    Odd thermistor faults.
    703
      Phaedrux Moderator @Phaedrux
      @phaedrux said in Odd thermistor faults.:
      Was your MCU temp reading calibrated?
      https://duet3d.dozuki.com/Wiki/Calibrating_the_CPU_temperature
      wdenkerundefined 1 Reply Last reply Reply Quote 0
      • wdenkerundefined
        wdenker @Phaedrux
        @phaedrux no but my infrared thermometer shows it is accurate.
        www.bd3dcustoms.com | BD3DCUSTOMS Supercube
        • wdenkerundefined
          wdenker
          @phaedrux here is after a pause and resume and MCU showing 38c and infrared confirms 38cScreenshot_20220209-223044.png
            I think the MCU temp is a red herring.
            The graph seems more like noise or interference. Or failing thermistor.
            • wdenkerundefined
              wdenker @Phaedrux
              @phaedrux thermistor was just replaced. I can replace again and see if I still have issues I suppose.
                Does any component on the board seem to be getting abnormally hot?
                • wdenkerundefined
                  wdenker @Phaedrux
                  @phaedrux extruder motor is.
                  jay_s_ukundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                    jay_s_uk @wdenker
                    @wdenker my guess is it's noise from nearby wiring such as running next to a motor cable
                    • wdenkerundefined
                      wdenker @jay_s_uk
                      @jay_s_uk I've got 8 other printers wired and running the same way. Only difference is this one is duet 3 instead of duet wifi 2.
                        Phaedrux Moderator @wdenker
                        @wdenker said in Odd thermistor faults.:
                        I mean on the board itself.
                        • wdenkerundefined
                          wdenker @Phaedrux
                          @phaedrux no one including the expansion board where the thermistor is plugged in. Both good temps now.
