    BLtouch 3.1 on Duet 2 WiFi 1.05 does not work
    695
      And if you send M950 S0 C"exp.heater3" does M401 and M402 work?
      Schotteundefined 1 Reply Last reply Reply Quote 0
      • Schotteundefined
        Schotte @Phaedrux
        @phaedrux
        Unfortunately not
          Do you get an error from sending that M950?
          If you replace the M558 line in your config with the one you manually sent, does it stop the error message you were getting before?
          M558 P9 C"^zprobe.in" H5 F120 T6000
          • Schotteundefined
            Schotte @Phaedrux
            @phaedrux said in BLtouch 3.1 on Duet 2 WiFi 1.05 does not work:
            15.2.2022, 21:20:33 M950 s0
            GPIO/servo port 0 pin (exp.heater3,exp.8) frequency 50Hz
            yes, and the table moves up
              Are you sure you have the yellow wire connected to exp.heater3?
              • Schotteundefined
                Schotte @Phaedrux
                @phaedrux
                yes, we have already checked several times
                  Can you test with a different heater pin then? exp.heater7 perhaps? Alter the M950 command accordingly.
                  It may also be worthwhile testing with a fresh set of configs from the config tool.
                  https://configtool.reprapfirmware.org/Start
                  • Schotteundefined
                    Schotte @Phaedrux
                    @phaedrux
                    We had already tested heater 7 and will be testing heater 5 and 7 again soon.
                    I just created a new config, we will test it afterwards.
                    Also, a big thank you for your help! That's great
                    • JoergS5undefined
                      JoergS5
                      @schotte I am not sure, but
                      M558 P9 C"^zprobe.in" H12 R1.0 F500:F120 T6000
                      F parameter looks wrong to me, it should be F500:120 (so without second F letter).
                      • Schotteundefined
                        Schotte
                        @Phaedrux
                        Have tested heater 5 and 7, Bltouch still doesn't work.
                        New SD card with new system didn't help either.
                          Can you test with the BLTouch leads connected directly to the board without any extension?
                          The M558 problem is resolved, now we just need to get the servo communicating.
                          You mentioned in your first post that the power on pin test of the bltouch moves slowly. Is the BLtouch held upright? Have you tried connecting only 5v and ground?
                          • Schotteundefined
                            Schotte @Phaedrux
                            @phaedrux
                            We can no longer connect the Bltouch directly without further.
                            If we unplug the yellow wire from the Heater5 pin, the Bltouch will do the self-test at normal speed. Once the yellow wire is reconnected, again slowly.
                            @JoergS5
                            we will test again when the BLtouch is running - thanks for the tip
                            • JoergS5undefined
                              JoergS5 @Schotte
                              @schotte another thing to check is whether the probe pin can move correctly. The distance and freedom of moving is defined by the screw at the top which can be changed with an allen key.
                              https://www.antclabs.com/bltouch-v3
                              the picture
                              • Schotteundefined
                                Schotte @JoergS5
                                @joergs5
                                The pen is smooth, shouldn't be a problem
                                Our measurement is 0.2mm
                                  If you're certain the wiring is correct and there is continuity on the wires there is still the possibility the probe itself is defective.
                                  Do you have another printer to test the probe with, or another probe to test on this printer?
                                  • Schotteundefined
                                    Schotte @Phaedrux
                                    @phaedrux
                                    I'm helping a friend online through Teamviewer and he lives about 90 miles away. He's going to order a new one and then we'll see.
                                    We will then report, hopefully it works with the new one.
                                    • Schotteundefined
                                      Schotte
                                      Hello
                                      We tested the direct connection with a new BL-Touch and it worked. We then found out that it was the extension cable for the BL-Touch, the internal resistance was too high.
                                      Everything works now.
                                      Thanks again for the help!!!!
                                      • Phaedruxundefined Phaedrux has marked this topic as solved
                                      • Schotteundefined
                                        Schotte
                                        This post is deleted!
