    npn 5v fly rrf e3
    STM
    2.2k
      jay_s_uk @npm1
      @npm1 said in npn 5v fly rrf e3:
      npn 12mm BX probe
      and whats one of those? part number? data sheet? how are you powering it?
      npm1undefined 1 Reply Last reply Reply Quote 0
      • npm1undefined
        npm1 @jay_s_uk
        @jay_s_uk im using 5v from the bltouch connector and the original zstop connector...its from china brought through aliexpress M12 4mm DC 5V NPN NO LJ12A3-4-Z/BX-5V Inductive Proximity Sensor.
        It is a widely used component in the automatic control industry for non-contact detection, control and switching.
        When the proximity switch is close to a target object, it sends out a control signal.
        As it is a capacitive type proximity switch, its sensing object target is not limited to conductor, but also liquid and even powdery objects, like plastic, water, glass , oil, etc.
        It is widely used in machine, papermaking, light industry for limiting station, orientation considering, acceleration test ect.
        Specifications:
        3-wire polarity: NPN sensing
        Voltage: DC 5V
        Sensing distance: 4mm
        Output status: normally open
        Output current: 300mA
        Sensing objects: Conductor
        Part number: LJ12A3-4-Z/BX
        Screw length: 61mm
        Quantity: 1 Pc
        Note:
        Please allow 1-3mm error due to manual measurement. Please make sure you don't mind before you bid
        Due to the difference between different monitors, the picture may not reflect the actual color of the item. Thank you!
        Package Content:
        1pc x Inductive Switch
        Ender 5 pro(LGXextruderddewith e3d revo rapid changer) with fly rrf e3 and a standard prusa mk3, both siting air-tight in a ikea kitchen cabinet.
          jay_s_uk @npm1
          @npm1 what wires do you have going to where?
          • npm1undefined
            npm1 @jay_s_uk
            @jay_s_uk I have the + wire going to the 5v connection for the bltouch, the negative going to the left of the zstop connection and the signal going to the right of the zstop connection
            • npm1undefined
              npm1 @npm1
              @jay_s_uk the sensor lights up correctly when i put metal prong against it
              gloomyandyundefined 1 Reply Last reply Reply Quote 0
              • gloomyandyundefined
                gloomyandy @npm1
                @npm1 Please try the following...
                1. Run M98 P"config.g" and post any output.
                2. Run M119 and G31 in the console both with and without the probe being triggered.
                  3 Comment out the line: M574 Z1 S2 and then repeat the two tests run above.
                3. Power off the board, remove the Z driver module, power the board on again and re-run the tests in step 2.
                4. Post the output from all 6 of the tests.
                npm1undefined 2 Replies Last reply Reply Quote 0
                • npm1undefined
                  npm1 @gloomyandy
                  @gloomyandy
                  With M574
                  M98 P"config.g"
                  HTTP is enabled on port 80
                  FTP is disabled
                  TELNET is disabled
                  Endstops - X: not stopped, Y: at min stop, Z: not stopped, Z probe: not stopped
                  G31
                  Z probe 0: current reading 0, threshold 500, trigger height 2.500, offsets X0.0 Y0.0
                  • npm1undefined
                    npm1 @gloomyandy
                    @gloomyandy Without M574
                    M98 P"config.g"
                    FTP is disabled
                    TELNET is disabled
                    Endstops - X: not stopped, Y: at min stop, Z: no endstop, Z probe: not stopped
                      gloomyandy @npm1
                      @npm1 Are those results with or without the probe being in a triggered state?
                      • npm1undefined
                        npm1 @gloomyandy
                        @gloomyandy the first response is with m574 and the second response is without m574
                          gloomyandy @npm1
                          @npm1 Yes but I asked you to run M119 and G31 twice for each test once without having the probe in a triggered state and then again with the probe in a triggered state (by placing something metal near it so the LED comes on). Have you run the test with the Z driver removed?
                          • npm1undefined
                            npm1 @gloomyandy
                            @gloomyandy
                            without m574 and with metal touching the probe
                            g31
                            2/25/2022, 8:46:38 PM g31
                            2/25/2022, 8:46:16 PM M119
                            2/25/2022, 8:45:56 PM M98 P"config.g"
                            FTP is disabled
                            TELNET is disabled
                            npm1undefined gloomyandyundefined 2 Replies Last reply Reply Quote 0
                            • npm1undefined
                              npm1 @npm1
                              @gloomyandy with 574 and metal touching probe
                              g31
                              2/25/2022, 8:50:23 PM g31
                              2/25/2022, 8:50:05 PM m119
                                gloomyandy @npm1
                                @npm1 and the results with the Z driver removed from the socket?
                                • npm1undefined
                                  npm1 @gloomyandy
                                  @gloomyandy
                                  removed z driver with m574
                                  g31
                                  2/25/2022, 8:59:47 PM M119
                                  2/25/2022, 8:59:44 PM M119
                                  2/25/2022, 8:59:33 PM M98 P"config.g"
                                  FTP is disabled
                                  TELNET is disabled
                                  • npm1undefined
                                    npm1 @npm1
                                    @gloomyandy removed z driver with m574 metal touching
                                    g31
                                    2/25/2022, 9:01:46 PM g31
                                    2/25/2022, 9:01:24 PM M119
                                    • npm1undefined
                                      npm1 @npm1
                                      @gloomyandy removed z driver without m574
                                      g31
                                      2/25/2022, 9:04:04 PM g31
                                      2/25/2022, 9:03:53 PM M119
                                      • npm1undefined
                                        npm1 @npm1
                                        @gloomyandy removed z driver without m574 metal touching
                                        G31
                                        2/25/2022, 9:05:35 PM m119
                                        • npm1undefined
                                          npm1 @npm1
                                          hope that helps
                                            gloomyandy @npm1
                                            @npm1 Are you still using this line for your probe definition:
                                            M558 P5 C"!^zstop" H5 F120 T6000
                                            If so with the Z driver still removed enter
                                            M558 P5 C"zstop" H5 F120 T6000
                                            in the console (or change the line in your config.g and reboot)
                                            and rerun both sets of tests.
