    slowing down a non-powered stepper motor
    852
    • mrehorstdmdundefined
      mrehorstdmd @fma
      @fma In that case, two motors might not be such a good idea as they jump to random positions when powered up. If you use a single motor and put the bed on a stable mount you probably won't need autoleveling. My printer doesn't use it- just a flat cast aluminum plate with a heater that is the same size as the bed. The bed plate sits on a kinematic mount that requires adjustment at two screws to tram the bed. The last time I did it was almost a year ago. When I do adjust it, I use the manual bed leveling assistant in RRF. It takes about a minute. The tooling plate with a layer of PEI is flat enough to print edge to edge with a 0.2 mm first layer.
      I tried braking by shorting the motor windings before I got the worm gear setup. My printer's Z axis is almost 700mm long and the bed assembly weighs about 3.5 kg. The shorted motor slowed the drop a bit initially, but by the time it was about 1/2 way down, it had acquired enough speed that it might as well have been in freefall.
      fmaundefined 1 Reply Last reply Reply Quote 0
      • fmaundefined
        fma @mrehorstdmd
        @mrehorstdmd My current printer uses a cantilever bed, and I almost never adjust it! The next one will be even more rigid, but will weight almost 4kg :o/ So, I will go for a 5:1 geared motor, it will solved a lot of problems.
        BTW, guys, how do you connect the belt to the Z carriage (bed)? Do you use an open belt, or a closed one?
        Frédéric
        • fcwiltundefined
          fcwilt @fma
          @fma said in slowing down a non-powered stepper motor:
          I don't understand your question. Can you elaborate?
          • fmaundefined
            fma
            When using a belt to lift the bed, is it better to use an open one, or a loop? And how to you clamp it to the bed?
            And is a width of 6mm enough, or should I go for 9mm?
            Frédéric
            • fcwiltundefined
              fcwilt @fma
              I cannot visualize how it would be done without using a loop of some sort.
              Well on my printers it is done like this. Hope this is enough detail. If not ask for more.
              I played it safe and used 9mm.
              • fmaundefined
                fma
                Thanks for the picture! I had the motor turned 90°, which is not as good as your solution!
                About the belt: it belt can be one big closed loop, or a cut part. I have the feeling that a closed loop will be more robust, and less prone to break...
                Frédéric
                fcwiltundefined mrehorstdmdundefined 2 Replies Last reply Reply Quote 0
                  mrehorstdmd
                  I use 2x 9 mm glass core belts to lift the 3.5 kg bed assembly in my printer.
                  I measured belt stretch using both steel core and glass core belts. The glass core belts (Gates LL2MR09) stretch about 3x the steel core belts, but for the stuff I print, it doesn't matter.
                  See: https://drmrehorst.blogspot.com/2018/12/comparing-steel-core-and-glass-core.html
                  I had an interesting failure in a belt clamp when I was using steel core belts: https://drmrehorst.blogspot.com/2018/12/another-interesting-3d-printer-failure.html Don't do what I did!
                  This is the business end of the Z axis- I uses a 30:1 worm gear reducer to turn a shaft with two 60 tooth pulleys that lift the bed assembly.
                  The photo was taken when I was still using steel core belts (before the clamp failure) which have since been swapped for glass core GT2 belts. At the top of the Z axis there are just two pulleys made from stacked F608 skate bearings (which I also used in the XY stage).
                  • fcwiltundefined
                    fcwilt @fma
                    The belt looks like a loop since the cut ends are clamped under those green pieces in the drawing which have ridges on the surface you cannot see which match the belt.
                    The idler pulley at the top, which you cannot see in the image, is adjustable to set belt tension.
                      mrehorstdmd @fma
                      @fma I used open belt formed into a loop by clamping the ends in printed clamps that mount on the Z axis bearing blocks. No closed loop belt is needed. I initially used a simple slot type clamp that failed with steel core belt so I switched to a clamp similar to one I printed and is still working after about 6 or 7 years. You simply fold the belt back on itself and feed the folded part through a slot that keeps the teeth interdigitated. Like this:
                      The center of the loop in the clamp can be printed (as I did) or it can be the screws that hold the clamp to the bearing block (as was done here) or to a bracket that attaches to the bearing block:
                      • fmaundefined
                        fma
                        Thank you very much for your answers!
                        Frédéric
                        breedundefined 1 Reply Last reply Reply Quote 0
                        • breedundefined
                          breed @fma
                          @fma could also drive you z belt with a worm gearbox. Worm gears can't be back driven.
                          • fmaundefined
                            fma @breed
                            @breed yes, that's mrehorstdmd's solution.
                            Frédéric
