    Orbiter 2 extruder mounting for Smart effector with Magball arms
    Smart effector for delta printers
    12
    56
    5.8k
      jay_s_uk @dc42
      I've managed to mount an LGX Lite and (just about) keep the full 380mm diameter on the predator I'm working on without adjusting the magball mountings
      bbergerundefined 1 Reply Last reply Reply Quote 3
      • bbergerundefined
        bberger
        For reference:
        This is the absolute minimum needed for the Predator with a 380mm bed, 440mm arms and 235mm delta radius with a 55mm smart effector.
        I'm currently using this and it's clearing the rods by maybe 1mm at the extreme edge of the bed.
        Currently prototyping 80mm spacing (with 12mm distance between the adjacent balls), but haven't had time to mount it yet, some tweaks still needed as I also want to directly integrate an Orbiter mount on my adapter. Goal would be to mount it completely flat for center of gravity reasons.
        @jay_s_uk wow. Isn't the LGX Lite supposed to be even bigger than the orbiter? (see the mount I'm using from above).
          jay_s_uk @bberger
          @bberger could be. mines on a predator too, although using 450mm arms
          bbergerundefined 1 Reply Last reply Reply Quote -1
          • bbergerundefined
            bberger @jay_s_uk
            @jay_s_uk what's the motor (or better how deep is the motor, 17mm? 20mm? 24mm?) you're using on the LGX?
              jay_s_uk @bberger
              @bberger using a 17mm Moons rather than a 20mm LDO
              bbergerundefined 1 Reply Last reply Reply Quote 0
              • bbergerundefined
                bberger @jay_s_uk
                @jay_s_uk after toying around im CAD I see why the LGX Lite fits better: it's a symmetrical design with the motor in the center. On the orbiter the motor is heavily offset.
                Adrian52undefined 1 Reply Last reply Reply Quote 1
                • amjm22undefined
                  amjm22
                  Here is what I am using with my Smart Effector.
                  https://www.thingiverse.com/thing:516254120220207_212516.jpg
                  • Adrian52undefined
                    Adrian52 @bberger
                    @bberger my thought about horizontal assymetry is that it will create a turning effect for vertical motion, so it should not be much of a problem for the small incremental z movements whilst printing. I was trying to get the extruder weight as low as possible to minimise the turning moment caused by large and rapid x/y motion. The slightly wider arm spacing should also resist this turning effect better?
                    • Adrian52undefined
                      Adrian52 @amjm22
                      @amjm22 This is what mine looks like now
                      I have made the part cooling fan bracket vertical, and redone the duct - its much easier to get at the mounting screws and adjust the fan height.
                      • bbergerundefined
                        bberger
                        This is what I've tried so far. Just disassembled it and trying something different (all-in-1-adapter for Orbiter + SE).
                        https://youtu.be/rO-gD0ADkQc
                        Will upload pics of my current/latest attempt shortly..
                        I tried to keep the underside of the effector flat to the adapter so I can reuse my cooling solutions..
                        • bbergerundefined
                          bberger
                          Just a note:
                          After ghosting got worse and worse the more I experimented with 80mm spacing I'm back to this:
                          https://www.thingiverse.com/thing:5253693 (I remixed the excellent 2 arm rigid adapter to be a 3 arm adapter, rigidly mounting the Orbiter v2 adapter from above to the hotend adapter woth 3 screws and additionally the nut).
                          This seems to have solved all my problems and is the clear winner.
                          No ringing ghosting visible without Input Shaper up to ~4k, with 42Hz MVZ the limit on my machine are the motors now (striking out at ~12k acceleration on the far edges of the bed).
                          I printed a 23 minute Benchy yesterday with 500mms@10k + Input Shaper (outer walls at 250mms@3k) with basically no defect.
                          So I'd wager to say: rigidity beats center of gravity in my case. Screwing the rigid 3 arm adapter to the tall Orbiter v2 adapter together tightly was the secret sauce. Didn't work well with just the nut on the V6 M12 heatsink.
                          I can also run the SE on 25 sensitivity and get excellent results. Deviation < 0.002.
                          The only thing that's still puzzling me a bit is that 42Hz resonance frequency. It's the same frequency I ended up with all of my tried solutions, be it 55mm spacing with the M12 and the tall adapter, 80mm spacing with the short adapter or the "solid shield". The difference is just the amplitude of it. Mounting the frame on squash feet, using the stock machine damper feet or bolting it to a slab ob granite. All ending up on 42Hz.
                          Not sure if stiffening my frame would help here, I suspect it's either the PLA-CF carriages on the MGN12 rail bolted to the frame, the belts (6mm geniune Gates RF belt or the Moon's motors themselves..?).
                          • bbergerundefined
                            bberger @jay_s_uk
                            @jay_s_uk would you be willing to share the STEP/F3D file on your LGX Mount? Would be using a 20mm motor though and would like to get a starting point on the tilt and offset..
                            Fred-Yundefined 1 Reply Last reply Reply Quote 0
                            • bbergerundefined
                              bberger
                              I've settled on a solution for me now. Still undecided if I want to go back to the flying orbiter v2 though as the input shaping graphs don't look too bad, but compared to the flying extruder don't look too good either.. and I'm kinda into getting prints done as fast as I can:
                              Direct Drive Orbiter v2 on 80mm adapter:
                              Flying Orbiter v2 on stock 55mm Smart Effector:
                              Flying Orbiter v2 on 80mm Adapter for reference what the 80mm adapter alone does to my input shaper graph:
                              //Edit: the graphs only tell half the truth. I can't even get close to max suggested accelerations on the direct drive without having motion artifacts (no ringing, but "smoothing" from hell). Need to go down to about 2.5k to have comparable print quality to the flying extruder on 8.5k acceleration.
                              I'll be reverting back and just get a second printer for printing flexibles.
                              • Fred-Yundefined
                                Fred-Y @bberger
                                @bberger Have you redesigned a LGX lite mount for the Smart Effector?
                                I spend quite some time lately on pushing my SR with a flying LGX Lite so I would like to compare with a direct drive.
                                bbergerundefined weed2allundefined 2 Replies Last reply Reply Quote 0
                                • bbergerundefined
                                  bberger @Fred-Y
                                  @fred-y I don't have a solution that I'm happy to share tbh (80mm rod spacing adapter + a pain in the butt mount for the LGX lite).
                                  That LGX Lite is a pain to mate to the smart effector and any adapter I had thought of. The pain of a need to screw them from the bottom is real.
                                  BUT: on the SR I suspect you could probably get away with this without losing print volume:
                                  https://www.thingiverse.com/thing:5255358
                                  It doesn't print really well though and needs supports.
                                  Fred-Yundefined 1 Reply Last reply Reply Quote 1
                                  • Fred-Yundefined
                                    Fred-Y @bberger
                                    @bberger Thanks for the link, I didn't see this one the other day when I did a search.
                                    On my other printers I have a 2 parts mount for the LGX Lite because of these screws on the bottom; Maybe I should be looking at doing the same or just give up.
                                    On a side note, the other day I realized something about how we mount the extruder on the SE - I have not an expert on kinematic / force but with the extruder mount attached on the effector we apply the filament pressure on the 3 screws.
                                    When doing high speed printing this pressure is fairly high.
                                    I was wondering if we could be looking at reusing the thread from the hotend by this way there is no (or very little) pressure on the PCB but I'm worry about the impact for the probe.
                                    The 3 holes on the PCB could just be used to stabilize everything.
                                    I'm just sharing the idea ... what do you think?
                                    bbergerundefined Adrian52undefined Falkiaundefined 3 Replies Last reply Reply Quote 0
                                    • Adrian52undefined
                                      Adrian52
                                      Just to add that I have updated the orbiter 2 mount, posted at https://www.thingiverse.com/thing:5402227
                                      I have made small changes including thickening the top mount and extruder mount, and kept the 55 mm magball spacing. I have recently started using a revo micro extruder, so have included a part cooling duct for that.
                                      The revo seems to have a higher melt rate than the v6 I was using previously, so I have been able to print at 250mm/sec, with 300mm/sec travel speed, with very good results.
                                      • bbergerundefined
                                        bberger @Fred-Y
                                        @fred-y though about exactly that multiple times. Problem is that it's pointless with 55mm magball spacing as you need some real nasty vertical offset and tilt to jot collide with the arms which then puts a lot of direct force onto the hotend itself.
                                        Adrian52undefined 1 Reply Last reply Reply Quote 0
                                        • Adrian52undefined
                                          Adrian52 @bberger
                                          @bberger I find that the 55mm spacing (which I wanted to use to avoid changes to carriages) works well with a 12mm extension - the extruder can be horizontal (filament path vertical). Here is my setup in the furthest -Y position, where the arms are closest to the extruder motor.
                                          The gap between the extruder platform and the top of the hotend is about 1mm:
                                          7ce2022e-d946-4cbd-9f47-617e41d37057-image.png , giving the shortest possible filament path. I would have thought that as the downward force during extrusion is symetrically distrubuted, the strain on the effector/hotend should not be a problem.
                                          These puzzle pieces, which are about 40mm long and 14mm high, were printed at 250mm/sec, with 300mm/sec travel.
                                          The pieces fit together to make and Escher solid:
                                          We have just had a jubilee here in the UK - hence the red white and blue. The pieces have to be very precise to fit together with no gaps.
                                          • Adrian52undefined
                                            Adrian52 @Fred-Y
                                            @fred-y Thanks for this idea - it seems to work. I made this:
                                            using the two holes on the motor side of the extruder. This leaves a nice gap on the molex connector side for the plug to fit properly.
                                            This is how it looks in situ:
                                            I am using the default sensitivity on a v3 smart effector, and found that it needed an extra -0.04 on the probe offset. Seems to work well though - a 19 point G32 gave a 0.010 fit.
                                            The mount pictured was printed with the new setup - I was fine tuning the thread diameter - 12.3mm was good for me. I havent pushed the new setup yet - seems promising though.
                                            Fred-Yundefined vapvapundefined 2 Replies Last reply Reply Quote 3
