    Replaced old with new duet2 wifi, cant get nozzle heater working
    502
    • brianundefined
      brian @alankilian
      @alankilian ok here's the complete config.g;
      ; Configuration file for Duet WiFi (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.10 on Wed Feb 02 2022 11:48:28 GMT-0800 (Pacific Standard Time)
      M550 P"Brian's Build 3" ; set printer name
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M350 X32 Y32 Z32 E32 I0 ; configure microstepping without interpolation
      M92 X320.00 Y320.00 Z2500.00 E420.00 ; set steps per mm
      M906 X800 Y800 Z1600 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X430 Y410 Z650 S0 ; set axis maxima
      M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
      M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
      M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
      a
      M563 P0 S"Hot End" D0 H1 F0 ; define tool 0
      • alankilianundefined
        alankilian @brian
        @brian It looks like you are currently missing all your heater definitions.
        Maybe just a cut-n-paste error?
        Also, click on the </> button and paste your config.g in there and it will look
        like this!
        brianundefined 1 Reply Last reply Reply Quote 0
        • brianundefined
          brian @alankilian
          @alankilian sorry, here's the M122
          m122
          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later
          Board ID: 0JD0M-9P6B2-NJ4S8-6JKF6-3S86R-1A7GL
          Used output buffers: 3 of 24 (12 max)
          Static ram: 23876
          Dynamic ram: 74956 of which 176 recycled
          Never used RAM 15408, free system stack 184 words
          Tasks: NETWORK(ready,14.0%,229) HEAT(delaying,0.0%,330) Move(notifyWait,0.1%,364) MAIN(running,85.9%,383) IDLE(ready,0.0%,29), total 100.0%
          Owned mutexes: WiFi(NETWORK)
          Last reset 00:03:12 ago, cause: power up
          Last software reset at 2022-02-02 11:23, reason: User, GCodes spinning, available RAM 12464, slot 2
          Error status: 0x08
          Aux0 errors 0,0,0
          Step timer max interval 0
          MCU temperature: min 28.9, current 30.4, max 30.7
          Supply voltage: min 11.2, current 11.5, max 11.5, under voltage events: 0, over voltage events: 0, power good: yes
          Driver 0: position 0, standstill, SG min/max not available
          Driver 1: position 0, standstill, SG min/max not available
          Driver 2: position 0, standstill, SG min/max not available
          Driver 3: position 0, standstill, SG min/max not available
          Driver 4: position 0, standstill, SG min/max not available
          Driver 5: position 0
          Driver 6: position 0
          Driver 7: position 0
          Driver 8: position 0
          Driver 9: position 0
          Driver 10: position 0
          Driver 11: position 0
          Date/time: 2022-02-02 12:09:14
          Slowest loop: 4.30ms; fastest: 0.17ms
          === Storage ===
          Free file entries: 10
          SD card longest read time 3.2ms, write time 0.0ms, max retries 0
          === MainDDARing ===
          === AuxDDARing ===
          Segments left: 0
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          Daemon is idle in state(s) 0
          Code queue is empty.
          === Network ===
          Slowest loop: 200.14ms; fastest: 0.09ms
          HTTP sessions: 1 of 8
          • WiFi -
            Network state is active
            Failed messages: pending 0, notready 0, noresp 1
            WiFi firmware version 1.23
            WiFi MAC address e0:98:06:22:8f:44
            WiFi Vcc 3.43, reset reason Turned on by main processor
            WiFi flash size 4194304, free heap 22920
            WiFi IP address 192.168.1.67
            WiFi signal strength -37dBm, mode none, reconnections 0, sleep mode modem
            Clock register ffffffff
          • brianundefined
            brian @brian
            @brian and the config.g again
            M308 S1 P"e0temp" Y"thermistor" T100000 B4725 ; configure sensor 1 as thermistor on pin e0temp
            • brianundefined
              brian @brian
              @brian 2/2/2022, 12:14:04 PM M98 P"config.g"
              HTTP is enabled on port 80
              FTP is disabled
              TELNET is disabled
              • brianundefined
                brian @brian
                @brian sorry , i dont follow this " click on the </> button and paste your config.g in there"
                deckingmanundefined alankilianundefined 2 Replies Last reply Reply Quote 0
                  deckingman @brian
                  @brian I think you need to PID tune the heater. You have disabled bang bang mode but there are no PID parameters in your M307.
                  Edit. Unless you are using config-overide and have missed out the command to read those stored values (I'm using my phone but I think it's M501 that you need in config.g to read config-overide.g).
                    alankilian @brian
                    @brian
                    See at the top of the posting entry window where there are a bunch of symbols like:
                    Click the </> button and you'll get something in the posting entry window.
                    code_text
                    Then if you replace the code_text with your config.g it will be formatted nicely.
                    Here's my config.g
                    ; generated by RepRapFirmware Configuration Tool v3.2.3 on Tue Mar 09 2021 13:21:24 GMT-0500 (Eastern Standard Time)
                    G90                                                     ; send absolute coordinates...
                    M83                                                     ; ...but relative extruder moves
                    M550 P"alan"                                            ; set printer name
                    M665 R132.5 L291.06 B132.5 H400                         ; Set delta radius, diagonal rod length, printable radius and homed height
                    M666 X0 Y0 Z0                                           ; put your endstop adjustments here, or let auto calibration find them
                    M552 P0.0.0.0 S1                                        ; enable network and acquire dynamic address via DHCP
                    ; Testing external driver
                    ;M569 P5 S1 T4:4:4:4                                     ; physical drive 5 goes forwards
                    ;M584 X0 Y1 Z2 E3 U5                                     ; set drive mapping
                    ;M350 X16 Y16 Z16 E16 U16 I1                             ; configure microstepping with interpolation
                    ;M92 X100.00 Y100.00 Z100.00 U100.00 E91.00              ; set steps per mm
                    ;M566 X1200.00 Y1200.00 Z1200.00 U1200 E1200.00          ; set maximum instantaneous speed changes (mm/min)
                    ;M203 X18000.00 Y18000.00 Z18000.00 U18000E1200.00       ; set maximum speeds (mm/min)
                    ;M201 X1000.00 Y1000.00 Z1000.00 U1000E1000.00           ; set accelerations (mm/s^2)
                    ;M906 X1000 Y1000 Z1000 E800 U1000I30                    ; set motor currents (mA) and motor idle factor in per cent
                    M584 X0 Y1 Z2 E3                                        ; set drive mapping
                    M350 X16 Y16 Z16 E16 I1                                 ; configure microstepping with interpolation
                    M92 X100.00 Y100.00 Z100.00 E91.00                      ; set steps per mm
                    M566 X1200.00 Y1200.00 Z1200.00 E1200.00                ; set maximum instantaneous speed changes (mm/min)
                    M203 X18000.00 Y18000.00 Z18000.00 E1200.00             ; set maximum speeds (mm/min)
                    M201 X1000.00 Y1000.00 Z1000.00 E1000.00                ; set accelerations (mm/s^2)
                    M906 X1000 Y1000 Z1000 E800 I30                         ; set motor currents (mA) and motor idle factor in per cent
                    M208 Z0 S1                                              ; set minimum Z
                    M574 X2 S1 P"xstop"                                     ; configure active-high endstop for high end on X via pin xstop
                    M574 Y2 S1 P"ystop"                                     ; configure active-high endstop for high end on Y via pin ystop
                    M574 Z2 S1 P"zstop"                                     ; configure active-high endstop for high end on Z via pin zstop
                    M558 P1 C"zprobe.in" H10 F3000 T6000                    ; set Z probe type to unmodulated and the dive height + speeds
                    G31 P500 X0 Y0 Z-0.1                                    ; set Z probe trigger value, offset and trigger height
                    M557 R132 S40                                           ; define mesh grid
                    M308 S0 P"bedtemp" Y"thermistor" T100000 B4388 C7.06e-8 ; configure sensor 0 as thermistor on pin bedtemp
                    M140 H0                                                 ; map heated bed to heater 0
                    M143 H0 S120                                            ; set temperature limit for heater 0 to 120C
                    M308 S1 P"e0temp" Y"thermistor" T100000 B4385           ; configure sensor 1 as thermistor on pin e0temp
                    M950 H1 C"e0heat" T1                                    ; create nozzle heater output on e0heat and map it to sensor 1
                    M307 H1 B0 S1.00                                        ; disable bang-bang mode for heater  and set PWM limit
                    M950 F0 C"fan0" Q500                                    ; create fan 0 on pin fan0 and set its frequency
                    M106 P1 S0.7 H1 T45                                     ; set fan 1 value. Thermostatic control is turned on
                    M563 P0 D0 H1 F0                                        ; define tool 0
                    G10 P0 X0 Y0 Z0                                         ; set tool 0 axis offsets
                    G10 P0 R0 S0                                            ; set initial tool 0 active and standby temperatures to 0C
                    ; Custom settings
                    M501                                                    ; Load config-overrides.g
                    ;T0                                                      ; Select tool zero
                    M912 P0 S3.5                                            ; MCU temperature calibration
                    M591 D0 P3 C"e0_stop" S1                                ; Configure filament monitor
                    After I boot, I can see the heaters like this:
                    If I click on Tool 0 and then enter a temperature, it starts to heat up like this:
                    What happens when you do that?
                    Phaedruxundefined brianundefined 2 Replies Last reply Reply Quote 0
                      Phaedrux Moderator @alankilian
                      Are you selecting the tool first before trying to heat it?
                      Add T0 to the end of your config.g to select the tool automatically at startup.
                      • brianundefined
                        brian
                        @phaedrux No i was not selecting tool first. But now it is heating up when i send a print. However, now its not homing z properly. Have added the T0 at end, no result as yet.
                        • brianundefined
                          brian @brian
                          @brian ok i see that i have to click the tool to make it active, who wouldnt thunk it?
                          • brianundefined
                            brian @alankilian
                            @alankilian said in Replaced old with new duet2 wifi, cant get nozzle heater working:
                            config.g
                            config.g   Thanks, found it.
                            • brianundefined
                              brian @brian
                              @brian So this is now working.
                              Config.g
                              ; generated by RepRapFirmware Configuration Tool v3.3.10 on Wed Feb 02 2022 14:20:11 GMT-0800 (Pacific Standard Time)
                              M92 X320.00 Y320.00 Z2500.00 E1050.00           ; set steps per mm
                              M208 X0 Y0 Z0 S1                               ; set axis minima
                              M574 Z2 S2                                     ; configure Z-probe endstop for high end on Z
                              M558 P1 C"zprobe.in+!pson" H5 F120 T6000       ; set Z probe type to unmodulated and the dive height + speeds
                              G31 P500 X0 Y0 Z0.5                            ; set Z probe trigger value, offset and trigger height
                              ;T0
                              • brianundefined
                                brian @brian
                                @brian thanks for everyone's help
