    External Pause/Resume Button
    Gcode meta commands
    1.9k
    • burtonenatorundefined
      burtonenator
      I'm trying to setup an external physical button that will pause and resume a job. I currently can pause from the button as expected, but I cannot resume.
      I've setup a trigger and a file so that I can add logic, but my basic attempt seems to have failed, is there anyway to get the printing state from a macro, I've seen that it'll always show busy, but that didn't seem to match either.
      My current trigger:
      if 	state.status == "Paused"
      	M24
      if 	state.status == "Printing"
      	M25
      I pause by just replacing that with M25
      OwenDundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
      • OwenDundefined
        OwenD
        By your description it may be that you have not indented your code.
        Looks like you corrected while I was writing.
        If it's actually written as you have posted then the if statements won't do anything and it will execute each line in turn, with M25 being the last.
        Also you need to use the correct object model names and they are case sensitive .
        These are listed here
        The status you see in DWC seems to be altered from that in the object model for readability.
        so the correct code for what you have written would be
        if state.status == "paused"
            M24
        elif state.status =="printing"
            M25
        You may find however that as soon as your macro starts, the machine status will become "busy" or "processing" because it's running the macro.
        To get around that and to use a single button you could set up your trigger like this
        In config.g set up a global variable
        if !exists global.lastPress ; if it's not created we do so now
            global lastPress = false
        then in your trigger do this
        if job.file.fileName !=null ; if there's a job filename then it's reasonably safe to say we are printing
           if global.lastPress == false ; the button hasn't been pressed so we'll pause
              M25
           else
             M24
           set global.lastPress = !global.lastPress ; toggle the value from whatever it was before use "not"
        • OwenDundefined
          OwenD @burtonenator
          @burtonenator
          You will also likely have to to some code in place to avoid issues with "bouncing", where the contacts make and break a few times when you press it.
          Something like this at the start of your trigger will ensure you have to hold the button down for an extended period.
          Change the gpIn number to suit where you have your button connected
          G4 S1 ; put a delay in as your first line,  The buttin must be held longer than this.
          if sensors.gpIn[7].value != 1 ; the button isn't still pressed so we'll abort the macro
             echo "Button wasn't pressed long enough" ; remove this line when done testing
             M99 ; cancel macro
                M25
             else
               M24
          burtonenatorundefined 1 Reply Last reply Reply Quote 0
            burtonenator @OwenD
            @owend
            So I gave this a try, but it now triggers the pause, and then immediately the resume.
            I don't see your "Button wasn't pressed long enough" error, even if I push very quickly, and it always does the pause resume, even when I did a longer dwell.
            G4 S5				 ; put a delay in as your first line,  The button must be held longer than this.
            if sensors.gpIn[9].value != 1 ; the button isn't still pressed so we'll abort the macro
            	M99 ; cancel macro
            	if global.PausePress == false ; the button hasn't been pressed so we'll pause
            		echo "Pause"
            		M25
            	else
            		echo "resume"
            		M24
            	set global.PausePress = !global.PausePress ; toggle the value from whatever it was before use "not"
            important parts of config.g:
            ;Pause Button
            M950 J9 C"io8.in"
            M581 P9 T2 S1
            global PausePress = false
            and the console:
            5/7/2022, 6:01:39 PM	Printing resumed
            5/7/2022, 6:01:35 PM	resume
            5/7/2022, 6:01:29 PM	Printing paused at X207.1 Y192.9 Z6.6
            5/7/2022, 6:01:24 PM	Resume state saved
            5/7/2022, 6:01:24 PM	Pause
            • fcwiltundefined
              fcwilt @burtonenator
              @burtonenator
              Take the safe and reliable route - use two buttons.
              • OwenDundefined
                OwenD
                I suspect it's being invoked twice. So the de-bouncing logic isn't working.
                Maybe reverse it and use a small delay
                Try
                echo "called at " ^ state.time
                G4 P10 ; delay 10ms to debounce
                if sensors.gpIn[9].value=0
                	M99 ; break out if sensor value is zero again (bouncing)
                as your first line.
                I expect a different time for the pause and resume lines.
                Do you see the value of the input change in the input model?
                It would be much easier to use two buttons.
                burtonenatorundefined 1 Reply Last reply Reply Quote 1
                  burtonenator @OwenD
                  @owend
                  This seems to work, although I don't understand why it does and what I had before doesn't:
                  ;echo "called at " ^ state.time
                  G4 P1 ; delay 1ms to debounce
                  if sensors.gpIn[9].value=1
                  	;echo "debounce"
                  		;echo "Pause"
                  		M25
                  	else
                  		;echo "resume"
                  		M24
                  Even with the delay debounce 1ms it now works as expected, So Thank you!
                  As for the 2 buttons debate, these buttons are way to cool, and lend themselves to the "One button Pause/Resume" idea:
                  Lit Indicator Buttons
                  I light and dim the LED in the pause and resume macros so the button is a correct indicator. You can even put a label behind the plastic to mark what its for. The LED is a bit dim on the 3.3v from the output, but I think I can deal with that now that I have this working
                  OwenDundefined Nightowlundefined 2 Replies Last reply Reply Quote 1
                  • OwenDundefined
                    OwenD @burtonenator
                    @burtonenator
                    The reason it didn't work before is that when the button bounced it called the macro twice in succession.
                    The long delay was masking this.
                    • Nightowlundefined
                      Nightowl @burtonenator
                      This is a really interesting thread, @burtonenator, thank you. I'm looking for a way to pause and resume the machine (in my case a CNC machine) with a normally open switch, which you seem to have done here. First press to pause, subsequent press to resume. This was referred to as a "feed hold" switch on my Shapeoko, but it wasn't completely workable with an external switch, so I'm hoping this solution is what I'm looking for on Duet3 MB6HC-controlled machine.
                      Although a flagrant abuse of the code you've shown here (sorry!) is it necessary to have Pause and Resume macros, as I can't see how they are 'called' from this code - or is that what the global.PausePress line refers to?
                      I'm also assuming the : Pause button lines in the config.g file are necessary, too?
                      As you can guess, I'm completely new to this, particularly programming the Duet!
                      I also noted @fcwilt's comment about using two buttons, which the direction I'd probably go in if I can't wrangle your code to fit with my machine.
                      Few things are more dangerous than taking the advice of someone who thinks he knows what he's doing.
                      I'm still on my learning curve, so take everything I say with caution!
                      RatRig 1075, Duet3 MB6HC, Sorotec SFM 1000 PV-ER milling motor, Hobbyist
                        burtonenator @Nightowl
                        So far this has worked well for me, the only issue is I do have to push the button until the command is recognized, so if the printer is doing a long line, it won't catch unless I have the button down at the end of the line before the next command goes in. This is probably expected and its not that big an issue in practice.
                        @nightowl999
                        This is all the magic from the config.g side, its the "T2" that sets it to run the second trigger file (trigger2.g) when the button is pushed.
                        ;Pause Button
                        M950 J9 C"io8.in"
                        M581 P9 T2 S1
                        ;if !exists global.PausePress ; if it's not created we do so now
                        trigger2.g, its the M24 and M25 that actually call the pause and resume files :
                        G4 P1 ; delay 10ms to debounce
                        	;echo "debounce"
                        		;echo "Pause"
                        		M25
                        	else
                        		;echo "resume"
                        		M24
                        turning the light on and off was the easy part, just turn the pin for that on or off:
                        M42 P8 S0 ;LED off
                        and its magic in config.g:
                        ;output for pause LED
                        M950 P8 C"io8.out"
                        M42 P8 S0 ; off by default
                        Nightowlundefined 3 Replies Last reply Reply Quote 1
                        • Nightowlundefined
                          That's awesome, thank you @burtonenator!
                          I see you're using "io8" for this (I'll have to change that to io1 as I'm already using io2, 3, 6 and 8!) but I think that should be fairly straightforward.
                          I also understand the "; Pause Button" and "; output for pause LED" lines of code are in the config.g file and the code for the M24 and M25 commands are in the trigger.g file, but what I'm not clear on is where the two M42... lines go. Are these in the config.g file too?
                          I think I've pretty much got the pin outs clear in my head too, but the LEDs in my switch (I think) are 12v, so I may need to get the +ve feed for that elsewhere, probably OUT7, 8 or 9.
                          Anyway, I'm off to experiment!
                          Thanks again!
                            @nightowl999
                            I have the initial M42 in the config.g because it does actually start with that on, so this sets it off, and then after that its in the pause and resume to set it correctly when pressed.
                            Yea, the out on the io's is 3.3v, I needed a transistor to bring it up to 5v for my LED, which in that one I showed above lists as 12v but looks great at 5v
                            oliofundefined Nightowlundefined 2 Replies Last reply Reply Quote 1
                            • oliofundefined
                              oliof @burtonenator
                              @burtonenator if you used M950 P8 C"!io8.out"you could skip the M42 IIRC.
                              • Nightowlundefined
                                @burtonenator said in External Pause/Resume Button:
                                Following on from this comment, what in 3D printing terms is "...a long line"? I appreciate this is the code within the gcode file, obviously 🙂 , but i'm not familiar with how travel speed/time on a 3D printer compares to that of a CNC machine.
                                Is it a case of CNCers savagely cut their way through stock while 3D printers gently weave their way?
                                Thanks
                                  Phaedrux Moderator @Nightowl
                                  @nightowl999 said in External Pause/Resume Button:
                                  .a long line
                                  It means that each command would execute and complete before an interruption/pause could take effect before the next command is executed.
                                  You can reduce this effect by increasing the segmentation value. This breaks long running commands up into smaller sections which allows the interruption to happen sooner.
                                  See the details on the M669 command for how to configure segmentation.
                                  https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m669-set-kinematics-type-and-kinematics-parameters
                                  Nightowlundefined 1 Reply Last reply Reply Quote 1
                                  • Nightowlundefined
                                    Nightowl @Phaedrux
                                    Sorry, I was being slightly flippant, @phaedrux, although it would be interesting to know how these things compare.
                                    I can cut a a 12" slot in a piece of hardwood with a 1/4" end mill quite qhickly, but I guess it would take a lot longer for a 3D printer to build a 1/4" square bar 12" long quite a bit longer, but I suppose it's trying to compare apples and pears...
                                      It's not about the time or speed it takes, it's about the gcode command itself which would be the same in CNC or 3d printer. The point being that in order to interrupt a command in progress it must be segmented to stop it mid execution.
                                      • Nightowlundefined
                                        Nightowl @Phaedrux
                                        @phaedrux I'm being a plum. I was getting confused with another thread! Sorry.
                                        No, this question was really about the delay when activating the pause command for the external switch.
                                        • fcwiltundefined
                                          fcwilt @Nightowl
                                          I like pears but my wife doesn't.
                                          • Nightowlundefined
                                            Nightowl @fcwilt
                                            @fcwilt 🙄 🙂 🙂
