    firmware retraction
    Using Duet Controllers
    823
    • bastienundefined
      bastien
      hello, I wanted to test the firmware retraction but I have a problem, with the same settings as my slicer, my filament moves back with each retraction to the point where it no longer feeds the tool, M207 S5 F3000 Z0.1
      Circuit: Duet 2 WiFi (2WiFi)
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta7+7 (2022-01-14)
      Duet WiFi Server Version: 1.23
        Are you still using wipe or coast in the slicer?
        Can you post your config.g?
        Are you sure you have firmware retraction enabled in the slicer?
        @bastien said in firmware retraction:
        3.4.0beta7+7
        You may want to update to 3.4 RC2
        • bastienundefined
          bastien
          I enabled firmware retraction in cura
          after M207
          Tool 0 retract/reprime: length 5.00/5.00mm, speed 50.0/50.0mm/sec, Z hop 0.10mm
            droftarts administrators
            @bastien sounds like you might be using absolute rather than relative extrusion in the slicer.
            bastienundefined 1 Reply Last reply Reply Quote 0
            • bastienundefined
              bastien @droftarts
              @droftarts I had thought about it, but I am in relative extrusion, and I have M83 at the beginning of my config.g, when the retraction is managed by the slicer, everything is fine, but not the firmware
                deckingman @bastien
                @bastien Can you make the gcode file that you are trying to print available. Or at least a section of it which shows a few retract/unretract cycles. It might also help if you post your complete config.g file as well as your slicer start code.
                • bastienundefined
                  bastien @deckingman
                  @deckingman
                  my config.g
                  G90                                            ; send absolute coordinates...
                  M83                                            ; ...but relative extruder moves
                  M550 P"Predator"                               ; set printer name
                  M665 L440.000 R221 B185.0 H456                       ; Set delta radius, diagonal rod length, printable radius and homed height M665 L415.000 R222.5 B185.0 H486  ; rod alu
                  M666 X0 Y0 Z0 A0.00 B0.00                                  ; put your endstop adjustments here, or let auto calibration find them
                  M552 S1                                        ; enable network
                  M586 P0 S1                                     ; enable HTTP
                  M586 P1 S1                                     ; disable FTP
                  M586 P2 S0                                     ; disable Telnet
                  M569 P0 S0                                     ; physical drive 0 goes forwards
                  M569 P1 S0                                     ; physical drive 1 goes forwards
                  M569 P2 S1                                     ; physical drive 2 goes forwards
                  M569 P3 S1                                     ; physical drive 3 goes forwards
                  M584 X0 Y1 Z2 E3                               ; set drive mapping
                  M350 X16 Y16 Z16 E16 I1                        ; configure microstepping with interpolation
                  M92 X160 Y160 Z160 E392.5 ; set steps per mm
                  M566 X1000 Y1000 Z1000 E1000       ; set maximum instantaneous speed changes (mm/min)
                  M203 X12000 Y12000 Z12000 E1200    ; set maximum speeds (mm/min)
                  M201 X3000 Y3000 Z3000 E3000       ; set accelerations (mm/s^2)
                  M906 X1000 Y1000 Z1000 E1000 I30                ; set motor currents (mA) and motor idle factor in per cent
                  M84 S30                                        ; Set idle timeout
                  M208 Z0 S1                                     ; set minimum Z
                  M574 X2 S1 P"xstop"                            ; configure active-high endstop for high end on X via pin xstop
                  M574 Y2 S1 P"ystop"                            ; configure active-high endstop for high end on Y via pin ystop
                  M574 Z2 S1 P"zstop"                            ; configure active-high endstop for high end on Z via pin zstop
                  M558 P5 C"e0stop" H8 F120 T6000            ; set Z probe type to switch and the dive height + speeds
                  M558 H10                                       ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
                  G31 P500 X0 Y0 Z14.95                        ; set Z probe trigger value, offset and trigger height
                  M557 R175 S20                               				; Define mesh grid
                  G29 S1
                  M308 S0 P"bedtemp" Y"thermistor" T100000 B4300 ; configure sensor 0 as thermistor on pin bedtemp
                  M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
                  M307 H0 B1 S1.00                               ; enable bang-bang mode for the bed heater and set PWM limit
                  M140 H0                                        ; map heated bed to heater 0
                  M143 H0 S80                                    ; set temperature limit for heater 0 to 80C
                  M308 S1 P"e0temp" Y"thermistor" T100000 B4300  ; configure sensor 1 as thermistor on pin e0temp
                  M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
                  M307 H1 B0 S1.00                               ; disable bang-bang mode for heater  and set PWM limit
                  M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
                  M106 P0 S0 H-1                                 ; set fan 0 value. Thermostatic control is turned off
                  M950 F1 C"fan1" Q500                           ; create fan 1 on pin fan1 and set its frequency
                  M106 P1 S1 H1 T45                              ; set fan 1 value. Thermostatic control is turned on
                  M563 P0 D0 H1 F0                               ; define tool 0
                  G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
                  G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
                  ; Retraction
                  ;M207 S4.0 F5000 R-0.025 T2500 Z0.5
                  M207 S6.5 F3700 Z0.1
                  ;M572 D0 S0.1												; Pressure Advance
                  ;M591 D0 P2 C"e1stop" S0											; Activate filament sensor
                  M404 N1.75 													; Set for print monitor
                  ;M592 D0 A0.07772 B-0.00029 		; Nonlinear extrusion. Set parameters for extruder drive 0
                  M575 P1 S1 B57600                              ; enable support for PanelDue
                  M501
                    Could you show photo examples of what results you get with both?
                    • bbergerundefined
                      bberger
                      @phaedrux said in firmware retraction:
                      3.4.0beta7+7
                      this. the 3.4 betas are known (and confirmed) to have a retraction issue..
                      • bastienundefined
                        bastien @bberger
                        @bberger said in firmware retraction:
                        it's ok after update thanks
                        • Phaedruxundefined Phaedrux has marked this topic as solved
