    DELAYED EXTRUDES DUET WIFI
    My Duet controlled machine
    359
    • paolozampini1973undefined
      paolozampini1973
      someone can explain to me why I start printing a rectangle 200 mm x 20 mm and when it starts printing it starts printing 55 mm after this means that on a line of 200 mm It only prints 145 mm because?
      config (30).g
        droftarts administrators @paolozampini1973
        @paolozampini1973 post the Gcode you are trying to print as well. What slicer are you using? Cura? PrusaSclicer? Or something else?
        Most likely you either have a long retraction at the beginning of the print, so it takes time for extrusion to catch up, or you are running the extruder in absolute mode rather than relative mode.
        paolozampini1973undefined 2 Replies Last reply Reply Quote 0
          paolozampini1973 @droftarts
          @droftarts CURA
          CFFFP_livellamento piano.gcode
          The problem does it with all files and all the drafting is 6 mm
            @droftarts I did a test from 6mm to 2mm and the problem doesn't always change 55mm after Start extruding
            • oliofundefined
              oliof
              If you do not see the priming bead at the beginning (lines 20 to 23 in the gcode), you need to increase the prime length until you get proper extrusion and the filament flowing before you start printing.
              paolozampini1973undefined 1 Reply Last reply Reply Quote 0
                paolozampini1973 @oliof
                @oliof Thanks for the answer I did not understand what you mean because of the translation Ie you ask me to modify the GCODE
                • oliofundefined
                  oliof @paolozampini1973
                  @paolozampini1973 Yes, change the start gcode. 3mm prime is not enough it seems.
                  paolozampini1973undefined 3 Replies Last reply Reply Quote 0
                    @oliof said in DELAYED EXTRUDES DUET WIFI:
                    Sorry I can't understand 3mm of what?
                    you can copy and paste the part you tell me to change please that i can't understand Have patience Thanks
                        @oliof Thanks good evening it seems that I solved thanks
                        • oliofundefined
                          @paolozampini1973 thanks for updating @droftarts you can mark this as solved.
                          • droftartsundefined droftarts marked this topic as a question
                          • droftartsundefined droftarts has marked this topic as solved
