://duet3d.dozuki.com/Wiki/PanelDue_Firmware_update#Section_Firmware_update_via_USB
                                  It looks like your main firmware and wifi firmware are up to date now. Can you confirm that DWC is also at 3.3?
                                  undefined 1 Reply Last reply 1 Feb 2022, 05:42 Reply Quote 0
                                    @phaedrux Right. I'm already there.
                                    Bossa does not work in the latest MacOS.
                                    I'm forced to find a ... PC.
                                    BTW where do I find the DWC version?
                                    droftartsundefined 1 Reply Last reply 1 Feb 2022, 09:38 Reply Quote 0
                                      droftarts administrators @Andy Cohen
                                      @andy-cohen to get Bossa working on macOS, see this thread: https://forum.duet3d.com/topic/11445/
                                      Find DWC version in DWC on system page, general tab https://duet3d.dozuki.com/Wiki/Duet_Web_Control_v2_and_v3_(DWC)_Manual#Section_General_tab
                                      undefined 1 Reply Last reply 1 Feb 2022, 17:21 Reply Quote 0
                                        Andy Cohen @droftarts
                                        @droftarts said in RRF Update to 3.3 just killed my FW:
                                        DWC is at 3.3.
                                        Found a PC and updated the PanelDue. The update worked but it does not see the tools nor does it operate anything. My bet is I have to add a line in the config... right?
                                        undefined 1 Reply Last reply 1 Feb 2022, 17:24 Reply Quote 0
                                          @andy-cohen Yup!
                                          All seems to be working fine for now.
                                          I'm really not looking forward to updating my Toolchanger!
                                          undefined 2 Replies Last reply 1 Feb 2022, 19:16 Reply Quote 0
                                          16 out of 46
