    No Step/Dir Signal from Duet 3 Expansion 1XD
    Accessories and Add-ons
    3.1k
    • alankilianundefined
      alankilian @Jered
      @jered said in No Step/Dir Signal from Duet 3 Expansion 1XD:
      I do not see that the wires are swapped I double checked.
      You are right, sorry about that.
      Jeredundefined 1 Reply Last reply Reply Quote 0
      • Jeredundefined
        Jered @dc42
        Ok, I will try and do that. I am not familiar with updating, so it may take me a while. When I click on the link for the latest update for the 1xd board, it brings me to the latest update for the main board. So I am not sure where to get it.
        I am connected to an SBC, so, is there an easy way to do it from there?
        • Jeredundefined
          Jered @alankilian
          @alankilian
          Ok, updated everything. It was a lot easier that I thought.
          However, I did try and move the machine and it moved!!
          Looks like updating the firmware worked! Thanks so much!
          Now I will have to get the steps/units correct and keep going.
          Does this forum allow me to post a link to a vid on youtube? I wanted to make a short vid for you guys so you can see what I am doing. It is very different from everyone else.
          Thanks Again!!
          • Jeredundefined
            Jered
            Whelp,
            That celebration was short lived. The movement of the machine is that of a non corexy. It moves only the X axis motor when commanded to move and the Y axis motor when moved in Y. It should be using both motors to move in X and Y. It is using the correct 1xd board for moving the motors, its just not moving both to get a movement in the X or Y direction. Instead, it move in a diagonal motion due to only one of the motors moving.
            In the config,
            M584 X40.0 Y41.0 Z42.0:43.0:125.0 E0.0:0.1:0.2:0.3:0.4:0.5:1.1 ; set drive mapping
            X and Y are designated only one address, but in core xy it uses both, so is the line above correct? The Z has 3 motors and is addressed as such. Should x and y be similar?
            • Jeredundefined
              Jered @Jered
              So, I have been testing this with the home x and home y buttons on the dash board (then quickly triggering the home switches) and the axis move like they should, except the y is backwards. When ever the H2 command is given, only the motor designated x or y moves. What is the H2 command? How do I invert the y home position? I can change the homey.g file and it moves correctly. Not sure if this is the correct way.
                Post your homing files.
                The homing direction is controlled in the homing files to be either positive or negative. Which direction that actually ends up being depends on the direction of rotation defined in M569 setting up the motor. The endstop position is defined in M574 to be either on the high (positive end) or low (negative end). And all of that is subject to creating a right hand coordinate system with 0,0 in the front left, +x moves right, -x moves left, +y moves back, -y moves to the front.
                  @jered your config.g file is set up for a Cartesian machine because it has no M669 command to select CoreXY mode.
                  • Jeredundefined
                    Jered @dc42
                    It does have M669 command and is set up for core xy. See line 11.
                    In Use Config.txt
                    I would still like to know what H2 is. It seems to take the machine out of core xy mode. In the homing files there is also an H2 command which makes the machine move funny when it backs off the home sensor. See below.
                    M201 X500.00 Y500.00 ; Reduce acceleration for homing moves
                    G91 ; Relative positioning
                    G1 H2 Z5 F6000 ; Lift Z relative to current position
                    G1 H1 Y-605 F3600 ; Move quickly to Y endstop and stop there (first pass)
                    G1 H2 Y5 F600 ; Go back a few mm
                    G1 H1 Y-605 F360 ; Move slowly to Y endstop once more (second pass)
                    M201 X3000 Y3000 ; Return to full acceleration
                    G1 H2 Z-5 F6000 ; Lower Z relative to current position
                    G90 ; Absolute positioning
                    This H2 is in all the homing files. The one above is for the Y. When this H2 is in the command line only the designated motor moves, not both. To be clear, only the motor with the address Y will move in this example, G1 H2 Y5 F600.
                    I was hoping to have my machine home to the back left. Will this be a problem? Should I move my sensors or change the files mentioned? If I can change the homing definitions, that would be fine and a bit easier.
                      dc42 administrators @Jered
                      @jered I'm sorry, I was using a smartphone last time I replied and I missed that line.
                      G1 H2 moves are always raw motor moves, so will move only one of the motors. To move a few mm in the -Y direction you can use:
                      G1 H2 X-5 Y5 F600
                      To move a few mm in the -X direction, use:
                      G1 H2 X-5 Y-5 F600
                      • Jeredundefined
                        Jered @dc42
                        This is off topic, but the warranty from is asking me for the serial # of the bad 1xd board, but there isn't one that I can see. The form says there is a sticker on the back of the board with this number on it, there is no sticker. See pics
                        alankilianundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                          alankilian @Jered
                          @jered
                          I ran the RRF configurator and selected COREXY and none of the homeing.g files have any H2 moves in it for any axis other than Z.
                          Maybe you should rerun the configurator and generate new files?
                          (I don't know, I'm just trying to help, so if I'm wrong, I'm sorry.)
                          ; homey.g
                          ; called to home the Y axis
                          ; generated by RepRapFirmware Configuration Tool v3.3.10 on Wed Apr 27 2022 12:58:17 GMT-0400 (Eastern Daylight Time)
                          G91               ; relative positioning
                          G1 H2 Z5 F6000    ; lift Z relative to current position
                          G1 H1 Y-215 F1800 ; move quickly to Y axis endstop and stop there (first pass)
                          G1 Y5 F6000       ; go back a few mm
                          G1 H1 Y-215 F360  ; move slowly to Y axis endstop once more (second pass)
                          G1 H2 Z-5 F6000   ; lower Z again
                          G90               ; absolute positioning
                            Phaedrux Moderator @Jered
                            @jered Don't worry about the serial number. Usually that would be on the mainboard.
                            • Jeredundefined
                              Jered @Phaedrux
                              @phaedrux
                              About the homing location. I have the switches setup for the machine to home to the back left. Is this ok, or should I move the switches? I am not sure what a typical machine homing location should be.
                              With the cnc machines that I design, all homing is to the front left.
                                @jered you can have the homing switches in any corner you like. Back left would normally be X min and Y max, so that +Y moves towards the back and +X to the right. Your M574 commands in config.g and homing movement commands in the homing files must be set up accordingly.
                                • Jeredundefined
                                  Jered @dc42
                                  Thank you guys for being such good help!
                                  After the machine homes (which it is doing just fine), I want it to move off the sensors 5mm and then set that position as 0,0. Is that possible? I have edited the home files so that it moves off 5mm from the sensors, but noticed the machine sees that it is 5mm of each axis. I want it to think that offset is 0,0. Is there a command that sets the home positions?
                                  I did also try and edit the config file and set the min positions to 5,5 but the machine showed it was off by 5mm from home, so that didn't work.
                                    You have two options, either use G92 X0 Y0 after you have moved off by 5mm, or you can set the axis minima in M208 to x-5 y-5 so that the 0,0 point would be 5mm away from the endstop.
                                    • Jeredundefined
                                      Jered @Phaedrux
                                      Thanks again guys for your help! Here is a vid so you can see a bit more of what I am doing.
                                      Multi Filament Vcore 3
                                      deckingmanundefined 1 Reply Last reply Reply Quote 2
                                        It's looking good. We're always here to help.
                                          alankilian @Phaedrux
                                          @phaedrux This super great.
                                          It's clear you now how to build bullet-proof machines.
                                          Very well done man.
                                          Thanks for the video.
                                          • Jeredundefined
                                            Jered @alankilian
                                            Just curious, is the a way to auto tune 2 heater outputs at the same time due to the fact that they are using the same TC and are working together? My hot end has to heater cartages connected to their own output.
