    Toolboard + NO NPN probe
    967
    • tecnoundefined
      tecno @jay_s_uk
      @jay_s_uk
      Doh... too many variables so confusing it is.
      How can i check port that it is working? Short GND to INP or 5V?
      Set it as P8 so I can see Probe value 0 or 1000
      • infiniteloopundefined
        infiniteloop @tecno
        @tecno said in Toolboard + NO NPN probe:
        Vin non triggered = out Vin
        Do I understand this right: The signal has 6-30V non-triggered?
        tecnoundefined 1 Reply Last reply Reply Quote 0
        • tecnoundefined
          tecno @infiniteloop
          @infiniteloop
          Yes
            infiniteloop @tecno
            Yes
            Then you've fried the port. 😢
            • tecnoundefined
              tecno @infiniteloop
              @infiniteloop
              That is what I suspect, not the first toolboard to go south on me.
                infiniteloop @tecno
                Yes, you can short GND to INP. Does this trigger the endstop?
                • tecnoundefined
                  tecno @infiniteloop
                  @infiniteloop said in Toolboard + NO NPN probe:
                  not shorted = value is 0
                  shorted = value is 1000
                  So go figure what is wrong, I only have 1N4148 diode's at hand no BAT´s
                  infiniteloopundefined dc42undefined 2 Replies Last reply Reply Quote 0
                    infiniteloop @tecno
                    That's good news, the board still works. Your test means that the probe doesn't pull down the signal strong enough to trigger. Try the diode - according to the documentation, this might work:
                    The diode should preferably be a small-signal Schottky diode such as BAT43 or BAT85, but a small signal silicon diode such as 1N4148 works for some people.
                    • tecnoundefined
                      tecno @infiniteloop
                      @infiniteloop
                      Already tried the diod = no go
                        infiniteloop @tecno
                        @tecno Hm, I'm guessing, but maybe a pull-down resistor between GND and INP might help. Can't tell you a value, though, but I would start with something like 10k - and go down until the probe triggers reliably.
                        • martin7404undefined
                          martin7404
                          I syrongly sugest using NC probe
                          M671 X-31.39:250:531.36 Y-18:433.3:-18 S10       ; Locations left, center, right
                          M558 P8 C"121.io2.in"  H3 F1000 T6000 A20 S0.005 ; PINDA set Z probe type to switch and the dive height + speeds
                          This is for my superpinda with duet 3 and toolboard
                          Muldex IDEX Duet2+Duex5
                          Custom CoreXY 600x400 Hemera , Duet3+Toolboard+1HCL closed loop
                          Sapphire Pro with Duet2, with closed-loop motors
                          custom high temp E3D tool changer with Duet2+Duex
                          • tecnoundefined
                            tecno @infiniteloop
                            I found one PNP that I now have tried = same issue.
                            Found other with better sense distance that I prefere.
                            IFS208-00_EN-GB.pdf
                            How do I connect this one, if possible the 2 wire Vin + io0 in ?
                              dc42 administrators @tecno
                              @tecno if shorting input to ground changes the Z probe reading from 0 to 1000 then an NPN output probe connected correctly should work. You do not need to use a diode.
                              Are you sure it is NPN output?
                              Are you sure you have connected it correctly?
                              Does it have a LED on it to indicate when it is triggered?
                              • tecnoundefined
                                tecno @dc42
                                Label says NPN NO
                                std coloring on wires BN to +, BK out and BU to -. Load BK to BN so it should be NPN right?
                                Vin to BN
                                GND on 121.io0 to BU
                                BK to 121.io0 input
                                Yes LED indicates Trig
                                Tried without and with 1N4148 Diode, Inverted - Non inverted - Pull up no pullup
                                • tecnoundefined
                                  tecno @tecno
                                  Now I have yet another probe = IFS208 and now it works.
                                  Suspect these bloody mini crimp connectors again = they are not up to par what is needed for a good connector.
                                  So a Toolboard V2 with new bigger common crimp connectors PLEASE. I see no need to scale down this board to be hard to work with. I suggested earlier that toolboard to be delivered with pre crimped pigtails.
                                  All in all it is too wimpy with the assembly with board connector housing not properly seated.
                                  • tecnoundefined
                                    tecno @tecno
                                    probe = IFS208 = Too long so it does not fit.
                                    • tecnoundefined
                                      tecno @tecno
                                      Back to the NPN NO probe, now it works.
                                      M558 C"!121.io0.in" P8 H10 F120 T8000
                                      So bad crimp was the issue.
                                      • dc42undefined dc42 marked this topic as a question
                                      • dc42undefined dc42 has marked this topic as solved
