    BLTouch not working
    848
    • hsverreundefined
      hsverre @Phaedrux
      @phaedrux Could it be an option to reflash the os from scratch?
        Phaedrux Moderator @hsverre
        @hsverre said in BLTouch not working:
        I don't think it's going to make a difference.
        The easy way to test the BLtouch is to connect 5v and ground and see if it lights up and tests the pin.
        hsverreundefined 1 Reply Last reply Reply Quote 0
        • hsverreundefined
          hsverre @Phaedrux
          @phaedrux said in BLTouch not working:
          Thats the black and white wire?
            No. On a genuine BLTouch 5v is red and ground is black/brown.
            hsverreundefined 2 Replies Last reply Reply Quote 0
            • hsverreundefined
              hsverre @Phaedrux
              @phaedrux
              Are you refering to the brown on the PWM or the black on the Probe?
              DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
              • hsverreundefined
                hsverre @Phaedrux
                @phaedrux
                The red and black/blue show 0 Volt
                • DIY-O-Sphereundefined
                  DIY-O-Sphere @hsverre
                  @hsverre
                  Doesn't matter but disconnect the probe from the board.....
                  (UTC+1)
                  • hsverreundefined
                    hsverre @DIY-O-Sphere
                    @diy-o-sphere
                    I did that and the red and brown pin show 0 volt
                      @hsverre
                      You can connect the probe directly to 5v as @Phaedrux mentioned.
                      (UTC+1)
                      • hsverreundefined
                        hsverre
                        @diy-o-sphere
                        No one of the PWM ports gives 5 V, all of them show 0 V.
                        And both the BLTOuches works fine on another printer. So they are ok.
                        There has to be something wrong with the power on the PWM pins
                          @hsverre
                          There is a jumper on the duex for the use of an external 5v supply.
                          Have you checked that?
                          (UTC+1)
                          • hsverreundefined
                            @diy-o-sphere
                            I have played a bit back and forth with that pin. When in the position the schem show the PWM pins gives 2.658 V
                              @hsverre
                              Set the jumper that way.
                              (UTC+1)
                              • hsverreundefined
                                @diy-o-sphere
                                BTW Do I need an external powersupply for the Duex other than the 12 V?
                                  @hsverre
                                  Only with big 5v fans....
                                  Edit:
                                  To be exact larger consumers like LEDs, rc servos...... in total more than 1A on the 5v line.
                                  (UTC+1)
                                  • hsverreundefined
                                    @diy-o-sphere said in BLTouch not working:
                                    @hsverre
                                    I dont have any 5 V fan
                                    • hsverreundefined
                                      @hsverre
                                      Now i have set the jumper that way and 2.6 V (half of 5?) at thw PWM
                                        @hsverre
                                        You cannot measure this exactly with a voltmeter. But it could be plausible for an end position. It's been a few years since I've measured that too.....I would give it a try.
                                        (UTC+1)
                                        • hsverreundefined
                                          The BLTouch still dont work with the 2.6 v. In my opinion the problem is that the PWM gives 2.6 V and not 5 V. The schematics says 5 V and then I should measure 5 V at that pin.
                                          • droftartsundefined droftarts referenced this topic
                                          • hsverreundefined hsverre referenced this topic
                                            You can source 5v from other points on the Duex for testing purposes.
                                            https://duet3d.dozuki.com/Wiki/Duex_wiring_diagrams
                                            Another possible test would be to disconnect the Duex Ribbon cable and connect the BLtouch wires as shown for a simple Duet connection. If the BLTouch works there, then we have isolated the problem to the Duex itself.
