    BLTouch not working
    832
    • hsverreundefined
      hsverre @Phaedrux
      @phaedrux said in BLTouch not working:
      @hsverre said in BLTouch not working:
      connected the bltouch directly on the bord. But, with the same result.
      Have you tried connecting this BLtouch to one of your other printers? Perhaps the BLTouch itself isn't working.
      I have don that some days ago. I will try again just to make shure thats not the problem.
      • hsverreundefined
        hsverre @Phaedrux
        @phaedrux Could it be an option to reflash the os from scratch?
          Phaedrux Moderator @hsverre
          I don't think it's going to make a difference.
          The easy way to test the BLtouch is to connect 5v and ground and see if it lights up and tests the pin.
          hsverreundefined 1 Reply Last reply Reply Quote 0
          • hsverreundefined
            hsverre @Phaedrux
            Thats the black and white wire?
              No. On a genuine BLTouch 5v is red and ground is black/brown.
              hsverreundefined 2 Replies Last reply Reply Quote 0
              • hsverreundefined
                hsverre @Phaedrux
                @phaedrux
                Are you refering to the brown on the PWM or the black on the Probe?
                DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
                • hsverreundefined
                  hsverre @Phaedrux
                  @phaedrux
                  The red and black/blue show 0 Volt
                  • DIY-O-Sphereundefined
                    DIY-O-Sphere @hsverre
                    @hsverre
                    Doesn't matter but disconnect the probe from the board.....
                    (UTC+1)
                    • hsverreundefined
                      hsverre @DIY-O-Sphere
                      @diy-o-sphere
                      I did that and the red and brown pin show 0 volt
                        @hsverre
                        You can connect the probe directly to 5v as @Phaedrux mentioned.
                        (UTC+1)
                        • hsverreundefined
                          hsverre
                          @diy-o-sphere
                          No one of the PWM ports gives 5 V, all of them show 0 V.
                          And both the BLTOuches works fine on another printer. So they are ok.
                          There has to be something wrong with the power on the PWM pins
                            @hsverre
                            There is a jumper on the duex for the use of an external 5v supply.
                            Have you checked that?
                            (UTC+1)
                            • hsverreundefined
                              @diy-o-sphere
                              I have played a bit back and forth with that pin. When in the position the schem show the PWM pins gives 2.658 V
                                @hsverre
                                Set the jumper that way.
                                (UTC+1)
                                • hsverreundefined
                                  @diy-o-sphere
                                  BTW Do I need an external powersupply for the Duex other than the 12 V?
                                    @hsverre
                                    Only with big 5v fans....
                                    Edit:
                                    To be exact larger consumers like LEDs, rc servos...... in total more than 1A on the 5v line.
                                    (UTC+1)
                                    • hsverreundefined
                                      @diy-o-sphere said in BLTouch not working:
                                      @hsverre
                                      I dont have any 5 V fan
                                      • hsverreundefined
                                        @hsverre
                                        Now i have set the jumper that way and 2.6 V (half of 5?) at thw PWM
                                          @hsverre
                                          You cannot measure this exactly with a voltmeter. But it could be plausible for an end position. It's been a few years since I've measured that too.....I would give it a try.
                                          (UTC+1)
                                          • hsverreundefined
                                            The BLTouch still dont work with the 2.6 v. In my opinion the problem is that the PWM gives 2.6 V and not 5 V. The schematics says 5 V and then I should measure 5 V at that pin.
                                            • droftartsundefined droftarts referenced this topic
                                            • hsverreundefined hsverre referenced this topic
