Solved Is there a terminal like YAT for RPI?
@tecno said in Is there a terminal like YAT for RPI?:
Config.g empty 'again'.
Was this the original problem here or that it had happened previously?
Both
Had you edited config.g before it had gone empty?
Was config.g missing completely, or just blank?
Was config.g.bak present and complete? -
No
Blank
Present -
Thanks. Had we replaced this board for you already when it first happened?
No config this morning, printer been offline for 2 days.
Today no config.g and no config.g.bak
re. board To be honest I do not remember. M552 S1 keeps me running
Here some moore
Now no CAN connection, WTF is going on??
@tecno i've seen that happen when i reboot. the board reboots before the toolboard can respond. its normal I think
Edited config.g (probe) and now CAN is back, this a bit fishy.
@jay_s_uk
; WAIT FOR CAN
G4 S4 should be plenty -
@tecno the red line issue you showed above was after the emergency stop and not to do with startup
@jay_s_uk
Ain't that same as remote boot up? -
@tecno no
@jay_s_uk
So only power off and on? -
@tecno imagine you're on the phone to someone and you ask them a question but they hang up before they can answer, thats the same as whats happening when you press the emergency stop button. the main board asks the heater to turn off to make sure its off but its already rebooting, so you get the error that the remote heater can't be turned off. it has nothing to do with startup delay
@tecno use M122 B121 to check which bootloader version is installed on the tool board.
M122 B121
Diagnostics for board 121:
Duet TOOL1LC firmware version 3.3 (2021-06-15 16:12:58)
Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1)
Never used RAM 2624, free system stack 2774 words
Tasks: Move(notifyWait,0.0%,153) HEAT(delaying,0.2%,107) CanAsync(notifyWait,0.0%,61) CanRecv(notifyWait,0.0%,76) CanClock(notifyWait,0.0%,65) ACCEL(notifyWait,0.0%,61) TMC(notifyWait,2.8%,57) MAIN(running,92.0%,352) IDLE(ready,0.0%,27) AIN(delaying,5.0%,142), total 100.0%
Last reset 01:08:08 ago, cause: software
Last software reset data not available
Driver 0: position 0, 80.0 steps/mm, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 19, reads 12723, writes 9, timeouts 0, DMA errors 0, steps req 0 done 0
Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
Peak sync jitter -271/0, peak Rx sync delay 214, resyncs 0/0, no step interrupt scheduled
VIN: 24.4V
MCU temperature: min 35.3C, current 35.8C, max 36.0C
Ticks since heat task active 225, ADC conversions started 4088720, completed 4088719, timed out 0, errs 0
Last sensors broadcast 0x00000002 found 1 230 ticks ago, loop time 0
CAN messages queued 49052, send timeouts 0, received 36802, lost 0, free buffers 37, min 37, error reg 110000
dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0
Accelerometer detected: yes, status: 00
I2C bus errors 0, naks 0, other errors 0 -
Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1)Are you using 3.4 on the mainboard?
You can update the bootloader to 2.4 via these instructions: https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_bootloader
As for the config.g going missing, I think we should replace the board. Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
Since last mid april printer has been working OK. This morning I got heater fault.
OK so I decided to do the updates of bootloader as well as FW for toolboard.Now I can not get hotend heater to work.
m122 B121
Duet TOOL1LC rev 1.1 or later firmware version 3.4.0 (2022-03-15 09:00:04)
Bootloader ID: SAMC21 bootloader version 2.4 (2021-12-10)
All averaging filters OK
Never used RAM 2680, free system stack 88 words
Tasks: Move(notifyWait,0.0%,153) HEAT(notifyWait,0.2%,115) CanAsync(notifyWait,0.0%,65) CanRecv(notifyWait,0.0%,76) CanClock(notifyWait,0.0%,65) ACCEL(notifyWait,0.0%,61) TMC(delaying,3.0%,57) MAIN(running,91.9%,349) IDLE(ready,0.0%,26) AIN(delaying,4.9%,142), total 100.0%
Last reset 00:02:43 ago, cause: power up
Driver 0: pos 0, 80.0 steps/mm,standstill, SG min 0, read errors 0, write errors 0, ifcnt 9, reads 16237, writes 9, timeouts 1, DMA errors 0, CC errors 0, failedOp 0x71, steps req 0 done 0
Peak sync jitter -2/9, peak Rx sync delay 209, resyncs 0/0, no step interrupt scheduled
VIN voltage: min 23.9, current 24.0, max 24.7
MCU temperature: min 32.9C, current 36.8C, max 36.9C
Last sensors broadcast 0x00000002 found 1 107 ticks ago, 0 ordering errs, loop time 0
CAN messages queued 3260, send timeouts 0, received 1485, lost 0, free buffers 37, min 37, error reg 0
Accelerometer: LIS3DH, status: 00
I2C bus errors 0, naks 3, other errors 0Any idea what is wrong? Is it the FET again?
I can activate the bed heater but not hotend heater!
