    auto calibration
    1.1k
    • trublu89undefined
      trublu89
      Hello all, I have been fighting with trying to get this corexy calibrated to get a consistent first layer all day. It seems like one minute it's fine then the next its back out of skew.
      I'm running a core xy with 4 lead screws. I tried using g32 and now g29 both work fine one minute then one of the points wont trigger. ```
      ; bed.g
      ; generated by RepRapFirmware Configuration Tool v3.3.10 on Fri Dec 17 2021 18:35:59 GMT-0600 (Central Standard Time)
      G28 ; home
      G30 P0 X50 Y25 Z-99999 ; probe near a leadscrew
      G30 P1 X50 Y420 Z-99999 ; probe near a leadscrew
      G30 P2 X480 Y420 H-2 Z-99999 ; probe near a leadscrew
      G30 P3 X480 Y25 H-1 Z-99999 S4 ; probe near a leadscrew and calibrate 3 motors
      M569 P0 S1                                                    ; physical drive 0 goes forwards
      M569 P1 S1                                                   ; physical drive 1 goes forwards
      M569 P2 S1                                                    ; physical drive 2 goes forwards
      M569 P3 S0                                                    ; physical drive 3 goes forwards
      M569 P4 S1                                                    ; physical drive 4 goes forwards
      M569 P5 S0
      M569 P6 S0
      M584 X0 Y1 Z2:4:5:6 E3                                          ; set drive mapping
      M350 X16 Y16 Z16:16:16:16 E16 I1                                 ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z400.00:400.00:400.00:1600.00 E158.49            ; set steps per mm
      M566 X900.00 Y900.00 Z20.00:20.00:20.00:20.00 E120.00               ; set maximum instantaneous speed changes (mm/min)
      M203 X24960.00 Y24960.00 Z24960.00:24960.00:24960.00:24960.00  E7980.00 ; set maximum speeds (mm/min)
      M201 X3000.00 Y3000.00 Z80.00:80.00:80.00:80.00 E500.00             ; set accelerations (mm/s^2)
      M906 X800 Y800 Z950:90:950:950 E800 I30                          ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                                       ; Set idle timeout
      M208 X0 Y0 Z0 S1                                              ; set axis minima
      M208 X520 Y480 Z790 S0                                        ; set axis maxima
      M574 X1 S1 P"xstop"                                           ; configure switch-type (e.g. microswitch) endstop for low end on x via pin ystop
      M574 Y1 S1 P"ystop"                                           ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
      M574 Z1 S2                                                    ; configure Z-probe endstop for low end on Z
      M558 P1 C"zprobe.in" H6 F120 T10000                          ; set Z probe type to unmodulated and the dive height + speeds
      G31 P500 X0 Y0 Z0.192                                           ; set Z probe trigger value, offset and trigger height
      M557 X45:485 Y50:424 S80                                     ; define mesh grid
      ;M140 H-1                                                      ; disable heated bed (overrides default heater mapping)
      ;M308 S0 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8        ; define E0 temperature sensor
      ;M950 H0 C"e0heat" T0                                          ; create nozzle heater output on e0heat and map it to sensor 0
      ;M307 H0 B0 S1.00                                              ; disable bang-bang mode for heater  and set PWM limit
      ;M143 H0 S270                                                  ; set temperature limit for heater 0 to 270C
      ;M570 S360						      ; allow one minute for fault detection
      M950 F0 C"fan0" Q500                                          ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1                                                ; set fan 0 value. Thermostatic control is turned off
      ;M308 S0 P"bedtemp" Y"thermistor" T100000 B4267 C7.06e-8 ; configure sensor 0 as thermistor on pin bedtemp
      ;M950 H0 C"bedheat" T0                                   ; create bed heater output on bedheat and map it to sensor 0
      ;M143 H0 S130                                            ; set temperature limit for heater 0 to 130C
      ;M307 H0 B0 S1.00                                        ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H-1                                                 ; map heated bed to heater 0
      M308 S1 P"e0temp" Y"thermistor" T100000 B4267 C7.06e-8  ; configure sensor 1 as thermistor on pin e0temp
      M950 H1 C"e0heat" T1                                    ; create nozzle heater output on e0heat and map it to sensor 1
      M143 H1 S275                                            ; set temperature limit for heater 1 to 275C
      M307 H1 B0 S1.00                                        ; disable bang-bang mode for heater  and set PWM limit
      ;Lead screw position
      M671 X45:45:485:485Y45:424:424:45  s5
      M563 P0 D0 H1 F0
      ;G10 P0 X0 Y0 Z0                                               ; set tool 0 axis offsets
      ;G10 P0 R0 S0 T0                                                 ; set initial tool 0 active and standby temperatures to 0C
      M501                                                          ; load saved parameters from non-volatile memory
      ; Automatic power saving
      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
      attached are my bed and config files.
      fcwiltundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
      • fcwiltundefined
        fcwilt @trublu89
        @trublu89
        Not sure what you mean by "tried using G32 and now G29" - those are two totally different things.
        G32 is for invoking bed.g to level the bed.
        G29 is for invoking mesh.g to create the heightmap needed for using the Mesh Bed Compensation feature.
        I don't see it in your code but there are certain times when you need to set the Z=0 Datum using a single G30 at a consistent XY location.
        • after bed leveling
        • before creating a heightmap
        • before loading a heightmap
        Also what sort of Z probe do you have that has a X offset of 0 and a Y offset of 0?
        trublu89undefined 1 Reply Last reply Reply Quote 0
        • trublu89undefined
          trublu89 @fcwilt
          @fcwilt I've been out of the 3d printing loop for a while lol. I'm using the ir height sensor. I never really set offsets for the probe it just worked.
          so would I use a G92 to set z to zero?
          • fcwiltundefined
            fcwilt @trublu89
            @trublu89 said in auto calibration:
            In the G31 command there is the Z parameter which sets the probe Z Trigger Height value.
            When you execute a G30 the probe and bed move toward one another and when the probe triggers the logical Z axis position is set to the value of the G31 Z Trigger Height parameter value.
            So let's assume that value is 5 mm. G30 executes, the probe and bed move, the probe triggers, the logical Z axis position is set to 5 mm and then the probe and bed move apart based on the values of the G31 Z Trigger Height parameter and the M558 H parameter.
            If the physical Z axis position at the moment the probe was triggered was actually 5 mm then the physical Z axis position and the logical Z axis position are in sync.
            If the G31 Z Trigger Height parameter was too large or too small then the physical Z axis position and the logical Z axis position would be out of sync and any Z axis moves would result in the physical Z axis position being incorrect.
            So it is essential that the correct value for the G31 Z Trigger Height parameter is determined with very good accuracy.
            You can determine the correct value by trial-and-error or by using a reference object of known height.
            I can explain how to do that if needed.
              Phaedrux Moderator @trublu89
              You mean that it will move to the probe points but randomly the probe doesn't trigger? Meaning a nozzle crash? An error message?
              You can test and calibrate your probe following this: https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_testing
              • trublu89undefined
                trublu89 @Phaedrux
                @phaedrux it won't even crash it will just stop before reaching it. And sometimes the margin of error is -9.
                Now I'm getting a temperature excursion error I'm printing at 230 it will jump to 250 I paid tuned several times. Tried with fan on didn't realize the fan comes on with the newer firmware.
                • fcwiltundefined
                  fcwilt @trublu89
                  What do you mean by "reaching it" - what does "it" refer to?
                  • trublu89undefined
                    trublu89 @fcwilt
                    @fcwilt
                    right before it tries to trigger it will just stop and error out probe was not triggered during move.
                    • fcwiltundefined
                      fcwilt @trublu89
                      @fcwilt
                      That is usually caused by starting to probe to far from the bed.
                      Does the probe move smoothly towards the bed?
                      • trublu89undefined
                        trublu89 @fcwilt
                        @fcwilt
                        I have the ir probe and my lead screws are independent driven by motors.
                          The offsets for the probe look suspect
                          There is no X Y offset from the nozzle so the firmware doesn't know where the probe actually is. And the trigger height seems very small.
                          Have you gone through this yet? https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_testing
                          This command to define your lead screw positions may not be registering correctly because there is a missing space between the X and Y values and an extra space before the S.
                          Can you also post your homeall.g and config-override.g?
                          It would also be nice to see the results of sending M122 and M98 P"config.g" in the gcode console.
                          Does this happen consistently in the space spot? Or totally randomly?
                          What is your bed surface? The IR probe can be sensitive to reflective or multicolor surfaces. You can try and eliminate this by putting a plane piece of white paper on your bed.
                          It would also be good to get some close up photos of the IR probe itself incase it is damaged in some way.
                          trublu89undefined 1 Reply Last reply Reply Quote 1
                          • trublu89undefined
                            trublu89 @Phaedrux
                            @phaedrux
                            I didn't realize there was a gap in my m671
                            That's how I came up with .192 homing to where the paper grabbed the nozzle and g92 z=0 g30 s1 to get the mean results.
                            ; homeall.g
                            ; called to home all axes
                            G1 H2 Z5 F108000        ; lift Z relative to current position
                            G1 H1 X-565 Y-535 F1800 ; move quickly to X or Y endstop and stop there (first pass)
                            G1 H1 X-565             ; home X axis
                            G1 H1 Y-535             ; home Y axis
                            G1 X5 Y5 F108000        ; go back a few mm
                            G1 H1 X-565 F360        ; move slowly to X axis endstop once more (second pass)
                            G1 H1 Y-535             ; then move slowly to Y axis endstop
                            G90                     ; absolute positioning
                            G1 X32 Y50 F108000      ; go to first bed probe point and home Z
                            G30                     ; home Z by probing the bed
                            ; config-override.g file generated in response to M500 at 2022-05-14 23:47
                            ; Heater model parameters
                            M307 H1 R1.925 K0.303:0.261 D5.51 E1.35 S0.90 B0 V12.2
                            ; Workplace coordinates
                            G10 L2 P1 X0.00 Y0.00 Z0.00
                            G10 L2 P2 X0.00 Y0.00 Z0.00
                            G10 L2 P3 X0.00 Y0.00 Z0.00
                            G10 L2 P4 X0.00 Y0.00 Z0.00
                            G10 L2 P5 X0.00 Y0.00 Z0.00
                            G10 L2 P6 X0.00 Y0.00 Z0.00
                            G10 L2 P7 X0.00 Y0.00 Z0.00
                            G10 L2 P8 X0.00 Y0.00 Z0.00
                            G10 L2 P9 X0.00 Y0.00 Z0.00
                            What is the config overide g? I never really looked in there.
                            M122
                            RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.0 (2022-03-15 18:58:31) running on Duet WiFi 1.02 or later + DueX5
                            Board ID: 08DGM-956GU-DJMSN-6JKF2-3S86L-TBRVG
                            Used output buffers: 3 of 24 (16 max)
                            Static ram: 23868
                            Dynamic ram: 74744 of which 0 recycled
                            Never used RAM 13468, free system stack 184 words
                            Tasks: NETWORK(ready,12.4%,247) HEAT(notifyWait,0.0%,332) Move(notifyWait,0.0%,364) DUEX(notifyWait,0.0%,24) MAIN(running,87.0%,440) IDLE(ready,0.5%,30), total 100.0%
                            Owned mutexes: WiFi(NETWORK)
                            Last reset 00:02:37 ago, cause: power up
                            Last software reset at 2022-05-14 19:46, reason: User, GCodes spinning, available RAM 13264, slot 0
                            Error status: 0x00
                            Aux0 errors 0,0,0
                            Step timer max interval 0
                            MCU temperature: min 29.6, current 36.9, max 37.2
                            Supply voltage: min 12.3, current 12.4, max 12.5, under voltage events: 0, over voltage events: 0, power good: yes
                            Events: 0 queued, 0 completed
                            Driver 0: standstill, SG min n/a
                            Driver 1: standstill, SG min n/a
                            Driver 2: standstill, SG min n/a
                            Driver 3: standstill, SG min n/a
                            Driver 4: standstill, SG min n/a
                            Driver 5: standstill, SG min n/a
                            Driver 6: standstill, SG min n/a
                            Driver 7: standstill, SG min n/a
                            Driver 8: standstill, SG min n/a
                            Driver 9: standstill, SG min n/a
                            Driver 10:
                            Driver 11:
                            Date/time: 2022-05-15 16:48:09
                            Slowest loop: 135.24ms; fastest: 0.19ms
                            === Storage ===
                            Free file entries: 10
                            SD card longest read time 1.2ms, write time 60.6ms, max retries 0
                            DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
                            === MainDDARing ===
                            === AuxDDARing ===
                            Bed heaters -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
                            Segments left: 0
                            Movement lock held by null
                            HTTP is idle in state(s) 0
                            Telnet is idle in state(s) 0
                            File is idle in state(s) 0
                            USB is idle in state(s) 0
                            Aux is idle in state(s) 0
                            Trigger is idle in state(s) 0
                            Queue is idle in state(s) 0
                            LCD is idle in state(s) 0
                            Daemon is idle in state(s) 0
                            Code queue is empty
                            === Filament sensors ===
                            Extruder 0 sensor: ok
                            === DueX ===
                            Read count 1, 0.38 reads/min
                            === Network ===
                            Slowest loop: 111.91ms; fastest: 0.00ms
                            HTTP sessions: 1 of 8
                            - WiFi -
                            Network state is active
                            WiFi firmware version 1.26
                            WiFi MAC address 5c:cf:7f:76:72:b4
                            WiFi Vcc 3.39, reset reason Turned on by main processor
                            WiFi flash size 4194304, free heap 24952
                            WiFi IP address 10.0.0.18
                            WiFi signal strength -66dBm, mode 802.11n, reconnections 0, sleep mode modem
                            Clock register 00002002
                            Socket states: 4 0 0 0 0 0 0 0
                            	M98 P"config.g"
                            HTTP is enabled on port 80
                            FTP is disabled
                            TELNET is disabled
                            It stops before reaching it in the rear right corner I adjusted the screw manually and eventually it will still do it.
                            The build surface I have is buildtak.
                              Is there anything unique about that corner? Can you try putting the plain white paper there?
                              • trublu89undefined
                                trublu89 @Phaedrux
                                @phaedrux nope is there a way to just move one z motor instead of all?
                                • fcwiltundefined
                                  fcwilt @trublu89
                                  Have you tried Auto Bed Leveling?
                                  Docs where bed leveling is discussed
                                  How do the Z steppers connect to the bed? Do the connections have any give? Are the kinematic connections?
                                  • trublu89undefined
                                    trublu89 @fcwilt
                                    @fcwilt this is g29 initially and then g29 with s1 at startup code right?
                                    • fcwiltundefined
                                      fcwilt @trublu89
                                      @trublu89
                                      G29 is related to Mesh Bed Compensation which is a feature used during printing to try and adjust for an uneven bed.
                                      G32 is related to Auto Bed Leveling which is a feature used before printing to level the bed. Since you have multiple Z steppers you may be able to use Auto Bed Leveling but it depended on how much "flex" you have in the connections from the Z lead screws to the bed. The firmware probes the bed with your Z probe and attempts to adjust the Z steppers individually to level the bed.
                                      Here is a link to a quick-and-dirty video showing the Auto Bed Leveling feature leveling the bed on my printer. I designed the printer to support bed leveling and I use kinematic mounts to connect the Z belts to the bed. The mounts allow a lot of "flex" so the Z steppers are free to adjust the bed without any binding.
                                      Auto Bed Leveling Video
                                      trublu89undefined 2 Replies Last reply Reply Quote 0
                                      • trublu89undefined
                                        trublu89 @fcwilt
                                        @fcwilt I have the flexible z couplers.
                                        • trublu89undefined
                                          trublu89 @fcwilt
                                          @fcwilt also what would cause temperature excursion. I have paid tuned several times with and without the fan on.
                                            What error exactly are you getting and when are you getting it? Did you save the results of the PID tune and have it loaded again at startup? This is usualy done by sending M500 after the tuning to save it to config-override.g and then adding M501 to the end of config.g to load that file at startup.
