    Odd thermistor faults.
    703
    • jens55undefined
      jens55 @wdenker
      @wdenker said in Odd thermistor faults.:
      @jens55 yeah this isn't a thermistor issue. All of my wiring checks out good. I actually found that my MCU temp was too high. I've got a fan on it now and it is holding strong.
      As I said, it is a VERY common failure mode of thermistors. Got nothing to do with wiring although I suppose a teeny tiny portion of wiring faults could possibly present like that.
      At 50C or whatever, has nothing to do with the MCU either!
      It is also a very random type of failure that shows up whenever the moon aligns with Alph Centuri and you got up on the left side of the bed tat morning. .... but hey, a fan doesn't hurt but don't expect that to fix the issue.
      I suggest you replace the thermistor to see if it fixes things.
      Peace ... out ...< drops keyboard and leaves the room> <heavy gesturing with arms to emphasize for proper drama purposes>
      • wdenkerundefined
        wdenker @Phaedrux
        @phaedrux well mcu temp helped for about an hour longer. i paused on the next blip and started back again and is solid.
        www.bd3dcustoms.com | BD3DCUSTOMS Supercube
          Phaedrux Moderator @Phaedrux
          @phaedrux said in Odd thermistor faults.:
          Was your MCU temp reading calibrated?
          https://duet3d.dozuki.com/Wiki/Calibrating_the_CPU_temperature
          wdenkerundefined 1 Reply Last reply Reply Quote 0
          • wdenkerundefined
            wdenker @Phaedrux
            @phaedrux no but my infrared thermometer shows it is accurate.
            • wdenkerundefined
              wdenker
              @phaedrux here is after a pause and resume and MCU showing 38c and infrared confirms 38cScreenshot_20220209-223044.png
                I think the MCU temp is a red herring.
                The graph seems more like noise or interference. Or failing thermistor.
                • wdenkerundefined
                  wdenker @Phaedrux
                  @phaedrux thermistor was just replaced. I can replace again and see if I still have issues I suppose.
                    Does any component on the board seem to be getting abnormally hot?
                    • wdenkerundefined
                      wdenker @Phaedrux
                      @phaedrux extruder motor is.
                      jay_s_ukundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                        jay_s_uk @wdenker
                        @wdenker my guess is it's noise from nearby wiring such as running next to a motor cable
                        • wdenkerundefined
                          wdenker @jay_s_uk
                          @jay_s_uk I've got 8 other printers wired and running the same way. Only difference is this one is duet 3 instead of duet wifi 2.
                            Phaedrux Moderator @wdenker
                            I mean on the board itself.
                            • wdenkerundefined
                              wdenker @Phaedrux
                              @phaedrux no one including the expansion board where the thermistor is plugged in. Both good temps now.
