    RRF Update to 3.3 just killed my FW
    2.1k
      It's likely that that wifi server didn't get updated correctly.
      Try sending M997 S1 on the panel.
      Otherwise connect via USB terminal and see what you can see there with M122.
      Also, did you update your config.g to enable the paneldue itself? That must be done in RRF3.
      M575 P1 B57600 S1
        droftarts administrators @Andy Cohen
        @andy-cohen if the firmware did update to 3.3 (connect via USB, send M115) send
        M997 S1 P”0:/sys/DuetWiFiServer.bin”
        Otherwise it will look in the /firmware folder, which doesn’t exist, and you’ll get an error message. 3.3 and later keeps firmware updates out of the sys folder.
        • Andy Cohenundefined
          Andy Cohen
          Unfortunately... nothing seems to work at all. It acts like it cannot see the SD card and the extruder fan goes on. The update looks like it killed my whole setup!
          Can't I simply take the SD card out and make changes?
            There are config changes required between 3.0 and above. Can you post your current config.g?
            You can remove the SD card from the Duet and check the config.g on your PC.
            A firmware update can't kill anything. We just need you to connect the board via USB terminal to see what is actually going on.
            Andy Cohenundefined 1 Reply Last reply Reply Quote 0
              Andy Cohen @Phaedrux
              @phaedrux I was able top get the wifiserver running thanks to your post.
              It looks like quite a bit of the config is no longer working. Great.
                The changes between 3.0 and up are pretty minor.
                The change between RRF2 and RRF3 are more substantial. What firmware were you running before?
                You can get an example config updated for 3.3 from the config tool to compare against. https://configtool.reprapfirmware.org/Start
                  Andy Cohen
                  @phaedrux I started with a late v2 and I'm lost with the new approach with the M950. Is there a web app I can use to gen the gcode?
                    Phaedrux Moderator @Andy Cohen
                    @andy-cohen said in RRF Update to 3.3 just killed my FW:
                    Yes. I linked it in my last post.
                    Here's what I normally tell people when they want to update from RRF2
                    If you still have access to DWC. Upload these 3 zip files, one at a time in the system tab. Don't extract them first. Reboot after each. Use M115 in the gcode console to verify the firmware has been applied.
                    https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
                    https://github.com/Duet3D/RepRapFirmware/releases/download/3.3/Duet2and3Firmware-3.3.zip
                    That will get your firmware and DWC up to date.
                    You can see the change logs here:
                    https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x
                    For your config, might be a good idea to run through the configurator tool and generate a fresh set for RRF3.
                    Backup your existing config files in the sys folder in case you want to switch back to RRF2. It’s easy to switch back and forth, just upload the zip file for the version you want and then upload your config files.
                    These documents will come in handy during the conversion.
                    https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview
                    https://duet3d.dozuki.com/Wiki/Gcode
                      Andy Cohen
                      Thanks for the help.
                      I was able to get it to kinda work. It still does not see my extruder heater, only the bed heater. This is the heater gcode in the config file I generated:
                      Andy Cohenundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                        Andy Cohen @Andy Cohen
                        @andy-cohen Here's the tool def:
                          What does not see it?
                          Can you send M122 and M98 P"config.g" in the gcode console or USB terminal and share the results?
                            @andy-cohen Yeah... I see it... The web app did not make the P1 tool.
                              @phaedrux OK... heaters and fans seem OK.
                              Now the motors. They won't home. Comparing with my original config, I see nothing that can be incorrect. Any ideas?
                              M92 X88.57 Y88.57 Z400.00 E125.459271 ; set steps per mm
                              M201 X1000.00 Y1000.00 Z20.00 E250.00 ; set accelerations (mm/s^2)
                              M906 X800 Y800 Z400 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
                              M84 S30 ; Set idle timeout
                              M208 X300 Y195 Z210 S0 ; set axis maxima
                              M574 X2 S0 P"xstop" ; configure switch-type (e.g. microswitch) endstop for high end on X via pin xstop
                              M574 Y2 S0 P"ystop" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin ystop
                              M574 Z1 S0 P"zstop" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin zstop
                                S0 is incorrect.
                                If the signal needs to be inverted, use S1 and add a ! to the front of the pin name.
                                M574 X2 S1 P"!xstop"
                                  @phaedrux It moves but the limit switches are ignored. When told to Home X it moves it on an angle. It's a coreXY machine so I got something wrong..
                                  Why oh WHY was soooo much changed?!?
                                    You'll have to share your config and homing files at this point for any meaningful feedback.
                                    Are you sure it's set to corexy kinematic?
                                      @phaedrux Heck... at this point I'm not sure of anything!
                                      I also suspect the wifiserver FW needs to be updated as well as the ManelDue.
                                      ; Configuration file for Duet WiFi (firmware version 3.3)
                                      ; generated by RepRapFirmware Configuration Tool v3.3.10 on Mon Jan 31 2022 16:37:49 GMT-0800 (PST)
                                      M550 P"My Printer" ; set printer name
                                      M550 P"CloneDuet" ; Set machine name
                                      M552 S1 ; Enable network
                                      M586 P0 S1 ; Enable HTTP
                                      M586 P1 S0 ; Disable FTP
                                      M586 P2 S0 ; Disable Telnet
                                      M552 S1 ; enable network
                                      M586 P0 S1 ; enable HTTP
                                      M586 P1 S0 ; disable FTP
                                      M586 P2 S0 ; disable Telnet
                                      M574 X2 S1 P"!xstop" ; configure switch-type (e.g. microswitch) endstop for high end on X via pin xstop
                                      M574 Y2 S1 P"!ystop" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin ystop
                                      M574 Z1 S1 P"!zstop" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin zstop
                                      M558 P1 C"zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
                                      M557 X10:300 Y-16.0:195 S20 ; define mesh grid
                                      M563 P1 ; Define tool 1
                                      G10 P1 X35 Y0 Z0 ; Set tool 1 axis offsets
                                      G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C
                                        Andy Cohen
                                        Yeah... you were correct.
                                        There's no
                                        "M669 K1 ; switch to CoreXY mode"
                                        I added it and now it seems to work.
                                          Can you send m122 and share the results?
                                            @phaedrux Attached.
                                            In the meantime the PanelDue is a 5.0i but it does not seem to want to update via the Duet. It's 3 years old. Think I'll need to remove it from it's containment and hit a resent button?
                                            M122
                                            RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later
                                            Board ID: 08DGM-917DA-G4MS8-6JKD0-3S06N-K9TVB
                                            Used output buffers: 3 of 24 (12 max)
                                            Static ram: 23876
                                            Dynamic ram: 75052 of which 0 recycled
                                            Never used RAM 15488, free system stack 184 words
                                            Tasks: NETWORK(ready,14.4%,244) HEAT(delaying,0.0%,326) Move(notifyWait,0.1%,364) MAIN(running,85.2%,417) IDLE(ready,0.4%,29), total 100.0%
                                            Owned mutexes: WiFi(NETWORK)
                                            Last reset 00:04:26 ago, cause: power up
                                            Last software reset at 2022-01-31 19:16, reason: StuckInSpinLoop, GCodes spinning, available RAM 12280, slot 0
                                            Software reset code 0x4083 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f80f BFAR 0xe000ed38 SP 0x2000254c Task MAIN Freestk 900 ok
                                            Stack: 004534c9 00455180 810f0000 00000000 3f000000 369dc3a0 3edbc06f 3331bb4c 40000000 b5ddd98d 388ab355 bb360b61 3e2aaaab 3f800000 00000000 00000000 4354c416 00000000 00000000 60000010 004534c1 200080c8 00408da7 00000000 200182c8 20004c8c 0041872b
                                            Error status: 0x00
                                            Step timer max interval 0
                                            MCU temperature: min 37.4, current 39.2, max 39.6
                                            Supply voltage: min 23.9, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
                                            Driver 0: position 0, standstill, SG min/max not available
                                            Driver 1: position 0, standstill, SG min/max not available
                                            Driver 2: position 0, standstill, SG min/max not available
                                            Driver 3: position 0, standstill, SG min/max not available
                                            Driver 4: position 0, standstill, SG min/max not available
                                            Driver 5: position 0
                                            Driver 6: position 0
                                            Driver 7: position 0
                                            Driver 8: position 0
                                            Driver 9: position 0
                                            Driver 10: position 0
                                            Driver 11: position 0
                                            Date/time: 2022-01-31 19:26:17
                                            Slowest loop: 7.69ms; fastest: 0.17ms
                                            === Storage ===
                                            Free file entries: 10
                                            SD card longest read time 1.1ms, write time 0.0ms, max retries 0
                                            === MainDDARing ===
                                            === AuxDDARing ===
                                            Segments left: 0
                                            Movement lock held by null
                                            HTTP is idle in state(s) 0
                                            Telnet is idle in state(s) 0
                                            File is idle in state(s) 0
                                            USB is idle in state(s) 0
                                            Aux is idle in state(s) 0
                                            Trigger is idle in state(s) 0
                                            Queue is idle in state(s) 0
                                            LCD is idle in state(s) 0
                                            Daemon is idle in state(s) 0
                                            Code queue is empty.
                                            === Network ===
                                            Slowest loop: 182.04ms; fastest: 0.00ms
                                            HTTP sessions: 1 of 8
                                            • WiFi -
                                              Network state is active
                                              WiFi firmware version 1.26
                                              WiFi MAC address bc:dd:c2:89:a2:9b
                                              WiFi Vcc 3.38, reset reason Turned on by main processor
                                              WiFi flash size 4194304, free heap 24160
                                              WiFi IP address 192.168.1.92
                                              WiFi signal strength -37dBm, mode 802.11n, reconnections 0, sleep mode modem
                                              Clock register 00002002
