    Read Output pin state
    Using Duet Controllers
    8
    44
    2.6k
    • alankilianundefined
      alankilian @wayneosdias
      @wayneosdias
      I'm thrilled that you are taking the time to work Duet into the OpenPNP world.
      Are you sure you turned compression back on?
      Because I thought it compressed the spaces out also but it doesn't seem to be doing that.
      wayneosdiasundefined 1 Reply Last reply Reply Quote 0
      • wayneosdiasundefined
        wayneosdias @alankilian
        @alankilian
        Yes its working with compression. Here is a snippet of my machine.xml with the setting emboldened. The full .xml file is several thousand lines long;
        driver class="org.openpnp.machine.reference.driver.GcodeAsyncDriver" id="DRV16cc6c1da8ebf1f8" name="GcodeAsyncDriver" motion-control-type="Simulated3rdOrderControl" communications="serial" connection-keep-alive="false" sync-initial-location="false" units="Millimeters" max-feed-rate="100000" backlash-offset-x="-1.0" backlash-offset-y="-1.0" backlash-offset-z="0.0" backlash-offset-r="0.0" non-squareness-factor="0.0" backlash-feed-rate-factor="0.1" timeout-milliseconds="5000" connect-wait-time-milliseconds="3000" visual-homing-enabled="true" backslash-escaped-characters-enabled="false" remove-comments="false" compress-gcode="true" logging-gcode="true" supporting-pre-move="false" using-letter-variables="true" infinity-timeout-milliseconds="60000" writer-polling-interval="100" writer-queue-timeout="60000" max-commands-queued="1000" confirmation-flow-control="false" reported-location-confirmation="true" interpolation-max-steps="32" interpolation-jerk-steps="4" interpolation-time-step="0.001" interpolation-min-step="16"
        Config
        Console
        Thanks. Duet is working very well w Openpnp thus far. I started a Duet Wiki page under Openpnp. All add this info for others as well. RRF config via SD is so much easier to get Openpnp configured correctly vs Smoothieware that needs you to rebuild and flash with each config change.
        There is a lot of hesitancy to move to Openpnp from propriety PnP controllers because generating the machine.xml (Openpnp config) is long and complex. The Duet/RRF make scratch building the machine.xml much more straight forward.
        Again thanks
          @wayneosdias said in Read Output pin state:
          I'm sure you know what you're doing, and I'm also SURE I DO NOT, but this doesn't match your graphics, so maybe just check to be sure?
          I do know I've wasted so much time when I update something and forget to type Make before testing, or I edited and didn't save a change, so I'm an idiot.
            @alankilian
            Sorry, yes you're correct again 🙂
            The xml doesn't update until File>Save>Configuration. Meaning the GUI changes don't automatically update the xml and I blindly copied it without saving first.
            So just for clarity I Saved the GUI settings, closed Openpnp, restarted Openpnp and now;
            xml
            driver class="org.openpnp.machine.reference.driver.GcodeAsyncDriver" id="DRV16cc6c1da8ebf1f8" name="GcodeAsyncDriver" motion-control-type="Simulated3rdOrderControl" communications="serial" connection-keep-alive="false" sync-initial-location="false" units="Millimeters" max-feed-rate="100000" backlash-offset-x="-1.0" backlash-offset-y="-1.0" backlash-offset-z="0.0" backlash-offset-r="0.0" non-squareness-factor="0.0" backlash-feed-rate-factor="0.1" timeout-milliseconds="5000" connect-wait-time-milliseconds="3000" visual-homing-enabled="true" backslash-escaped-characters-enabled="true" remove-comments="false" compress-gcode="true" logging-gcode="true" supporting-pre-move="false" using-letter-variables="true" infinity-timeout-milliseconds="60000" writer-polling-interval="100" writer-queue-timeout="60000" max-commands-queued="1000" confirmation-flow-control="false" reported-location-confirmation="true" interpolation-max-steps="32" interpolation-jerk-steps="4" interpolation-time-step="0.001" interpolation-min-step="16"
            GUI
            Its all working 🙂
              wayneosdias @wayneosdias
              @dc42 @alankilian @gloomyandy @OwenD @SIam @Stephen6309
              Thanks again.
              Now that I have M118 working within Openpnp with GCode compression via the Backslash option I have changed my other analog sensor queries;
              Initially using M308 was pretty verbose with 138 total char count
              >> M308S0
              << Sensor 0 (Pressure_1) type Linear analog using pin temp0, reading 1996.0, last error: success, unfiltered, range 0.0 to 4095.0
              Vs now using M118 a total char count of 50
              >> M118P1S{sensors.analog[0].lastReading}
              //actual Opnepnp syntax w compression and back slash
              // M118 P1 S{sensors\u002Eanalog[0]\u002ElastReading}
              << 1996.0
              Thanks Wayne
              OwenDundefined 1 Reply Last reply Reply Quote 0
              • OwenDundefined
                OwenD @wayneosdias
                @wayneosdias
                Glad it's all working.
                Be interesting to see a video of it in operation
                  wayneosdias @OwenD
                  @owend
                  Will do, I need to get the mechanicals back together first. 🙂
                  If you dont know what this is, it's the aftermath drag pin machine crash. The pin with the bent tip slides up and down within the blue coil of the selenoid with the bent frame.
                  I hope to get fixed tonight and put some of my new and improved RRF commands to work 🙂
                  Thanks again.
                    wayneosdias
                    Heres a quick vid of the process.
                    pick_2edOjyQd.mp4
                      droftarts administrators @wayneosdias
                      @wayneosdias Hi, is it okay to add a link to your wiki page on our wiki page here? https://docs.duet3d.com/User_manual/Machine_configuration/Configuration_OpenPnP
                      wayneosdiasundefined 2 Replies Last reply Reply Quote 0
                        wayneosdias @droftarts
                        @droftarts
                        Yes absolutely. I do need to make some tweeks to the wiki as I have been making changes but haven't been updating the wiki. I'll spend some time tonight to tiding things up a bit.
                        I don't want to spread any bad info so if you see anything that is not best practice please let me know.
                        Lastly, just to put the original topic to bed, M118 is the best method for retrieving input/output/analog values from Duet using GCode correct? Best meaning timely and succinct.
                          @wayneosdias Great, thanks.
                          For sending messages to USB, I guess M118 is going to be the most useful; I actually can't think of any other way to do it. If you wanted to send to DWC or PanelDue (but I don't think you do), use M291 instead.
                            @droftarts
                            Ok good to know, for Openpnp its USB/serial or tcp.
                              @droftarts
                              Ive updated the wiki, it is current. Feel free to post the link
                              https://github.com/openpnp/openpnp/wiki/Duet3D-Openpnp-Example
                                @droftarts said in Read Output pin state:
                                You can also use 'echo' commands to retrieve information.
