    Beta testers for multiple motion system support
    Beta Firmware
    21
    70
    6.5k
    • JoergS5undefined
      JoergS5 @dc42
      @dc42 I will participate with two robot arms. Main focus will be collision detection and avoidance and I will help writing needed code.
      • gloomyandyundefined
        gloomyandy @o_lampe
        @o_lampe It looks like the code for this will be on the 3.5-dev repo. I will at some point be picking that code up and providing an STM32 version, so hopefully we will be able to contribute to the testing of this new feature. I usually try to track new developments reasonably closely so hopefully it will be possible to do that again.
        1 Reply Last reply Reply Quote 4
        • oliofundefined
          oliof @o_lampe
          @o_lampe I have an unused MB6HC and 3HC expansion board I can loan out to you. DM me for details.
          o_lampeundefined 1 Reply Last reply Reply Quote 1
          • o_lampeundefined
            o_lampe @oliof
            @oliof That's very kind of you, but I'd need at least three 3HC boards or many other toolboards with 2 drivers per board. 15 drivers in total...
            • oliofundefined
              oliof @o_lampe
              @o_lampe if one other kind soul finds they have a 6HC lying around you'd be set (-:
              • o_lampeundefined
                o_lampe @oliof
                @oliof
                Jepp, passing the hat is not my style. Unfortunately the shopping list would be alot longer (eg. hotends, direct drive extruders). That's why I proposed to sell my frame.
                But it's over the top for a dual-motion system anyway. It would need 4 independent Z-axes and then it could work with two tools simultaneously. (then changing tools for perimeter and infill)
                It's quite a challenge
                • oliofundefined
                  oliof @o_lampe
                  @o_lampe you are not passing the hat if people propose giving, but I catch your drift. Unfortunately I have neither the funds nor the space for yet another machine, or I´d consider your offer.
                  • breedundefined
                    breed
                    ive been working on this layout in the background while I finish other printers. should be what you are thinking correct?
                    • o_lampeundefined
                      o_lampe @breed
                      @breed The critical thing about dual print heads and dual toolheads working simultaneously has always been the z-height. (mesh -leveling etc)
                      Idk if that's already in the scope of @dc42 project, but independent z-motion is the key for succesful multi tool systems.
                      Since you are still in the planning phase, you might consider adding an Z-adjustable toolholder. (I prefer dovetail sliders)
                      David, would you be so kind and tell us the options to drive the independent mini-z axes?
                      Geared DC-encoder motors would be small and strong, but they'd need a supporting toolboard.
                      Steppers would be huge and heavy. Remotely driven, it might be an option, if mesh leveling with backlash-compensation is available.
                      dc42undefined breedundefined 2 Replies Last reply Reply Quote 0
                        dc42 administrators @o_lampe
                        @o_lampe wouldn't a Nema 11 or Nema 8 stepper motor with leadscrews be suitable? Although the Nema 8 ones tend to be expensive. https://www.omc-stepperonline.com/linear-motor
                        • breedundefined
                          breed @o_lampe
                          @o_lampe I haven't gotten near the point of adjustable z on one of the tool heads. I have 2 printers with makertech tilting hotend. They have grub screws for adjusting the heatbreaks, seems to work fine. I was hoping to get this one figured out and together by mrrf, but there are 4 other printers in the que in front of it. Maybe next year. Having automatic z adjustment would be awesome but the weight....I didn't want the common rail double x carriage because of carrying the second x carriage for all the y axis moves. I have an i3 style idex and basically never print mirror or duplicate mode. I def could see a path for simultaneous g code. Printing two different objects would be a useful time saver.
                          • o_lampeundefined
                            o_lampe @dc42
                            It would work, but the weight penalty isn't worth the +/-1mm movement we need for Z-hop and mesh leveling.
                            Even a small hobby servo with excenter could do this, but their speed isn't controlable. That makes it difficult to move them in sync with XY motion.
                            So IMHO a dc motor with encoder would be the best option.
                            A mockup picture of a modified PTFE dovetail slider with dc motor/leadscrew
                            In a perfect world we'd have access to the heightmap(s)-data and route the z-correction to a device of our choice.
                            • botundefined
                              bot
                              What about shims to adjust hot end Z height? On my printer, I'm able to add shims to the top of the hot end to lower its nozzle's Z height.
                              *not actually a robot
                                dc42 administrators @bot
                                Thanks for all who have responded. I may be able to provide a first build of RRF with dual motion system by this Friday. This version will have some limitations:
                                • The two motion systems must share a common Z axis
                                • Standalone mode only (not SBC mode)
                                • Resume-after-power fail will not be supported
                                • Simulation mode may not be supported
                                • Pause/resume may not be fully implemented
                                • There will be no attempt to predict collisions between the two print heads, so the GCode commands must avoid potential collisions
                                • There will be no checking that commands for different motion systems don't attempt to drive the same axis simultaneously
                                • No mesh bed compensation
                                It's time to think about preparing GCode files that case use both motion systems. There is some documentation at https://docs.duet3d.com/en/User_manual/RepRapFirmware/Multiple_motion_systems on how the different motion systems are addressed in GCode.
                                The simplest way to use the two motion systems is probably to load two objects on the build plate in your slicer and space them far enough apart so that they can be printed independently by your two motion systems without collisions. Then change the GCode file produced by the slicer so that the commands for one object are assigned to motion system 0 (by using the M596 P0 command before a block of commands for that motion system) and commands for motion system 1 are assigned to motion system 1 (using M596 P1 before a block of commands for that motion system).
                                You will need to add a M400 command to sync the motion systems before and after each G1 Z command that does a layer change. Obviously you cannot use Z hop on travel moves. Don't let the blocks of contiguous commands for one motion system get too long, or the other motion system might pause for a short while as it skips the block.
                                You will need to select one tool for each motion system at the start. One of those tools should map the X and Y axes to the corresponding axes of your second motion system, for example U and V.
                                In the future I hope we will be able to do the splitting of objects into multiple motion systems either in the slicer, or in a standard post-processing script.
                                o_lampeundefined 2 Replies Last reply Reply Quote 2
                                • o_lampeundefined
                                  o_lampe @dc42
                                  That'll be exciting to try!
                                  You should also mention that mesh leveling must not be enabled.
                                  I wonder, how a waiting tool behaves when layer times are way different? Will it go in parking position or just sit and wait for the other tool to finish the layer? Will it automatically retract/unretract?
                                  • o_lampeundefined
                                    o_lampe @dc42
                                    @dc42 said in Beta testers for multiple motion system support:
                                    How do we address layer changes then? Isn't Z-axis a common axis of both systems? Do we need to define a third tool just for the z-axis and switch to that tool before layer change?
                                    Putting M400 before a layer change will only wait for the other tool to empty the print queue, but it's not guaranteed to be finished with the layer...
                                      @o_lampe said in Beta testers for multiple motion system support:
                                      When multiple motion systems are in use, M400 causes them to synchronise at that point, i.e. no motion system proceeds past that M400 until all motion systems have finished executing it.
                                      Only one motion system needs to move the Z axis to do the layer change. Another M400 command after that Z move will ensure that the other motion system waits for it to complete.
                                      Currently it will just sit there. In the future I will add an option to park waiting tools, probably by using an extra parameter on M400. Meanwhile you could call a parking macro just before the M400.
                                      • botundefined
                                        bot
                                        I will begin work shortly preparing a rudimentary minimally-viable custom PrusaSlicer build to support concurrent printing of multiple objects. So far, the plan would be to copy and modify the sequential object printing feature to interleave the two object g-codes instead of outputting them sequentially. M596 and M400 would be emitted when needed. Is there anything else that would be required or helpful to get started testing this? At first, time estimates and other helpful features would not work.
                                        o_lampeundefined 1 Reply Last reply Reply Quote 4
                                        • o_lampeundefined
                                          o_lampe @bot
                                          @bot
                                          I thought from the beginning, that such a project can only be done with a slicer-dev in coop.
                                          Interleaving the two objects has it's charm, but there is also the problem with unequal path length (or path print duration to be exact).
                                          You'd have to chop (straight) path' into equal portions to make sure, both nozzles are finished at the same time.
                                          A waiting tool at the end of a layer is one thing, but a waiting tool at the end of every path is another.
                                          It would be cool, if you could slow down the nozzle of the object with the slightly smaller layer-area, to make them both fotofinish the layer.
                                          dc42undefined botundefined 2 Replies Last reply Reply Quote 0
                                            @o_lampe when printing multiple objects, it should only be necessary for the two motion systems to synchronise at the end of each layer and again after the Z move, provided the objects are separate sufficiently for there to be no risk of collision of the two tool heads.
