    Extruder motor not working correctly after update
    964
    • GBusy24undefined
      GBusy24 @Phaedrux
      @phaedrux With filament loaded.Increase in current makes it move and extrude somewhat. DWC reports being at print temp. Yes, current that high concerns me. Really want to resolve this. I have a big project I'm ready to start
      No such thing as spare time. No such thing as free time No such thing as down time. All you got is lifetime. Go!
        deckingman @GBusy24
        @gbusy24 said in Extruder motor not working correctly after update:
        As a general rule, needing to set high motor current to get an extruder to work is a sign that something else is amiss. That "something else" is a restriction to flow which might be caused a partial blockage or attempting to extrude at too low a temperature. Are you sure that the temperature reading is accurate? Have you tried raising the hot end temperature and if so what happens? Have you checked for any partial blockages, either in the nozzle or in the heat break area?
        GBusy24undefined 1 Reply Last reply Reply Quote 0
        • GBusy24undefined
          GBusy24 @deckingman
          @deckingman Along with the update to 3.3, I also refurbished the hotend. New heater block, new thermistor, new heat break, new heat sink and nozzle also. New everything after 6 years of heavy use. I'm using the same filament I used for almost 4 yrs. Printing at same temp I always have with this filament. The extruder motor is brand new too. E3d 0.9 resolution pancake stepper.
          OwenDundefined deckingmanundefined 2 Replies Last reply Reply Quote 0
          • OwenDundefined
            OwenD @GBusy24
            Were you running the same motor before?
            I am using an E3D pancake motor on my titan aero and found I needed fairly high currents to get the little motor to work reliably at higher feed rates.
            I have no problems because the water cooled block also keeps the motor very cool.
              deckingman @GBusy24
              @gbusy24 Have you considered the possibility that the reason your extruder motor doesn't work after updating the firmware might be something to do with the miriad of other changes you made at the same time (including changing the motor itself), rather than a firmware issue?
              GBusy24undefined 2 Replies Last reply Reply Quote 0
              • GBusy24undefined
                GBusy24 @deckingman
                @deckingman Yes, but I've unfortunately been at all this for quite some time B4 I ever dreamed of posting my issues on the forum. That's just how I am. I go to great lengths to work things out on my own first. Therefor, I now cry out. LOL
                • GBusy24undefined
                  GBusy24 @deckingman
                  @deckingman and OwenD, I threw caution to the wind and upped the current to 1200ma and things are working as I want now, that's 86%. Lotta current, but if it works......................
                  • GBusy24undefined
                    GBusy24 @OwenD
                    @owend What currents are you running?
                    • OwenDundefined
                      OwenD @GBusy24
                      @gbusy24
                      I'm actually running 1400mA on that motor.
                      I started at about 1100 and as the motor was stone cold when running, because of the liquid cooling, I eventually increased it up to the maximum rated current.
                      It still runs cold and I've had no issues although I'm not a high volume user.
                      I can't guarantee the same results for you, especially if you don't have a liquid cooled extruder system.
                        deckingman @GBusy24
                        @gbusy24 What diameter nozzle do you use? If it's 0.4mm consider using 0.5mm. You will arguably lose 0.1mm in resolution if you print small, highly detailed parts, but a 0.5mm nozzle has circa 50% more area than a 0.4mm nozzle and you'll find that you can extrude reliably using much less extruder pressure (motor torque).
                        • GBusy24undefined
                          GBusy24 @OwenD
                          @owend Thanks for your reply.
                          • GBusy24undefined
                            GBusy24 @deckingman
                            @deckingman I may give that a try. Thanks
                              dc42 administrators @GBusy24
                              @gbusy24 if you run:
                              M98 P"config.g"
                              are any errors reported?
                              • GBusy24undefined
                                GBusy24 @dc42
                                @dc42 Hi, I just saw your message and ran the command. E-thing seems good to go. Here's the response: "M98 P"config.g"
                                HTTP is enabled on port 80
                                FTP is disabled
                                TELNET is disabled
                                I've come to terms that this smaller stepper needs higher current than normal sized steppers. I'm okay with that. I've used this motor for years on my setup and haven't had any problems. I am going to show it a lil' love tho with a nice heatsink that arrives tomorrow
