    Toolboard + NO NPN probe
    982
    • tecnoundefined
      tecno @infiniteloop
      @infiniteloop
      That is what I suspect, not the first toolboard to go south on me.
      • infiniteloopundefined
        infiniteloop @tecno
        @tecno said in Toolboard + NO NPN probe:
        How can i check port that it is working? Short GND to INP or 5V?
        Yes, you can short GND to INP. Does this trigger the endstop?
        tecnoundefined 1 Reply Last reply Reply Quote 0
        • tecnoundefined
          tecno @infiniteloop
          @infiniteloop said in Toolboard + NO NPN probe:
          not shorted = value is 0
          shorted = value is 1000
          So go figure what is wrong, I only have 1N4148 diode's at hand no BAT´s
          infiniteloopundefined dc42undefined 2 Replies Last reply Reply Quote 0
            infiniteloop @tecno
            That's good news, the board still works. Your test means that the probe doesn't pull down the signal strong enough to trigger. Try the diode - according to the documentation, this might work:
            The diode should preferably be a small-signal Schottky diode such as BAT43 or BAT85, but a small signal silicon diode such as 1N4148 works for some people.
            • tecnoundefined
              tecno @infiniteloop
              @infiniteloop
              Already tried the diod = no go
                infiniteloop @tecno
                @tecno Hm, I'm guessing, but maybe a pull-down resistor between GND and INP might help. Can't tell you a value, though, but I would start with something like 10k - and go down until the probe triggers reliably.
                • martin7404undefined
                  martin7404
                  I syrongly sugest using NC probe
                  M671 X-31.39:250:531.36 Y-18:433.3:-18 S10       ; Locations left, center, right
                  M558 P8 C"121.io2.in"  H3 F1000 T6000 A20 S0.005 ; PINDA set Z probe type to switch and the dive height + speeds
                  This is for my superpinda with duet 3 and toolboard
                  Muldex IDEX Duet2+Duex5
                  Custom CoreXY 600x400 Hemera , Duet3+Toolboard+1HCL closed loop
                  Sapphire Pro with Duet2, with closed-loop motors
                  custom high temp E3D tool changer with Duet2+Duex
                  • tecnoundefined
                    tecno @infiniteloop
                    I found one PNP that I now have tried = same issue.
                    Found other with better sense distance that I prefere.
                    IFS208-00_EN-GB.pdf
                    How do I connect this one, if possible the 2 wire Vin + io0 in ?
                      dc42 administrators @tecno
                      @tecno if shorting input to ground changes the Z probe reading from 0 to 1000 then an NPN output probe connected correctly should work. You do not need to use a diode.
                      Are you sure it is NPN output?
                      Are you sure you have connected it correctly?
                      Does it have a LED on it to indicate when it is triggered?
                      • tecnoundefined
                        tecno @dc42
                        Label says NPN NO
                        std coloring on wires BN to +, BK out and BU to -. Load BK to BN so it should be NPN right?
                        Vin to BN
                        GND on 121.io0 to BU
                        BK to 121.io0 input
                        Yes LED indicates Trig
                        Tried without and with 1N4148 Diode, Inverted - Non inverted - Pull up no pullup
                        • tecnoundefined
                          tecno @tecno
                          Now I have yet another probe = IFS208 and now it works.
                          Suspect these bloody mini crimp connectors again = they are not up to par what is needed for a good connector.
                          So a Toolboard V2 with new bigger common crimp connectors PLEASE. I see no need to scale down this board to be hard to work with. I suggested earlier that toolboard to be delivered with pre crimped pigtails.
                          All in all it is too wimpy with the assembly with board connector housing not properly seated.
                          • tecnoundefined
                            tecno @tecno
                            probe = IFS208 = Too long so it does not fit.
                            • tecnoundefined
                              tecno @tecno
                              Back to the NPN NO probe, now it works.
                              M558 C"!121.io0.in" P8 H10 F120 T8000
                              So bad crimp was the issue.
                              • dc42undefined dc42 marked this topic as a question
                              • dc42undefined dc42 has marked this topic as solved
