    DUEX 5 V0.8 TO DUEX 5 V0.11
    283
    23.7k
    • tekkydaveundefined
      tekkydave @paolozampini1973
      @paolozampini1973 said in DUEX 5 V0.8 TO DUEX 5 V0.11:
      @droftarts I want to ask a question I do not know if I have explained myself you have understood that for me the problem has worsened a lot to install the V 0.11 for me it was much worse I have a lot of problems so many problems that I did not have before please answer me if I have been clear Please please
      Yes very clear. We all understand it has got worse for you. Move on from that and give us the information we need to help you.
      ~ tekkydave ~
      D-Bot: 300x300mm | Duet WiFi + Duex2 | 3 independent z motors | X,Y & Z linear rails | E3D Titan Aero + V6 | Precision Piezo z-probe
      FreeCAD, PrusaSlicer
      • paolozampini1973undefined
        paolozampini1973 @tekkydave
        @tekkydave 30273fb4-d2dc-4112-a692-7fbb74328c0d-image.png 73aa5151-9de2-476e-bd78-7fe6c85f9119-image.png 47aabfb4-ee75-423c-b892-66cc8e993c1b-image.png c6c27765-945d-4e05-93bc-fbe65fe5951e-image.png
          droftarts administrators @paolozampini1973
          @paolozampini1973 You know you can just copy and paste text from the Console window?
          paolozampini1973undefined 1 Reply Last reply Reply Quote 0
            paolozampini1973 @droftarts
            @droftarts 21/3/2022, 14:42:59 M122
            RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later + DueX2
            Board ID: 0JD0M-9P6M2-NW4SN-6J1DD-3SJ6K-KAURK
            Used output buffers: 3 of 24 (24 max)
            Static ram: 23876
            Dynamic ram: 77448 of which 0 recycled
            Never used RAM 13092, free system stack 184 words
            Tasks: NETWORK(ready,15.8%,233) HEAT(delaying,0.0%,330) Move(notifyWait,0.1%,319) DUEX(notifyWait,0.0%,24) MAIN(running,81.5%,413) IDLE(ready,2.6%,29), total 100.0%
            Owned mutexes: WiFi(NETWORK)
            Last reset 00:00:29 ago, cause: power up
            Last software reset at 2022-03-20 12:12, reason: User, GCodes spinning, available RAM 13092, slot 0
            Error status: 0x00
            Aux0 errors 0,0,0
            Step timer max interval 0
            MCU temperature: min 24.0, current 27.5, max 27.7
            Supply voltage: min 25.6, current 25.7, max 25.8, under voltage events: 0, over voltage events: 0, power good: yes
            Driver 0: position 0, standstill, SG min/max not available
            Driver 1: position 0, standstill, SG min/max not available
            Driver 2: position 0, standstill, SG min/max not available
            Driver 3: position 0, standstill, SG min/max not available
            Driver 4: position 0, standstill, SG min/max not available
            Driver 5: position 0, standstill, SG min/max not available
            Driver 6: position 0, standstill, SG min/max not available
            Driver 7: position 0
            Driver 8: position 0
            Driver 9: position 0
            Driver 10: position 0
            Driver 11: position 0
            Date/time: 2022-03-21 14:42:57
            Cache data hit count 1127564131
            Slowest loop: 10.85ms; fastest: 0.18ms
            === Storage ===
            Free file entries: 10
            SD card longest read time 1.0ms, write time 0.0ms, max retries 0
            === MainDDARing ===
            === AuxDDARing ===
            Heater 1 is on, I-accum = 0.0
            Segments left: 0
            Movement lock held by null
            HTTP is idle in state(s) 0
            Telnet is idle in state(s) 0
            File is idle in state(s) 0
            USB is idle in state(s) 0
            Aux is idle in state(s) 0
            Trigger is idle in state(s) 0
            Queue is idle in state(s) 0
            LCD is idle in state(s) 0
            Daemon is idle in state(s) 0
            Code queue is empty.
            === Filament sensors ===
            Extruder 0 sensor: no filament
            Extruder 1 sensor: ok
            Extruder 2 sensor: no filament
            Extruder 3 sensor: ok
            === DueX ===
            Read count 1, 2.04 reads/min
            === Network ===
            Slowest loop: 41.04ms; fastest: 0.00ms
            HTTP sessions: 1 of 8
            • WiFi -
              Network state is active
              WiFi firmware version 1.26
              WiFi MAC address 40:f5:20:0d:6b:49
              WiFi Vcc 3.37, reset reason Turned on by main processor
              WiFi flash size 4194304, free heap 23760
              WiFi IP address 192.168.1.5
              WiFi signal strength -64dBm, mode 802.11n, reconnections 0, sleep mode modem
              Clock register 00002002
              21/3/2022, 14:42:46 Connected to 192.168.1.5
              @paolozampini1973 Great! Now config.g.
              paolozampini1973undefined 3 Replies Last reply Reply Quote 0
                @droftarts config (17).g
                  @droftarts I am sending you a photo to make you understand the axes are made up entirely with sfU 1204 and 15 mm linear guides
                    @paolozampini1973 There are a lot of errors in you config.g. Just to start...
                    M569 P0 S0 R-1 ;T2.5:2.5:6:5                       ; X    physical drive 0 goes forwards
                    M569 P1 S1 R-1 ;T2.5:2.5:6:5                       ; Y    physical drive 1 goes forwards
                    M569 P2 S1 R1 T5:5:5:5                             ; Z    physical drive 2 goes forwards
                    M569 P3 S0                                         ; E0   physical drive 3 goes forwards
                    M569 P4 S0                                         ; E1   physical drive 4 goes forwards
                    M569 P5 S0                                         ; E2   physical drive 5 goes forwards
                    M569 P6 S0                                         ; E3   physical drive 6 goes forwards
                    M569 P7 S0 R1 T2:2:2:5                         ; E4 X physical drive 7 goes forwards
                    M569 P8 S1 R1 T2:2:2:5                         ; E5 Y physical drive 8 goes forwards
                    M569 P9 S1 R1 T5:5:5:5                             ; E6 Z physical drive 9 goes forwards
                    M584 X7 Y8 Z2:9 E3:4:5:6:7:8:9 S0                  ; set drive mapping
                    Don't set timings for internal TMC drivers. (M569 P2 S1 R1 T5:5:5:5)
                    Your timings for the external drivers are very short.
                    Your M584 should not have the X, Y and Z2 drivers mapped to E. S0 is not needed. Change to:
                    For M350, M92, M566, M203, M201 and M906 commands, make sure E has 4 parameters, eg
                    M350 X16 Y16 Z16 E16:16:16:16 I1
                      @droftarts what idea did you get what you think?
                        @droftarts Then send me the correct file as you think you are right and I will load it and do the tests you think that for this I lose the steps?
                        at this point what do I do I reassemble the v08 or I leave the V 011 I am willing to do any test Thank you please fill in the config file for me and I will load it exactly as you give it to me and I will let you know
                        droftartsundefined 2 Replies Last reply Reply Quote 0
                          @paolozampini1973 What exact thermistors are you using? You have set the default, which will not be correct, and probably why temperature is incorrect.
                          M308 S0 P"bedtemp" Y"thermistor" T100000 B4138
                          And you need to move Z2 from driver 9 on DueX to driver 0 or 1 on Duet 2. You DueX is being recognised as a DueX2, so probably driver 9 is not working. If it is using an external driver, don't do that; drives on a shared axis need to be identical.
                          paolozampini1973undefined 2 Replies Last reply Reply Quote 0
                            @droftarts Yes I set it to DUEX2 because the axes moved when I turned on the electronics Now I can't on DUEX5 Thanks for the dictation problems but for now it is more important to solve the problem of pitch loss and axis movement
                              @droftarts Yes I know that the engines must be identical and are identical
                                It will have to be later, I have other things I must do.
                                I'd keep the V011 in for now.
                                Please show how you have wired the 74HC level shifters. Wiring diagram and/or photo.
                                  @droftarts Listen to the 74hc I have to take it apart Because it gives me more problems it practically skips the steps at the entrance I have to give it three times and 8 and it doesn't skip my steps but if I give it 5 volts it skips my steps it practically gets worse
                                  I did as you told me but the axes move by themselves without command Both X and Y
                                    @droftarts I would like to leave V 011 but the Y x move without giving it the command so it is useless to talk about other problems there is to solve the first This is the problem Okay I'll wait when you get free I'll publish the config file thanks
                                    21/3/2022, 15:38:13 Error: short-to-ground reported by driver(s) 7 8
                                    Error: over temperature shutdown reported by driver(s) 7 8
                                    21/3/2022, 15:38:08 Error: short-to-ground reported by driver(s) 7 8
                                    21/3/2022, 15:38:04 Error: short-to-ground reported by driver(s) 7 8
                                    21/3/2022, 15:37:59 Error: short-to-ground reported by driver(s) 7 8
                                    21/3/2022, 15:37:55 Error: short-to-ground reported by driver(s) 7 8
                                    21/3/2022, 15:37:50 Error: short-to-ground reported by driver(s) 7 8
                                    21/3/2022, 15:37:49 M122
                                    RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later + DueX5
                                    Used output buffers: 3 of 24 (20 max)
                                    Static ram: 23876
                                    Tasks: NETWORK(ready,10.4%,231) HEAT(delaying,0.1%,330) Move(notifyWait,0.1%,319) DUEX(notifyWait,0.0%,24) MAIN(running,86.5%,411) IDLE(ready,3.0%,29), total 100.0%
                                    Owned mutexes:
                                    Last reset 00:00:25 ago, cause: software
                                    Last software reset at 2022-03-21 15:37, reason: User, GCodes spinning, available RAM 13092, slot 1
                                    Error status: 0x00
                                    Aux0 errors 0,0,0
                                    MCU temperature: min 29.3, current 30.0, max 30.3
                                    Driver 7: position 0, temperature-shutdown! short-to-ground, standstill, SG min/max not available
                                    Driver 8: position 0, temperature-shutdown! short-to-ground, standstill, SG min/max not available
                                    Driver 9: position 0, standstill, SG min/max not available
                                    Date/time: 2022-03-21 15:37:49
                                    Cache data hit count 981081507
                                    Slowest loop: 6.48ms; fastest: 0.19ms
                                    === Storage ===
                                    === MainDDARing ===
                                    === AuxDDARing ===
                                    Segments left: 0
                                    === DueX ===
                                    Read count 1, 2.36 reads/min
                                    === Network ===
                                    Slowest loop: 39.88ms; fastest: 0.00ms
                                    Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
                                    • WiFi -
                                      WiFi flash size 4194304, free heap 20888
                                      Socket states: 0 4 0 0 0 0 0 0
                                      21/3/2022, 15:37:46 Error: short-to-ground reported by driver(s) 7 8
                                      21/3/2022, 15:37:41 Error: short-to-ground reported by driver(s) 7 8
                                      21/3/2022, 15:37:39 Connected to 192.168.1.5
                                      config (18).g
                                      Is that in both DueX2 mode and DueX5 mode?
                                      paolozampini1973undefined 4 Replies Last reply Reply Quote 0
                                        @droftarts As you can see the errors alone are only when AND IN DUEX MODE 5 DRIVER 7+ DRIVER 8 ARE OFF IN DUEX 2 MODE IT DOESN'T GIVE SHORT-CIRCUIT ERRORS SO IT IS NOT NORMAL IN MY MEETING
                                          @droftarts No in DUEX2 MODE they do not move by themselves they move only with the command IN DUEX5 MODE THE MOVEMENT HAS BEEN ALONE WITHOUT COMMAND
                                          tekkydaveundefined 1 Reply Last reply Reply Quote 0
                                            @droftarts from my experience it tells me that this expansion has problems but I think they are more software problems and not hardware problems Tell me what you think
                                            Also because I'm sorry if I always repeat the same thing but I find myself with so many problems that I did not have Maybe some of these problems are not aware I will tell you more I tried to disconnect everything on the problem outputs it gives the same so on all the drivers I am disconnected disconnected nothing is connected and it still gives problems in duex 5 mode
