    DUEX 5 V0.8 TO DUEX 5 V0.11
    283
    23.7k
      droftarts administrators @paolozampini1973
      @paolozampini1973 In DueX5 mode, the Duet 2 will be trying to communicate with the drivers, and the external drivers are picking up the signal. That is why you need to disable them by using DueX2 mode. As I said before, move the stepper motor on DueX driver 9 to the Duet 2 board. Why can't you do this?
      For the other issues, please please please please post your config.g and M122.
      paolozampini1973undefined 3 Replies Last reply Reply Quote 1
      • paolozampini1973undefined
        paolozampini1973 @paolozampini1973
        @droftarts I have mounted the 74hc 14 but the problem has worsened on the stability and however it goes Iasi they go in motion without any command I repeat again I did not have this problem before mounting the V 011 now I have also mounted the 74hc 14 okay I have it done But it is even worse because it loses much more so after making all these changes I have made the problem worse I have not improved the problem what I say guys I agree with you but if I give him 5 times he still loses me the more I pass but I immediately lose any movement so the facts say this is not goodDM860H V3.3 act英文 (1).pdf
        there is what I try to say is that by putting even more electronics even more modern even better but I have more problems because thanks
          paolozampini1973 @droftarts
          @droftarts Yes I can also teach them abitare 3 nema 17 I throw them it is not a problem but it is not normal that before with the V 08 I did not have this problem you tell me that I owe them if living is not a problem I just detach them I disassemble them from the printer but so I was still another problem So it means that then three other motors I as command and then because before I did not have all these problems and now I have this problem with the v08 I did not have these problems understand that I want to tell you please can you explain it to me. Thanks
            @droftarts Please excuse me but what I want to understand if before I did not have these problems because now I have these problems with this new version I should not have any kind of problem and instead I have 4 new serious problems of the other Please explain me
            That is, for me all this is a contradiction because I should not have had these problems with the V 08 I did not have these problems I had only a small loss of pace please please please try to explain to me why you tell me to go IN MODE DUEX2 Okay but why do I have to disconnect three engines that then I don't know how to drive them anymore and therefore I still have another problem I want to understand Excuse me for my very bad English
              @droftarts I want to ask a question I do not know if I have explained myself you have understood that for me the problem has worsened a lot to install the V 0.11 for me it was much worse I have a lot of problems so many problems that I did not have before please answer me if I have been clear Please please
              tekkydaveundefined 1 Reply Last reply Reply Quote 0
              • tekkydaveundefined
                tekkydave @paolozampini1973
                @paolozampini1973 Yes you are correct. But now you have two choices:
                1. Accept that your new engine is crap and go back to the old one.
                2. Take some advice on how to work round the issues you have and fix them to get your car working again.
                You seem very reluctant to take option 2. If you read back over the advice in this thread all the answers are there. If you supply us with the information we have asked for - the output of the M122 command and your config.g we can help even more.
                ~ tekkydave ~
                D-Bot: 300x300mm | Duet WiFi + Duex2 | 3 independent z motors | X,Y & Z linear rails | E3D Titan Aero + V6 | Precision Piezo z-probe
                FreeCAD, PrusaSlicer
                paolozampini1973undefined 1 Reply Last reply Reply Quote 0
                  @paolozampini1973 said in DUEX 5 V0.8 TO DUEX 5 V0.11:
                  Yes very clear. We all understand it has got worse for you. Move on from that and give us the information we need to help you.
                  ~ tekkydave ~
                    paolozampini1973 @tekkydave
                    @tekkydave 30273fb4-d2dc-4112-a692-7fbb74328c0d-image.png 73aa5151-9de2-476e-bd78-7fe6c85f9119-image.png 47aabfb4-ee75-423c-b892-66cc8e993c1b-image.png c6c27765-945d-4e05-93bc-fbe65fe5951e-image.png
                      @paolozampini1973 You know you can just copy and paste text from the Console window?
                        @droftarts 21/3/2022, 14:42:59 M122
                        RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later + DueX2
                        Board ID: 0JD0M-9P6M2-NW4SN-6J1DD-3SJ6K-KAURK
                        Used output buffers: 3 of 24 (24 max)
                        Static ram: 23876
                        Dynamic ram: 77448 of which 0 recycled
                        Never used RAM 13092, free system stack 184 words
                        Tasks: NETWORK(ready,15.8%,233) HEAT(delaying,0.0%,330) Move(notifyWait,0.1%,319) DUEX(notifyWait,0.0%,24) MAIN(running,81.5%,413) IDLE(ready,2.6%,29), total 100.0%
                        Owned mutexes: WiFi(NETWORK)
                        Last reset 00:00:29 ago, cause: power up
                        Last software reset at 2022-03-20 12:12, reason: User, GCodes spinning, available RAM 13092, slot 0
                        Error status: 0x00
                        Aux0 errors 0,0,0
                        Step timer max interval 0
                        MCU temperature: min 24.0, current 27.5, max 27.7
                        Supply voltage: min 25.6, current 25.7, max 25.8, under voltage events: 0, over voltage events: 0, power good: yes
                        Driver 0: position 0, standstill, SG min/max not available
                        Driver 1: position 0, standstill, SG min/max not available
                        Driver 2: position 0, standstill, SG min/max not available
                        Driver 3: position 0, standstill, SG min/max not available
                        Driver 4: position 0, standstill, SG min/max not available
                        Driver 5: position 0, standstill, SG min/max not available
                        Driver 6: position 0, standstill, SG min/max not available
                        Driver 7: position 0
                        Driver 8: position 0
                        Driver 9: position 0
                        Driver 10: position 0
                        Driver 11: position 0
                        Date/time: 2022-03-21 14:42:57
                        Cache data hit count 1127564131
                        Slowest loop: 10.85ms; fastest: 0.18ms
                        === Storage ===
                        Free file entries: 10
                        SD card longest read time 1.0ms, write time 0.0ms, max retries 0
                        === MainDDARing ===
                        === AuxDDARing ===
                        Heater 1 is on, I-accum = 0.0
                        Segments left: 0
                        Movement lock held by null
                        HTTP is idle in state(s) 0
                        Telnet is idle in state(s) 0
                        File is idle in state(s) 0
                        USB is idle in state(s) 0
                        Aux is idle in state(s) 0
                        Trigger is idle in state(s) 0
                        Queue is idle in state(s) 0
                        LCD is idle in state(s) 0
                        Daemon is idle in state(s) 0
                        Code queue is empty.
                        === Filament sensors ===
                        Extruder 0 sensor: no filament
                        Extruder 1 sensor: ok
                        Extruder 2 sensor: no filament
                        Extruder 3 sensor: ok
                        === DueX ===
                        Read count 1, 2.04 reads/min
                        === Network ===
                        Slowest loop: 41.04ms; fastest: 0.00ms
                        HTTP sessions: 1 of 8
                        • WiFi -
                          Network state is active
                          WiFi firmware version 1.26
                          WiFi MAC address 40:f5:20:0d:6b:49
                          WiFi Vcc 3.37, reset reason Turned on by main processor
                          WiFi flash size 4194304, free heap 23760
                          WiFi IP address 192.168.1.5
                          WiFi signal strength -64dBm, mode 802.11n, reconnections 0, sleep mode modem
                          Clock register 00002002
                          21/3/2022, 14:42:46 Connected to 192.168.1.5
                          @paolozampini1973 Great! Now config.g.
                          paolozampini1973undefined 3 Replies Last reply Reply Quote 0
                            @droftarts config (17).g
                              @droftarts I am sending you a photo to make you understand the axes are made up entirely with sfU 1204 and 15 mm linear guides
                                @paolozampini1973 There are a lot of errors in you config.g. Just to start...
                                M569 P0 S0 R-1 ;T2.5:2.5:6:5                       ; X    physical drive 0 goes forwards
                                M569 P1 S1 R-1 ;T2.5:2.5:6:5                       ; Y    physical drive 1 goes forwards
                                M569 P2 S1 R1 T5:5:5:5                             ; Z    physical drive 2 goes forwards
                                M569 P3 S0                                         ; E0   physical drive 3 goes forwards
                                M569 P4 S0                                         ; E1   physical drive 4 goes forwards
                                M569 P5 S0                                         ; E2   physical drive 5 goes forwards
                                M569 P6 S0                                         ; E3   physical drive 6 goes forwards
                                M569 P7 S0 R1 T2:2:2:5                         ; E4 X physical drive 7 goes forwards
                                M569 P8 S1 R1 T2:2:2:5                         ; E5 Y physical drive 8 goes forwards
                                M569 P9 S1 R1 T5:5:5:5                             ; E6 Z physical drive 9 goes forwards
                                M584 X7 Y8 Z2:9 E3:4:5:6:7:8:9 S0                  ; set drive mapping
                                Don't set timings for internal TMC drivers. (M569 P2 S1 R1 T5:5:5:5)
                                Your timings for the external drivers are very short.
                                Your M584 should not have the X, Y and Z2 drivers mapped to E. S0 is not needed. Change to:
                                For M350, M92, M566, M203, M201 and M906 commands, make sure E has 4 parameters, eg
                                M350 X16 Y16 Z16 E16:16:16:16 I1
                                  @droftarts what idea did you get what you think?
                                    @droftarts Then send me the correct file as you think you are right and I will load it and do the tests you think that for this I lose the steps?
                                    at this point what do I do I reassemble the v08 or I leave the V 011 I am willing to do any test Thank you please fill in the config file for me and I will load it exactly as you give it to me and I will let you know
                                    droftartsundefined 2 Replies Last reply Reply Quote 0
                                      @paolozampini1973 What exact thermistors are you using? You have set the default, which will not be correct, and probably why temperature is incorrect.
                                      M308 S0 P"bedtemp" Y"thermistor" T100000 B4138
                                      And you need to move Z2 from driver 9 on DueX to driver 0 or 1 on Duet 2. You DueX is being recognised as a DueX2, so probably driver 9 is not working. If it is using an external driver, don't do that; drives on a shared axis need to be identical.
                                      paolozampini1973undefined 2 Replies Last reply Reply Quote 0
                                        @droftarts Yes I set it to DUEX2 because the axes moved when I turned on the electronics Now I can't on DUEX5 Thanks for the dictation problems but for now it is more important to solve the problem of pitch loss and axis movement
                                          @droftarts Yes I know that the engines must be identical and are identical
                                            It will have to be later, I have other things I must do.
                                            I'd keep the V011 in for now.
                                            Please show how you have wired the 74HC level shifters. Wiring diagram and/or photo.
