    Closed-Loop tuning on CL57T stepper driver
    1.5k
    • alankilianundefined
      alankilian @V.A.M.P printing snproj
      @v-a-m-p-printing-snproj
      OK, so you have the encoders hooked up properly and everything is setup to start tuning.
      I would start by printing a box that is one wall thick and about 30mm square at a VERY SLOW speed.
      This will show how well your motors are following the commanded position at setting #0 on the rotary switch S1 on the CL57T V4.0.
      After that, you should increase the speed to where you want it to be and if everything is OK, you're done!
      V.A.M.P printing snprojundefined 1 Reply Last reply Reply Quote 0
        Phaedrux Moderator @V.A.M.P printing snproj
        @v-a-m-p-printing-snproj said in Closed-Loop tuning on CL57T stepper driver:
        It will not let me post my config file
        Try again?
        • V.A.M.P printing snprojundefined
          V.A.M.P printing snproj @Phaedrux
          @phaedrux ; Configuration file for Duet WiFi (firmware version 2.03)
          ; generated by RepRapFirmware Configuration Tool v3.2.3 on Mon Mar 15 2021 15:55:39 GMT-0400 (Eastern Daylight Time)
          M550 P"VAMP" ; set printer name
          M669 K1 ; select CoreXY mode
          M586 P0 S1 ; enable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          M569 P3 S0 ; physical drive 3 goes forwards
          M569 P5 S1 T2.5:2.5:5:5 ; physical drive 5 goes forwards
          M569 P6 S1 T2.5:2.5:5:5 ; physical drive 6 goes forwards
          M569 P7 S0 T2.5:2.5:5:5 ; physical drive 7 goes backwards
          M569 P8 S0 T2.5:2.5:5:5 ; physical drive 8 goes backwards
          M569 P9 S0 T2.5:2.5:5:5 ; physical drive 9 goes backwards
          M584 X5 Y6 Z7:8:9 E3 ; set drive mapping
          M92 X80.5234 Y79.6020 Z800.00 E95.00 ; set steps per mm
          M566 X900.00 Y900.00 Z60.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X6000.00 Y6000.00 Z180.00 ; set maximum speeds (mm/min)
          M201 X500.00 Y500.00 Z20.00 ; set accelerations (mm/s^2)
          M906 E1600 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 X415 Y415 Z440 S0 ; set axis maxima
          M574 X1 Y2 S1 ; set active high endstops
          M307 H6 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
          M558 P9 H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
          M305 P0 T100000 B3950 R4700
          M305 P1 T4700000 B5140 R4700 ; set thermistor + ADC parameters for heater 1
          M143 H0 S180 ; set temperature limit for heater 0 to 100C
          M143 H1 S490 ; set temperature limit for heater 1 to 490C
          M501
            V.A.M.P printing snproj @alankilian
            @alankilian
            Okay ill do that and let you know how it goes. Since I had to change my home all coordinates for the Y position when the Z axis is homing, will this effect coordinates for a print?
              I don't know,
              Home the printer and then use G1 to move to someplace.
              Then measure the distance from the printer's origin to that location and see if it matches.
                I think it should only matter if you've changed M208.
                  @phaedrux Okay my only concern before starting a print is before i changed my drivers, in front of the rear lead screw it was reading that Y was at 85 and now it is reading at 315 at that lead screw. Also when i look at the code for a print it has Y coordinates less than 315 which isnt on my build plate.
                    You should do some careful positioning testing before starting a print.
                    https://docs.duet3d.com/en/User_manual/Tuning/Bed_origin
                    V.A.M.P printing snprojundefined 1 Reply Last reply Reply Quote 1
                      @phaedrux Okay sounds good thanks!
                        V.A.M.P printing snproj @V.A.M.P printing snproj
                        Okay so I've been messing around with movement on my printer and notice the distance the printer head is moving is not correct. Before my maximum for the x and y was 415, but when i would try to go to X0 Y0 it could go to Y0. So I set the maximum to 115 for both the X and Y and now it can go to X0 Y0. Why is the distance my print head is traveling reading differently now?
                          I don't quite understand, I'm sorry.
                          If you can type in the exact GCODE commands you are typing and tell us what you expect to happen and what actually happens it will help understand what's going wrong.
                            @alankilian
                            My bed length and width is 415mm but after getting everything going in the right direction when I command the printer to move to X115 Y115 it will travel to what should be 415mm.
                              I still don't understand because you didn't follow my instructions telling me what GCODE commands you enter.
                              But I'll guess (Which wastes all our time)
                              OK, you ask the printer to move 115mm in X and 115mm in Y and is actually moves 415, in X and 415mm in Y?
                              That would mean you are commanding too many steps.
                              Maybe change
                              to:
                              M350 X4 Y4 Z16 E16 I1 ; configure microstepping with interpolation
                              And see if it gets closer to the right move length.
