    npn 5v fly rrf e3
    STM
    2.0k
      jay_s_uk @npm1
      @npm1 what wires do you have going to where?
      npm1undefined 1 Reply Last reply Reply Quote 0
      • npm1undefined
        npm1 @jay_s_uk
        @jay_s_uk I have the + wire going to the 5v connection for the bltouch, the negative going to the left of the zstop connection and the signal going to the right of the zstop connection
        Ender 5 pro(LGXextruderddewith e3d revo rapid changer) with fly rrf e3 and a standard prusa mk3, both siting air-tight in a ikea kitchen cabinet.
        • npm1undefined
          npm1 @npm1
          @jay_s_uk the sensor lights up correctly when i put metal prong against it
          gloomyandyundefined 1 Reply Last reply Reply Quote 0
          • gloomyandyundefined
            gloomyandy @npm1
            @npm1 Please try the following...
            1. Run M98 P"config.g" and post any output.
            2. Run M119 and G31 in the console both with and without the probe being triggered.
              3 Comment out the line: M574 Z1 S2 and then repeat the two tests run above.
            3. Power off the board, remove the Z driver module, power the board on again and re-run the tests in step 2.
            4. Post the output from all 6 of the tests.
            npm1undefined 2 Replies Last reply Reply Quote 0
            • npm1undefined
              npm1 @gloomyandy
              @gloomyandy
              With M574
              M98 P"config.g"
              HTTP is enabled on port 80
              FTP is disabled
              TELNET is disabled
              Endstops - X: not stopped, Y: at min stop, Z: not stopped, Z probe: not stopped
              G31
              Z probe 0: current reading 0, threshold 500, trigger height 2.500, offsets X0.0 Y0.0
              • npm1undefined
                npm1 @gloomyandy
                @gloomyandy Without M574
                M98 P"config.g"
                FTP is disabled
                TELNET is disabled
                Endstops - X: not stopped, Y: at min stop, Z: no endstop, Z probe: not stopped
                  gloomyandy @npm1
                  @npm1 Are those results with or without the probe being in a triggered state?
                  • npm1undefined
                    npm1 @gloomyandy
                    @gloomyandy the first response is with m574 and the second response is without m574
                      gloomyandy @npm1
                      @npm1 Yes but I asked you to run M119 and G31 twice for each test once without having the probe in a triggered state and then again with the probe in a triggered state (by placing something metal near it so the LED comes on). Have you run the test with the Z driver removed?
                      • npm1undefined
                        npm1 @gloomyandy
                        @gloomyandy
                        without m574 and with metal touching the probe
                        g31
                        2/25/2022, 8:46:38 PM g31
                        2/25/2022, 8:46:16 PM M119
                        2/25/2022, 8:45:56 PM M98 P"config.g"
                        FTP is disabled
                        TELNET is disabled
                        npm1undefined gloomyandyundefined 2 Replies Last reply Reply Quote 0
                        • npm1undefined
                          npm1 @npm1
                          @gloomyandy with 574 and metal touching probe
                          g31
                          2/25/2022, 8:50:23 PM g31
                          2/25/2022, 8:50:05 PM m119
                            gloomyandy @npm1
                            @npm1 and the results with the Z driver removed from the socket?
                            • npm1undefined
                              npm1 @gloomyandy
                              @gloomyandy
                              removed z driver with m574
                              g31
                              2/25/2022, 8:59:47 PM M119
                              2/25/2022, 8:59:44 PM M119
                              2/25/2022, 8:59:33 PM M98 P"config.g"
                              FTP is disabled
                              TELNET is disabled
                              • npm1undefined
                                npm1 @npm1
                                @gloomyandy removed z driver with m574 metal touching
                                g31
                                2/25/2022, 9:01:46 PM g31
                                2/25/2022, 9:01:24 PM M119
                                • npm1undefined
                                  npm1 @npm1
                                  @gloomyandy removed z driver without m574
                                  g31
                                  2/25/2022, 9:04:04 PM g31
                                  2/25/2022, 9:03:53 PM M119
                                  • npm1undefined
                                    npm1 @npm1
                                    @gloomyandy removed z driver without m574 metal touching
                                    G31
                                    2/25/2022, 9:05:35 PM m119
                                    • npm1undefined
                                      npm1 @npm1
                                      hope that helps
                                        gloomyandy @npm1
                                        @npm1 Are you still using this line for your probe definition:
                                        M558 P5 C"!^zstop" H5 F120 T6000
                                        If so with the Z driver still removed enter
                                        M558 P5 C"zstop" H5 F120 T6000
                                        in the console (or change the line in your config.g and reboot)
                                        and rerun both sets of tests.
                                        • npm1undefined
                                          npm1 @gloomyandy
                                          @gloomyandy still no changes, the only thing that change is the z probe value being 1000 instead of zero
                                          • npm1undefined
                                            npm1 @npm1
                                            @gloomyandy have I blown something on the board
