    RRF 3.4.0 Sensorless Homing Issues after Power Cycle
    Beta Firmware
    8
    28
    1.6k
      dc42 administrators @Krohm Koala
      @krohm-koala you should perform stealthChop tuning in the homing files before executing the homing move.
      floblerundefined 1 Reply Last reply Reply Quote 0
      • floblerundefined
        flobler @dc42
        @dc42 @Phaedrux to my understanding I am performing the stealthchop tuning in the homing-modifications.g file.
        The main issue though is that these files have worked with both my printers for RRF 3.3 but do not work in RRF 3.4.0.
        This indicates to me that something has been changed in RRF 3.4.0, preventing us from homing directly after a power cycle.
        Am I doing something wrong? If so, why does it work without problem in RRF 3.3?
        Thanks for your time!
        Del87undefined gloomyandyundefined 2 Replies Last reply Reply Quote 0
        • Del87undefined
          Del87 @flobler
          @flobler mb because stealthchop is not default mode on 3.4 anymore
          Dmitry
          Krohm Koalaundefined floblerundefined 2 Replies Last reply Reply Quote 0
          • Krohm Koalaundefined
            Krohm Koala @Del87
            @del87 but Everything is set to stealthchop in config.g so it should be a problem
            • floblerundefined
              flobler @Del87
              @del87 thamks for chiming in but that is accounted for in config.g and I am certain the drivers are set to operate in stealthChop mode when trying to home. Otherwise hpming would not work at all and not just after a power cycle of the printer.
              • gloomyandyundefined
                gloomyandy @flobler
                @flobler The tuning moves you are using are very small. I wonder if perhaps using a longer move would help? You might also want to add a delay/m400 after the 2nd move as well to see if that makes any difference?
                I agree that it is odd that 3.3 works but 3.4 does not, but perhaps your settings were right on the edge and starting in spreadcycle mode then switching to stealthchop mode (which is in effect what now happens in 3.4), results in slightly different "learned" values after tuning? I suppose you could try switching back to 3.3 and capturing the various register contents just before your homing moves and compare those with 3.4.
                floblerundefined 1 Reply Last reply Reply Quote 1
                • floblerundefined
                  flobler @gloomyandy
                  @gloomyandy Thanks for the input! I tried to make the move longer and also to add the second M400 which both did not change the behavior.
                  What I also tried is to play with the sensitivity for stall detection as I thought maybe something changed here and the drivers are just being configured too sensitive. I used S3 for both axes on RRF 3.3. With RRF 3.4.0 I went all the way up to the least sensitive value (63) which also did not help. The motors still stall immediately when trying to home after a power-cycle.
                  So to me there is two things than could be going wrong:
                  a) I am doing something wrong with the tuning move (but I am not sure what and the docs are not very clear here); then I am still a bit confused why it did not happen in RRF 3.3
                  b) Something changed from RRF 3.3 to 3.4.0 that breaks the stealthChop tuning procedure
                  If any of my other settings were wrong (i.e. speed, current, acceleration or jerk) then I don't think the motors would home properly after this initial false stall after a power-cycle.
                  • floblerundefined
                    flobler
                    @dc42 @Phaedrux I have not managed to figure out what I am doing wrong yet and the behavior is still consistent across two machines.
                    Do you have any hints? Is my driver tuning procedure configured wong?
                    Thank you 🙂
                    P.S.: May I aske why this is categorized under "Beta Firmware"?
                    • oliofundefined
                      oliof @flobler
                      @flobler I had issues with sensorless homing after updating to 3.4 until I did M569 Pxx D3 at the beginning of the homing file and switched back to normal hybrid mode doing M569 Pxxx D2 at the end. Maybe that helps. Also the documentation recommends homing moves to be above 40mm/sec so I moved to 40mm/sec just so. With the reduced motor power it is just a light tap and the axis is homed.
                      • floblerundefined
                        flobler @oliof
                        @oliof thank you, I will give that a go and report back!
                        • floblerundefined
                          flobler
                          @oliof this did not help in my case. I think in your case you utilized that the drivers were defaulting to stealthChop before going to RRF 3.4.0 and therefore you needed to give them instructions to use stealthChop2 after the upgrade (as with RRF 3.4.0 the default now is spreadCycle).
                          My problem is not really that homing is not working generally. Homing works totally fine and smooth just not right after I power-cycle my printer when trying to home for the first time.
                          Thank you for the suggestion though!
                          • oliofundefined
                            oliof @flobler
                            @flobler well, without my change homing usually did not work at all, including right after turning on the printer. So yours is a bit of a weird one.
                            • floblerundefined
                              flobler @oliof
                              @oliof yes, that makes sense. I assume before you upgraded to RRF 3.4.0 you did not specifically configure your drivers as D3 (because they did that by default). Now they default to D2, hence you need to tell them specifically to operate in stealthChop2 before homing (via D3).
                              If you just configure your drivers as D3 now in config.g you should also be able to home just fine without switching between D2 and D3.
                              May I ask how your homing files look like? I'd like to see if you are doing something different to tune your drivers. Thank you!
                              oliofundefined dc42undefined 2 Replies Last reply Reply Quote 0
                              • oliofundefined
                                oliof @flobler
                                @flobler https://github.com/oliof/printerconfigs/blob/main/v-minion/sys/homex.g
                                  dc42 administrators @flobler
                                  @flobler your homing files are not right for the Duet 3 Mini because you are not executing the required stealthChop tuning move. For example, the first X move you do in homeall.g is this:
                                  G1 H1 X5 F1200
                                  Try this instead:
                                  M17 X
                                  G4 P140
                                  G1 H2 X5 F1200
                                  • floblerundefined
                                    flobler @dc42
                                    @dc42 Thank you! I just tried that but the behavior did not change. X and Y are still stalling immediately when trying to home after a power cycle and home fine after that initial false stall until I power cycle the printer again.
                                    I had a tuning move included in homing-modifications.g (which I removed to test what you suggested).
                                    dc42undefined floblerundefined 2 Replies Last reply Reply Quote 0
                                      @flobler when you try to home after a power cycle, does each of the X and Y axes move 5mm away from the endstop before the premature stall?
                                      • floblerundefined
                                        flobler @flobler
                                        For reference, this is what I just tried:
                                        homeall.g
                                        ; homeall.g
                                        ; Description:
                                        ; 	- system file
                                        ; 	- called to home all axes
                                        ; 	- used in homez.g
                                        ; Preparation
                                        M98 P"homing-modifications.g" ; calls homing-modifications.g
                                        ; Lift Z Axis
                                        G91                           ; relative positioning
                                        G1 H2 Z5 F1200                ; lift Z axis by 5mm
                                        M400                          ; wait for current moves to finish
                                        ; Home X Axis
                                        M17 X
                                        G4 P140
                                        G1 H2 X5 F1200
                                        G1 H1 X5 F1200                ; move X axis away from homing position by 5mm
                                        G1 H1 X-255 F3000             ; move to X axis endstop and stop there
                                        G1 X5 F1200                   ; move back by 5mm
                                        G1 H1 X-10 F3000              ; move to X axis endstop again
                                        G1 X10 F1200                  ; move back by 10mm
                                        ; Home Y Axis
                                        M17 Y
                                        G4 P140
                                        G1 H2 Y5 F1200
                                        G1 H1 Y5 F1200                ; move Y axis away from homing position by 5mm
                                        G1 H1 Y-220 F3000             ; move to Y axis endstop and stop there
                                        G1 Y5 F1200                   ; move back by 5mm
                                        G1 H1 Y-10 F3000              ; move to Y axis endstop again
                                        G1 Y10 F1200                  ; move back by 10 mm
                                        ; Home Z Axis
                                        G90                           ; absolute positioning
                                        G1 X11.5 Y4.5 F6000           ; go to first probe point
                                        G30                           ; home Z axis by probing the bed
                                        G1 Z0.6 F500                  ; move Z axis to 0.6mm
                                        G1 Z1 F500                    ; lift Z axis by 1mm
                                        ; Restore Defaults
                                        M98 P"homing-modifications-reset.g" ; calls homing-modifications-reset.g
                                        ; homing-modifications.g
                                        ; Description:
                                        ; 	- system file
                                        ; 	- sets motor current and V parameter for homing moves
                                        ; 	- tunes motor drivers
                                        ; 	- used in all homing system files
                                        ; Modifications
                                        M569 P0.3 V10           ; reduce V parameter to ensure stealthChop is enabled for X
                                        M569 P0.2 V10           ; reduce V parameter to ensure stealthChop is enabled for Y
                                        M913 X60 Y60            ; drop X and Y motor current to 60%
                                        G4 P150                 ; wait 150ms
                                        ; homing-modifications-reset.g
                                        ; Description:
                                        ; 	- system file
                                        ; 	- resets all homing modifications applied in homing_modifications.g
                                        M913 X100 Y100  ; reset X and Y motor current to 100%
                                        M569 P0.3 V2000 ; restore default V parameter for X
                                        M569 P0.2 V2000 ; restore default V parameter for Y
                                        • floblerundefined
                                          flobler @dc42
                                          @dc42 Yes, they do and as soon as the axes move towards the endstop, they stall. If it helps I can send you a video of the behavior?
                                          • floblerundefined
                                            flobler
                                            @dc42 my bad, as you can see above I failed to remove the G1 H1 X5 F1200
                                            I re-tested without and this works now. Thank you very much!
                                            • Phaedruxundefined Phaedrux has marked this topic as solved
