    Anyone tested ironing with transparent filament?
    1.4k
    • fotomasundefined
      fotomas @Phaedrux
      @phaedrux Good idea! Maybe not Witherspoon a coarse powder coated PEI but with glass bed maybe...
      This needs to be tested.
      fotomasundefined 1 Reply Last reply Reply Quote 0
      • fotomasundefined
        fotomas @fotomas
        @fotomas
        Did a test, first layer transparent PLA layed down in a concentric pattern. On top of that black and red PLA and lastlt a black layer. All layers printed with a .4 mm nozzle and layerheight .4 mm. The coaster has a diameter of 80 mm.
        There some moiré effects so there are things to improve. But as a first test I think it worked out fine.
        (The text translates to "transmission interruption")
        Baenwortundefined 1 Reply Last reply Reply Quote 1
        • Baenwortundefined
          Baenwort @fotomas
          @fotomas are you using Cura, and do you have the Monotonic setting enabled?
          https://community.ultimaker.com/topic/37964-ultimaker-cura-411-is-available-now/
          I think Superslicer has a similar setting. It may help with the visual pattern.
          • fotomasundefined
            fotomas @Baenwort
            @baenwort I am using PrusaSlicer that also has the monotonic pattern, for the top layer.
            This is the bottom pattern and second layer so monotonic is not applicable.
            It is the crossing between the spiral pattern in the bottom layer and the rect linear pattern in the second payer that causes the moiré effect.
            As far as I know there is no way of choose the fillpattern of solid layers within a model other than 100% infill and a infill pattern, but those are 3D patterns in almost all cases...
            engikeneerundefined Baenwortundefined 2 Replies Last reply Reply Quote 0
            • engikeneerundefined
              engikeneer @fotomas
              @fotomas you could do a layer variation and add ironing to the first layer? Would at least flatten off the clear layer to avoid some of the interactions?
              i3 clone with a bunch of mods
                SuperSlicer might give you some more control.
                A thinner first layer might help?
                • fotomasundefined
                  fotomas @engikeneer
                  @engikeneer Testing ironing on top of first/bottom layer.... will know more in 1hr...
                  Did not work. For some reason did not the setting have any effect.
                  Maybe not intended to be used like that or me doing something wrong....
                    I think ironing may be limited to external layer only. Unless I misunderstood what you mean by ironing the first layer.
                    engikeneerundefined 1 Reply Last reply Reply Quote 0
                      engikeneer @Phaedrux
                      @phaedrux @fotomas PrusaSlicer has an option for where you apply it: top most layer, all top surfaces, or all solid surfaces. I guess you'll need to apply all solid surfaces then turn it off for every layer above 1
                      EDIT: you should also be able to see the ironing in the slicer preview so may be worth double checking it's put it in properly before hitting print.
                      • Baenwortundefined
                        Baenwort @fotomas
                        @fotomas said in Anyone tested ironing with transparent filament?:
                        The setting in Curate can be applied to Top and Bottom lines. It can also be applied to Ironing and or the actual top/bottom layer lines.
                        You'll need to go into Setting visibility and enable them but it may help.
                        Combined with setting a bottom layers thickness that causes the bottom several layers to be monotonic and the same pattern (doesn't need to be just concentric) you might improve things. It may also need you to set the top/bottom line direction manually so they go the same way for non concentric patterns. The default has each layer of the bottom going in a different direction.
