My PanelDue7i Keep Says "connecting"
PanelDue
paneldue
654
    3.4 on the Panel and 3.3 on the Duet should probably work, but just in case, you can update the Duet as well. You should be on 3.4 anyway.
    Upload this zip file as is to the system tab:
    https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.0/Duet2and3Firmware-3.4.0.zip
    If that doesn't help, please try a 4-wire cable. If you don't plan on using the SD card slot on the PanelDue the 4-wire cable is preferred anyway.
    If you're still having troubles after trying that please post your full config.g and the results of M122 and M98 P"config.g". Also post the exact firmware version of the PanelDue as shown on the setup tab.
      TRATOON
      Done. I uploaded the files.
      undefined 1 Reply Last reply 22 Apr 2022, 16:21 Reply Quote 0
        TRATOON @TRATOON
        Exact Panel Due fw version: 3.4.0
        M122 Results: === Diagnostics ===
        RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.0 (2022-03-15 18:58:31) running on Duet WiFi 1.02 or later
        Board ID: 0JD0M-9P6M2-NW4SS-6JKD8-3SN6Q-1UWMK
        Used output buffers: 3 of 24 (17 max)
        Static ram: 23868
        Dynamic ram: 74300 of which 0 recycled
        Never used RAM 13912, free system stack 184 words
        Tasks: NETWORK(ready,14.1%,218) HEAT(notifyWait,0.0%,332) Move(notifyWait,0.0%,364) MAIN(running,85.4%,444) IDLE(ready,0.5%,30), total 100.0%
        Owned mutexes:
        Last reset 00:03:17 ago, cause: software
        Last software reset at 2022-04-22 00:04, reason: User, GCodes spinning, available RAM 13912, slot 1
        Error status: 0x00
        Aux0 errors 0,0,1
        Step timer max interval 0
        MCU temperature: min 32.4, current 34.5, max 34.6
        Supply voltage: min 24.0, current 24.2, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
        Events: 0 queued, 0 completed
        Driver 0: standstill, SG min n/a
        Driver 1: standstill, SG min n/a
        Driver 2: standstill, SG min n/a
        Driver 3: standstill, SG min n/a
        Driver 4: standstill, SG min n/a
        Driver 5:
        Driver 6:
        Driver 7:
        Driver 8:
        Driver 9:
        Driver 10:
        Driver 11:
        Date/time: 2022-04-22 09:19:25
        Slowest loop: 6.32ms; fastest: 0.18ms
        === Storage ===
        Free file entries: 10
        SD card longest read time 4.3ms, write time 0.0ms, max retries 0
        DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
        === MainDDARing ===
        === AuxDDARing ===
        Segments left: 0
        Movement lock held by null
        HTTP is idle in state(s) 0
        Telnet is idle in state(s) 0
        File is idle in state(s) 0
        USB is idle in state(s) 0
        Aux is assembling a command in state(s) 0
        Trigger is idle in state(s) 0
        Queue is idle in state(s) 0
        LCD is idle in state(s) 0
        Daemon is idle in state(s) 0
        Code queue is empty
        === Network ===
        Slowest loop: 16.13ms; fastest: 0.00ms
        Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
        HTTP sessions: 1 of 8
        • WiFi -
          Network state is active
          WiFi firmware version 1.26
          WiFi MAC address e0:98:06:a4:42:62
          WiFi Vcc 3.36, reset reason Turned on by main processor
          WiFi flash size 4194304, free heap 24320
          WiFi IP address 192.168.1.148
          WiFi signal strength -56dBm, mode 802.11n, reconnections 0, sleep mode modem
          Clock register 00002002
          Socket states: 4 0 0 0 0 0 0 0
        M98 Results:
        M98 P"config.g"
        HTTP is enabled on port 80
        FTP is disabled
        TELNET is disabled
        Warning: Macro file config-override.g not found
        And I do plan on using the SD slot. However for testing purposes, I will go make a 4-wire cable right now
        undefined 1 Reply Last reply 22 Apr 2022, 16:33 Reply Quote 0
          Phaedrux Moderator @TRATOON
          @tratoon said in My PanelDue7i Keep Says "connecting":
          https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_PanelDue
          You can try the latest pre-release paneldue firmware as well.
          https://github.com/Duet3D/PanelDueFirmware/releases
          undefined 1 Reply Last reply 22 Apr 2022, 16:51 Reply Quote 0
            TRATOON @Phaedrux
            @phaedrux Updating the firmware didn't work it still says connecting.
              Can you post your full config?
              undefined 1 Reply Last reply 22 Apr 2022, 17:17 Reply Quote 0
                TRATOON @Phaedrux
                @phaedrux The four wire worked. However, I would like SD functionality. What do you suggest? Should I ask my distributor for a new cable?
                undefined 1 Reply Last reply 22 Apr 2022, 17:25 Reply Quote 0
                  TRATOON @TRATOON
                  However, I checked the continuity of the ribbon cable and it was continuous. So what else could be the problem?
                    It's getting power through the ribbon cable, but it seems like the data connection is not working.
                    Can you also check the resistance of the ribbon cable wires?
                    Can you also inspect the socket on the board for solder defects?
                    undefined 1 Reply Last reply 22 Apr 2022, 17:54 Reply Quote 0
                      TRATOON @Phaedrux
                      @phaedrux Will do thank you
                      • undefined TRATOON marked this topic as a question 22 Apr 2022, 17:54
                      • undefined TRATOON has marked this topic as solved 22 Apr 2022, 17:54
                      13 out of 13
