    BLtouch 3.1 on Duet 2 WiFi 1.05 does not work
    695
    • Schotteundefined
      Schotte @Phaedrux
      @phaedrux
      m558 p9
      Error: M558: Missing Z probe pin name(s)
        Can you copy and paste this line into the gcode console and report back what it says?
        M558 P9 C"^zprobe.in" H5 F120 T6000
        Schotteundefined 1 Reply Last reply Reply Quote 0
        • Schotteundefined
          Schotte @Phaedrux
          @phaedrux
          reply
          • Schotteundefined
            Schotte
            Did a test, pressure plate goes up, but the pin from the Bltouch doesn't go out
              And if you send M950 S0 C"exp.heater3" does M401 and M402 work?
              • Schotteundefined
                Schotte @Phaedrux
                @phaedrux
                Unfortunately not
                  Do you get an error from sending that M950?
                  If you replace the M558 line in your config with the one you manually sent, does it stop the error message you were getting before?
                  • Schotteundefined
                    Schotte @Phaedrux
                    @phaedrux said in BLtouch 3.1 on Duet 2 WiFi 1.05 does not work:
                    15.2.2022, 21:20:33 M950 s0
                    GPIO/servo port 0 pin (exp.heater3,exp.8) frequency 50Hz
                    yes, and the table moves up
                      Are you sure you have the yellow wire connected to exp.heater3?
                      • Schotteundefined
                        Schotte @Phaedrux
                        @phaedrux
                        yes, we have already checked several times
                          Can you test with a different heater pin then? exp.heater7 perhaps? Alter the M950 command accordingly.
                          It may also be worthwhile testing with a fresh set of configs from the config tool.
                          https://configtool.reprapfirmware.org/Start
                          • Schotteundefined
                            Schotte @Phaedrux
                            @phaedrux
                            We had already tested heater 7 and will be testing heater 5 and 7 again soon.
                            I just created a new config, we will test it afterwards.
                            Also, a big thank you for your help! That's great
                            • JoergS5undefined
                              JoergS5
                              @schotte I am not sure, but
                              M558 P9 C"^zprobe.in" H12 R1.0 F500:F120 T6000
                              F parameter looks wrong to me, it should be F500:120 (so without second F letter).
                              • Schotteundefined
                                Schotte
                                @Phaedrux
                                Have tested heater 5 and 7, Bltouch still doesn't work.
                                New SD card with new system didn't help either.
                                  Can you test with the BLTouch leads connected directly to the board without any extension?
                                  The M558 problem is resolved, now we just need to get the servo communicating.
                                  You mentioned in your first post that the power on pin test of the bltouch moves slowly. Is the BLtouch held upright? Have you tried connecting only 5v and ground?
                                  • Schotteundefined
                                    Schotte @Phaedrux
                                    @phaedrux
                                    We can no longer connect the Bltouch directly without further.
                                    If we unplug the yellow wire from the Heater5 pin, the Bltouch will do the self-test at normal speed. Once the yellow wire is reconnected, again slowly.
                                    @JoergS5
                                    we will test again when the BLtouch is running - thanks for the tip
                                    • JoergS5undefined
                                      JoergS5 @Schotte
                                      @schotte another thing to check is whether the probe pin can move correctly. The distance and freedom of moving is defined by the screw at the top which can be changed with an allen key.
                                      https://www.antclabs.com/bltouch-v3
                                      the picture
                                      • Schotteundefined
                                        Schotte @JoergS5
                                        @joergs5
                                        The pen is smooth, shouldn't be a problem
                                        Our measurement is 0.2mm
                                          If you're certain the wiring is correct and there is continuity on the wires there is still the possibility the probe itself is defective.
                                          Do you have another printer to test the probe with, or another probe to test on this printer?
                                          • Schotteundefined
                                            Schotte @Phaedrux
                                            @phaedrux
                                            I'm helping a friend online through Teamviewer and he lives about 90 miles away. He's going to order a new one and then we'll see.
                                            We will then report, hopefully it works with the new one.
