    Servo Configuration Check
    Using Duet Controllers
    1.6k
    • alankilianundefined
      alankilian @JRCL
      @jrcl
      Do you have the ground of the 5 Volt output connected to the ground on the Duet?
      If it's isolated then you would need the grounds tied together.
      (somewhat unlikely, but who knows)
      JRCLundefined 1 Reply Last reply Reply Quote 0
      • JRCLundefined
        JRCL @Phaedrux
        @phaedrux Tried without the ! and here is my wiring diagram and circled the pin on the duex to be safe. Still no dice.
        • JRCLundefined
          JRCL @alankilian
          @alankilian just posted my abridged wiring diagram above. I don't think that's isolated, but maybe?
          fcwiltundefined alankilianundefined 2 Replies Last reply Reply Quote 0
          • fcwiltundefined
            fcwilt @JRCL
            @jrcl said in Servo Configuration Check:
            Do you perhaps have an oscilloscope you could check the PWM signal with? It may not be meeting the requirements for your servo.
            • JRCLundefined
              JRCL @fcwilt
              @fcwilt I don't unfortunately. I'm no electrical engineer, but could I use some sort of amplification module on the signal? Not sure if PWM signals work like that/or can be amplified like that.
              JRCLundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
              • JRCLundefined
                JRCL @JRCL
                Managed to find the control signal specs. What are the PWM signals on the Duex able to supply?
                • fcwiltundefined
                  fcwilt @JRCL
                  A PWM signal as used to drive a servo is a fixed frequency, typically 50 Hz, with a varying duty cycle.
                  While you could possible hear via an audio amplifier with suitable frequency range it wouldn't tell you if the signal met the needs of your servo.
                  You can get a fairly nice combo multimeter and oscilloscope which would do the job for $100 off of Amazon. A useful tool for working on 3D printers.
                    Phaedrux Moderator @JRCL
                    You've circled the PWM3 header, but the command you posted was for PWM2 M950 S1 C"!duex.pwm2"
                    Which is it?
                    Assuming it matches and it was just a typo, does the servo make any noise or get warm when you try and activate it?
                    Can you send M950 S1 by itself and report back the reply?
                    Can you try with some different PWM frequencies by adding a Q parameter to the M950 command?
                    M950 S1 C"!duex.pwm2" Q50 perhaps
                      alankilian @JRCL
                      @jrcl
                      Can you post the manufacturer and part number for your 24-to-5 Volt converter?
                      • JRCLundefined
                        JRCL @Phaedrux
                        @phaedrux Are they not grouped like this? I figured it was just a naming convention for the pin (E3_PWM) went with the PWM number (PWM2) and I saw this on the pin name table too and thought I still called C"duex.pwm2" though the control pin is called E3_PWM
                        • JRCLundefined
                          JRCL @alankilian
                          @alankilian Tobsun EA75-5V
                            alankilian @JRCL
                            @jrcl
                            I can't tell if that's isolated or not.
                            If you've got everything else figured out, try connecting the two grounds together at the converter.
                            • fcwiltundefined
                              fcwilt @alankilian
                              @alankilian said in Servo Configuration Check:
                              @jrcl
                              Without knowing how the unit is designed that might be unwise.
                              JRCLundefined alankilianundefined 2 Replies Last reply Reply Quote 0
                              • JRCLundefined
                                JRCL @fcwilt
                                @fcwilt Agreed, it's a buck converter if that makes any difference, but it does seem like that would allow the full power load to pass through the Duex and potentially fry the rail. Ordering the recommended MG995, from the servo wiki, to test against at least for now.
                                • fcwiltundefined
                                  fcwilt @JRCL
                                  It could be fine, it could be destructive - without word from the manufacturer you just don't know.
                                  Since it seems you have no test equipment even the lack of destruction would not insure it was actually working - it might just shutdown if wired incorrectly.
                                  I went ahead and ordered one. I should be able to determine if the output is isolated. If so you would need to connect the grounds together. I will let you know what I find.
                                  JRCLundefined 1 Reply Last reply Reply Quote 1
                                  • JRCLundefined
                                    JRCL @fcwilt
                                    @fcwilt You're too kind, appreciate the above and beyond support on this
                                    • fcwiltundefined
                                      fcwilt @JRCL
                                      Glad to be of help when I can.
                                        alankilian @fcwilt
                                        @fcwilt said in Servo Configuration Check:
                                        @jrcl
                                        @JRCL
                                        It's perfectly safe to connect the grounds together on an isolated-output converter.
                                        It just makes it into a nonisolated converter.
                                        Ref: (A poor reference, but nonetheless) https://electronics.stackexchange.com/questions/35800/should-i-isolate-grounds-of-an-isolated-dc-dc-converter
                                        https://electronics.stackexchange.com/questions/181088/connecting-grounds-when-using-an-isolated-dc-dc-converter
                                        • JRCLundefined
                                          JRCL @alankilian
                                          @alankilian ohhhh I see I thought you meant to use the onboard ground but positive off the converter. I will give this a try then. Redoing all the wiring on the servo too to be safe too
                                            alankilian @JRCL
                                            @jrcl It's just a lart-ditch effort.
                                            A US$10 converter is almost certainly not isolated, so I don't think this is your problem, but sometimes when you have verified everything else is right, you've got to try something.
