npn 5v fly rrf e3
STM
1.8k
    npm1
    my z probe isn't being activated in the reprap firmwire i.e. the z probe value isn't changing from 1000-0/0-1000 despite me putting a metalic object to the 5v npn probe.
    The probe is connected to the ztop jst connector, and the ender 5 pro is powered by the fly rrf e3 mainboard.
    m119 is showing the status as triggered,
    please help
    ; Configuration file for Fly-E3 (firmware version 3)
    ; generated by RepRapFirmware Configuration Tool v3.2.1-LPC+11 on Tue May 18 2021 11:34:22 GMT+0100 (British Summer Time)
    M550 P"Aquila" ; set printer name
    M552 S1 ; enable network
    M586 P0 S1 ; enable HTTP
    M586 P1 S0 ; disable FTP
    M586 P2 S0 ; disable Telnet
    M569 P0 S0 ; physical drive 0 goes backwards using default driver timings
    M569 P1 S0 ; physical drive 1 goes backwards using default driver timings
    M569 P2 S0 ; physical drive 2 goes backwards using default driver timings
    M569 P3 S1 ; physical drive 3 goes forwards using default driver timings
    M92 X80.00 Y80.00 Z400.00 E400.00 ; set steps per mm
    M566 X1200.00 Y1200.00 Z60.00 E360.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X540000.00 Y540000.00 Z60000.00 E360000.00 ; set maximum speeds (mm/min)
    M201 X1400.00 Y1400.00 Z60.00 E5000.00 ; set accelerations (mm/s^2)
    M906 X750 Y750 Z850 E750 I30 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X235 Y235 Z260 S0 ; set axis maxima
    M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
    M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
    M558 P5 C"!^zstop" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
    M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
    M950 H0 C"bed" T0 ; create bed heater output on bed and map it to sensor 0
    M308 S1 P"e0temp" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin e0temp
    M143 H1 S300 ; set temperature limit for heater 1 to 300C
    M106 P0 C"Part Cooling Fan" S0 H1 T45 ; set fan 0 name and value. Thermostatic control is turned on
    M106 P1 C"Hotend Fan" S0.01 H-1 ; set fan 1 name and value. Thermostatic control is turned off
    Ender 5 pro(LGXextruderddewith e3d revo rapid changer) with fly rrf e3 and a standard prusa mk3, both siting air-tight in a ikea kitchen cabinet.
      jay_s_uk
      @npm1 got any more info on the probe?
      undefined 1 Reply Last reply 25 Feb 2022, 18:24 Reply Quote 0
        npm1 @jay_s_uk
        @jay_s_uk its a npn 12mm BX probe at 5v
        undefined 1 Reply Last reply 25 Feb 2022, 18:26 Reply Quote 0
          jay_s_uk @npm1
          @npm1 said in npn 5v fly rrf e3:
          npn 12mm BX probe
          and whats one of those? part number? data sheet? how are you powering it?
          undefined 1 Reply Last reply 25 Feb 2022, 18:34 Reply Quote 0
            npm1 @jay_s_uk
            @jay_s_uk im using 5v from the bltouch connector and the original zstop connector...its from china brought through aliexpress M12 4mm DC 5V NPN NO LJ12A3-4-Z/BX-5V Inductive Proximity Sensor.
            It is a widely used component in the automatic control industry for non-contact detection, control and switching.
            When the proximity switch is close to a target object, it sends out a control signal.
            As it is a capacitive type proximity switch, its sensing object target is not limited to conductor, but also liquid and even powdery objects, like plastic, water, glass , oil, etc.
            It is widely used in machine, papermaking, light industry for limiting station, orientation considering, acceleration test ect.
            Specifications:
            3-wire polarity: NPN sensing
            Voltage: DC 5V
            Sensing distance: 4mm
            Output status: normally open
            Output current: 300mA
            Sensing objects: Conductor
            Part number: LJ12A3-4-Z/BX
            Screw length: 61mm
            Quantity: 1 Pc
            Note:
            Please allow 1-3mm error due to manual measurement. Please make sure you don't mind before you bid
            Due to the difference between different monitors, the picture may not reflect the actual color of the item. Thank you!
            Package Content:
            1pc x Inductive Switch
            undefined 1 Reply Last reply 25 Feb 2022, 18:44 Reply Quote 0
              jay_s_uk @npm1
              @npm1 what wires do you have going to where?
              undefined 1 Reply Last reply 25 Feb 2022, 18:51 Reply Quote 0
                npm1 @jay_s_uk
                @jay_s_uk I have the + wire going to the 5v connection for the bltouch, the negative going to the left of the zstop connection and the signal going to the right of the zstop connection
                  npm1 @npm1
                  @jay_s_uk the sensor lights up correctly when i put metal prong against it
                  undefined 1 Reply Last reply 25 Feb 2022, 19:53 Reply Quote 0
                    gloomyandy @npm1
                    @npm1 Please try the following...
                    1. Run M98 P"config.g" and post any output.
                    2. Run M119 and G31 in the console both with and without the probe being triggered.
                      3 Comment out the line: M574 Z1 S2 and then repeat the two tests run above.
                    3. Power off the board, remove the Z driver module, power the board on again and re-run the tests in step 2.
                    4. Post the output from all 6 of the tests.
                    undefined 2 Replies Last reply 25 Feb 2022, 20:25 Reply Quote 0
                      npm1 @gloomyandy
                      @gloomyandy
                      With M574
                      M98 P"config.g"
                      HTTP is enabled on port 80
                      FTP is disabled
                      TELNET is disabled
                      Endstops - X: not stopped, Y: at min stop, Z: not stopped, Z probe: not stopped
                      G31
                      Z probe 0: current reading 0, threshold 500, trigger height 2.500, offsets X0.0 Y0.0
                        npm1 @gloomyandy
                        @gloomyandy Without M574
                        M98 P"config.g"
                        FTP is disabled
                        TELNET is disabled
                        Endstops - X: not stopped, Y: at min stop, Z: no endstop, Z probe: not stopped
                        undefined 1 Reply Last reply 25 Feb 2022, 20:29 Reply Quote 0
                          gloomyandy @npm1
                          @npm1 Are those results with or without the probe being in a triggered state?
                          undefined 1 Reply Last reply 25 Feb 2022, 20:32 Reply Quote 0
                            npm1 @gloomyandy
                            @gloomyandy the first response is with m574 and the second response is without m574
                            undefined 1 Reply Last reply 25 Feb 2022, 20:41 Reply Quote 0
                              gloomyandy @npm1
                              @npm1 Yes but I asked you to run M119 and G31 twice for each test once without having the probe in a triggered state and then again with the probe in a triggered state (by placing something metal near it so the LED comes on). Have you run the test with the Z driver removed?
                              undefined 1 Reply Last reply 25 Feb 2022, 20:47 Reply Quote 0
                                npm1 @gloomyandy
                                @gloomyandy
                                without m574 and with metal touching the probe
                                g31
                                2/25/2022, 8:46:38 PM g31
                                2/25/2022, 8:46:16 PM M119
                                2/25/2022, 8:45:56 PM M98 P"config.g"
                                FTP is disabled
                                TELNET is disabled
                                undefined undefined 2 Replies Last reply 25 Feb 2022, 20:51 Reply Quote 0
                                  npm1 @npm1
                                  @gloomyandy with 574 and metal touching probe
                                  g31
                                  2/25/2022, 8:50:23 PM g31
                                  2/25/2022, 8:50:05 PM m119
                                    gloomyandy @npm1
                                    @npm1 and the results with the Z driver removed from the socket?
                                    undefined 1 Reply Last reply 25 Feb 2022, 21:00 Reply Quote 0
                                      npm1 @gloomyandy
                                      @gloomyandy
                                      removed z driver with m574
                                      g31
                                      2/25/2022, 8:59:47 PM M119
                                      2/25/2022, 8:59:44 PM M119
                                      2/25/2022, 8:59:33 PM M98 P"config.g"
                                      FTP is disabled
                                      TELNET is disabled
                                      undefined 1 Reply Last reply 25 Feb 2022, 21:02 Reply Quote 0
                                        npm1 @npm1
                                        @gloomyandy removed z driver with m574 metal touching
                                        g31
                                        2/25/2022, 9:01:46 PM g31
                                        2/25/2022, 9:01:24 PM M119
                                        undefined undefined 2 Replies Last reply 25 Feb 2022, 21:04 Reply Quote 0
                                          npm1 @npm1
                                          @gloomyandy removed z driver without m574
                                          g31
                                          2/25/2022, 9:04:04 PM g31
                                          2/25/2022, 9:03:53 PM M119
                                          undefined 1 Reply Last reply 25 Feb 2022, 21:06 Reply Quote 0
                                          9 out of 35
