    Servo Configuration Check
    Using Duet Controllers
    1.7k
    • JRCLundefined
      JRCL @fcwilt
      @fcwilt You're too kind, appreciate the above and beyond support on this
      • fcwiltundefined
        fcwilt @JRCL
        @jrcl said in Servo Configuration Check:
        Glad to be of help when I can.
        • alankilianundefined
          alankilian @fcwilt
          @fcwilt said in Servo Configuration Check:
          @alankilian said in Servo Configuration Check:
          @jrcl
          I can't tell if that's isolated or not.
          If you've got everything else figured out, try connecting the two grounds together at the converter.
          Without knowing how the unit is designed that might be unwise.
          @JRCL
          It's perfectly safe to connect the grounds together on an isolated-output converter.
          It just makes it into a nonisolated converter.
          Ref: (A poor reference, but nonetheless) https://electronics.stackexchange.com/questions/35800/should-i-isolate-grounds-of-an-isolated-dc-dc-converter
          https://electronics.stackexchange.com/questions/181088/connecting-grounds-when-using-an-isolated-dc-dc-converter
          JRCLundefined 1 Reply Last reply Reply Quote 0
          • JRCLundefined
            JRCL @alankilian
            @alankilian ohhhh I see I thought you meant to use the onboard ground but positive off the converter. I will give this a try then. Redoing all the wiring on the servo too to be safe too
              alankilian @JRCL
              @jrcl It's just a lart-ditch effort.
              A US$10 converter is almost certainly not isolated, so I don't think this is your problem, but sometimes when you have verified everything else is right, you've got to try something.
              • JRCLundefined
                JRCL @alankilian
                @alankilian Agreed! Worth the attempt, but alas it didn't fix the problem.
                • fcwiltundefined
                  fcwilt @JRCL
                  It may be the signal from the Duet is not compatible. I can measure the signal and tell you about it. Perhaps you can determine if it is/is not compatible with your servo.
                    Phaedrux Moderator @JRCL
                    @phaedrux Are they not grouped like this? I figured it was just a naming convention for the pin (E3_PWM) went with the PWM number (PWM2) and I saw this on the pin name table too and thought I still called C"duex.pwm2" though the control pin is called E3_PWM
                    Yes you're right. Sorry about that. Not enough coffee.
                    • JRCLundefined
                      JRCL
                      Just an aside. Got in my MG995S servo and swapped it out and was rewarded with immediate success. Still interested in hearing your findings on the higher torque servo signal @fcwilt
                      • fcwiltundefined
                        fcwilt @JRCL
                        Could you post a link to the servo that is not working for you?
                        JRCLundefined 1 Reply Last reply Reply Quote 1
                        • JRCLundefined
                          JRCL @fcwilt
                          @fcwilt
                          https://www.amazon.com/Youleke-Torque-Digital-Servo,Waterproof-Horn(270°)/dp/B08739MGPL/ref=sr_1_4?crid=HHSQAXOVWT74&keywords=BETU+2Pack+25KG+High+Torque+RC+Servo&qid=1650928661&s=toys-and-games&sprefix=betu+2pack+25kg+high+torque+rc+servo%2Ctoys-and-games%2C73&sr=1-4
