    BtnCmd-DWC Plugin - Customise DWC - v01.03.08 01-03-25
    Plugins for DWC and DSF
    27
    244
    38.6k
    • Stoutundefined
      Stout @jay_s_uk
      @jay_s_uk said in BtnCmd-DWC Plugin-Custom Layouts & Buttons - v0.10.03 28-12-21:
      @stout are you sure you have 3.3.0 installed? can you show a screenshot of the general settings page?
      I have full control of what I've got .-) I use two different systems, both with latest official releases.Both gives the same result as shown previous.
      First I used both systems with black background but it happened more than once that I shut off the wrong system during print, therefore one white and one black. But I don't really like the white backround and would like to change to blue or whatever. Don't find any CCS in /www for it. Is it a .js-file?
      • Stoutundefined
        Stout @MintyTrebor
        @mintytrebor
        Yes I did. Downloaded it from GitHub today.
        Pity, then the plug in don't change the background colour?
        MintyTreborundefined 1 Reply Last reply Reply Quote 0
        • MintyTreborundefined
          MintyTrebor @Stout
          @stout said in BtnCmd-DWC Plugin-Custom Layouts & Buttons - v0.10.03 28-12-21:
          Pity, then the plug in don't change the background colour? -
          No. It only gives you colour control over the buttons and panels you create yourself. You can also add standard DWC panels, and re-size them, but not change the colour of them
          Can you tell me the name of the zip file you uploaded to DWC please.
          And if you want to, please try installing this version as a check.
          NodeDSF - Native Node-Red integration with Duet boards.
          BtnCmd - Customise DWC with user defined buttons/layouts/panels (DWC Plugin)
          ReleaseMgr - Duet update info inside DWC.
          Repo
          Stoutundefined 1 Reply Last reply Reply Quote 0
          • Stoutundefined
            Stout @MintyTrebor
            @mintytrebor
            I'll give the link a try. Thanks.
            Here's a screenshot
              MintyTrebor @Stout
              @stout That version in the picture is version 0.10.03, I mentioned earlier you need 0.9.06.
              The filenames are BtnCmd_[DWC Ver]_[BtnCmd Ver].zip
              Repo
              • Stoutundefined
                Stout @MintyTrebor
                @mintytrebor
                You asked for the zip file I uploaded and gave you a snapshot of it!
                I installed BtnCmd_DWC3.3_Beta.0.9.04.zip without any problem. I then checked the SD, deleted the just installed files and copied 0.10.03 manually. when I started it, I got this:
                So I copied over the css files from 0.9.0.4 but let the 0.10.03 on the SD-card and it's starting up again though the old version.
                I'll play around with it as I am going to use one more Duet 3 for a CNC with an iPad.
                  jay_s_uk @Stout
                  @stout 0.10.03 isn't supported in 3.3.0. you either have to install the last supported version (0.9.06) or upgrade to 3.4rc1 so you can use 0.10.03
                    MintyTrebor
                    I have published Beta 0.10.06 for DWC 3.4RC1
                    Changes:
                    Fixed rendering issue input panels.
                    Updates to how BtnCmd works with new DWC features.
                    Added Auto Backup feature - please see wiki for more info.
                    Repo
                      MintyTrebor @MintyTrebor
                      Published 0.10.07
                      Changes :
                      • Various Bug Fixes
                      • New Input Panel Options
                      Input panels for global variables can now be configured as sliders, switches, selection lists, or input fields:
                      Please see this wiki page for more details
                      Repo
                      • moth4017undefined
                        moth4017 @MintyTrebor
                        @mintytrebor
                        Hi is there away to take data via i2c or serial to display in a "text Box"? or an option to Poll data/request via serial ?
                          MintyTrebor @moth4017
                          @moth4017 The plugin can display data from the Object Model, it does not have access to anything else.
                          Repo
                            MintyTrebor
                            I have published 0.10.08.
                            Change Log:
                            Added Console Panel
                            Notes:
                            This will be the last version of the plugin to include the events functionality. I am depreciating this feature as the introduction of 'tab sleeping' by many of the main browsers causes issues for this feature, plus the functionality no longer aligns with the core of BtnCmd.
                            Repo
                            • chimaeraghundefined chimaeragh referenced this topic
                            • mrwulffundefined
                              mrwulff
                              Awesome plugin!
                              Trying to make a little organized flow and ran into a sizing bug with custom panels.
                              I made a custom panel with a object model value and resized it. I save the custom panel but it does not save. Looking at the backup json file confirms this, and if I manually edit, it will be displayed properly.
                              Thanks
                              MintyTreborundefined 3 Replies Last reply Reply Quote 0
                                MintyTrebor @mrwulff
                                @mrwulff I cannot replicate this behaviour.
                                I tell a lie - I have just replicated it - let me look into it.
                                Repo
                                  @mrwulff I found the issue. I will push an update out later once I have run some quick sanity checks.
                                  Repo
                                    @mrwulff Published v0.10.09
                                    Changes:
                                    • fixed resizing issue with custom panels
                                    • removed Event feature
                                    As previously noted in the last release - this version depreciates the Event system from BtnCmd. I have depreciated this feature as the introduction of 'tab sleeping' by many of the main browsers causes issues for this feature, plus the functionality no longer aligns with the core of BtnCmd.
                                    Repo
                                      Published Beta 0.10.10 for DWC 3.4
                                      Changes:
                                      • Updated Alt Web Cam panel to align with recent DWC webcam changes
                                      • Removed >= 5000 ms update interval requirement from Alt Web Cam Panel settings
                                      • Added CNC Panels :
                                        • CNC Info Panel
                                        • CNC Movement Panel
                                        • CNC Spindle Speed Panel
                                      • Added CNC detection - Available Panels will now be filtered based on FFF/CNC operating mode
                                      Repo
                                      o_lampeundefined 1 Reply Last reply Reply Quote 1
                                      • o_lampeundefined
                                        o_lampe @MintyTrebor
                                        @mintytrebor said in BtnCmd-DWC Plugin-Custom Layouts & Buttons - v0.10.10 08-06-22:
                                        I want to try your plugin for a CNC/Laser combo machine I'm currently building. Will there be a difference in panel availability, if I switch back_and_forth from laser- to CNC-mode too?
                                        Or is there a combo mode possible that would show laser panels and CNC at the same time?
                                          MintyTrebor @o_lampe
                                          @o_lampe I released an update 2 mins ago to allow the Panels in both Laser & CNC mode 😊
                                          https://github.com/MintyTrebor/BtnCmd/releases
                                          Repo
                                          • chrishammundefined chrishamm referenced this topic
                                          • Adamfilipundefined
                                            Adamfilip
                                            Is there someplace to download different configurations of entire layouts of panels and buttons.
                                            or a way to load user created custom panels themselves.
                                            would be great if we could share various configurations to get us 90% of the way there.
                                            MintyTreborundefined 2 Replies Last reply Reply Quote 2
