    npn 5v fly rrf e3
    STM
    2.2k
    • npm1undefined
      npm1 @gloomyandy
      @gloomyandy Without M574
      M98 P"config.g"
      HTTP is enabled on port 80
      FTP is disabled
      TELNET is disabled
      Endstops - X: not stopped, Y: at min stop, Z: no endstop, Z probe: not stopped
      Z probe 0: current reading 0, threshold 500, trigger height 2.500, offsets X0.0 Y0.0
      Ender 5 pro(LGXextruderddewith e3d revo rapid changer) with fly rrf e3 and a standard prusa mk3, both siting air-tight in a ikea kitchen cabinet.
      gloomyandyundefined 1 Reply Last reply Reply Quote 0
      • gloomyandyundefined
        gloomyandy @npm1
        @npm1 Are those results with or without the probe being in a triggered state?
        npm1undefined 1 Reply Last reply Reply Quote 0
        • npm1undefined
          npm1 @gloomyandy
          @gloomyandy the first response is with m574 and the second response is without m574
            gloomyandy @npm1
            @npm1 Yes but I asked you to run M119 and G31 twice for each test once without having the probe in a triggered state and then again with the probe in a triggered state (by placing something metal near it so the LED comes on). Have you run the test with the Z driver removed?
            • npm1undefined
              npm1 @gloomyandy
              @gloomyandy
              without m574 and with metal touching the probe
              g31
              2/25/2022, 8:46:38 PM g31
              2/25/2022, 8:46:16 PM M119
              2/25/2022, 8:45:56 PM M98 P"config.g"
              FTP is disabled
              TELNET is disabled
              npm1undefined gloomyandyundefined 2 Replies Last reply Reply Quote 0
              • npm1undefined
                npm1 @npm1
                @gloomyandy with 574 and metal touching probe
                g31
                2/25/2022, 8:50:23 PM g31
                2/25/2022, 8:50:05 PM m119
                Endstops - X: not stopped, Y: at min stop, Z: not stopped, Z probe: not stopped
                  gloomyandy @npm1
                  @npm1 and the results with the Z driver removed from the socket?
                  • npm1undefined
                    npm1 @gloomyandy
                    @gloomyandy
                    removed z driver with m574
                    g31
                    2/25/2022, 8:59:47 PM M119
                    2/25/2022, 8:59:44 PM M119
                    2/25/2022, 8:59:33 PM M98 P"config.g"
                    FTP is disabled
                    TELNET is disabled
                    • npm1undefined
                      npm1 @npm1
                      @gloomyandy removed z driver with m574 metal touching
                      g31
                      2/25/2022, 9:01:46 PM g31
                      2/25/2022, 9:01:24 PM M119
                      • npm1undefined
                        npm1 @npm1
                        @gloomyandy removed z driver without m574
                        g31
                        2/25/2022, 9:04:04 PM g31
                        2/25/2022, 9:03:53 PM M119
                        • npm1undefined
                          npm1 @npm1
                          @gloomyandy removed z driver without m574 metal touching
                          G31
                          2/25/2022, 9:05:35 PM m119
                          • npm1undefined
                            npm1 @npm1
                            hope that helps
                              gloomyandy @npm1
                              @npm1 Are you still using this line for your probe definition:
                              M558 P5 C"!^zstop" H5 F120 T6000
                              If so with the Z driver still removed enter
                              M558 P5 C"zstop" H5 F120 T6000
                              in the console (or change the line in your config.g and reboot)
                              and rerun both sets of tests.
                              • npm1undefined
                                npm1 @gloomyandy
                                @gloomyandy still no changes, the only thing that change is the z probe value being 1000 instead of zero
                                • npm1undefined
                                  npm1 @npm1
                                  @gloomyandy have I blown something on the board
                                  • npm1undefined
                                    npm1 @npm1
                                    shall i update the firmware
                                    • npm1undefined
                                      npm1 @npm1
                                      Electronics
                                      Diagnostics
                                      Board: fly_E3 (STMWiFi)
                                      Firmware: RepRapFirmware for STM32F4 based Boards 3.3RC2+1_1 (2021-05-13)
                                      Duet WiFi Server Version: 1.26-01S-D
                                      Note: You can install updates on the System page.
                                      • npm1undefined
                                        npm1 @npm1
                                        will marlin be easier
                                          gloomyandy @npm1
                                          @npm1 Can you turn off your board, disconnect the probe and plug in one of the other endstop switches (x or y) into the zstop socket. Then run the two tests again once without pressing the endstop switch, then again with the endstop switch pressed. Run this test with the Z driver still removed.
                                          • npm1undefined
                                            npm1 @gloomyandy
                                            @gloomyandy endstop works with zero issues with everything triggered correctly
                                            M119
                                            Endstops - X: at min stop, Y: at min stop, Z: at min stop, Z probe: at min stop
                                            2/25/2022, 9:38:20 PM g31
                                            2/25/2022, 9:38:10 PM m119
                                            Endstops - X: at min stop, Y: at min stop, Z: not stopped, Z probe: not stopped
