    auto calibration
    1.1k
    • fcwiltundefined
      fcwilt @trublu89
      @trublu89
      Not sure what you mean by "tried using G32 and now G29" - those are two totally different things.
      G32 is for invoking bed.g to level the bed.
      G29 is for invoking mesh.g to create the heightmap needed for using the Mesh Bed Compensation feature.
      I don't see it in your code but there are certain times when you need to set the Z=0 Datum using a single G30 at a consistent XY location.
      • after bed leveling
      • before creating a heightmap
      • before loading a heightmap
      Also what sort of Z probe do you have that has a X offset of 0 and a Y offset of 0?
      trublu89undefined 1 Reply Last reply Reply Quote 0
      • trublu89undefined
        trublu89 @fcwilt
        @fcwilt I've been out of the 3d printing loop for a while lol. I'm using the ir height sensor. I never really set offsets for the probe it just worked.
        so would I use a G92 to set z to zero?
        • fcwiltundefined
          fcwilt @trublu89
          @trublu89 said in auto calibration:
          In the G31 command there is the Z parameter which sets the probe Z Trigger Height value.
          When you execute a G30 the probe and bed move toward one another and when the probe triggers the logical Z axis position is set to the value of the G31 Z Trigger Height parameter value.
          So let's assume that value is 5 mm. G30 executes, the probe and bed move, the probe triggers, the logical Z axis position is set to 5 mm and then the probe and bed move apart based on the values of the G31 Z Trigger Height parameter and the M558 H parameter.
          If the physical Z axis position at the moment the probe was triggered was actually 5 mm then the physical Z axis position and the logical Z axis position are in sync.
          If the G31 Z Trigger Height parameter was too large or too small then the physical Z axis position and the logical Z axis position would be out of sync and any Z axis moves would result in the physical Z axis position being incorrect.
          So it is essential that the correct value for the G31 Z Trigger Height parameter is determined with very good accuracy.
          You can determine the correct value by trial-and-error or by using a reference object of known height.
          I can explain how to do that if needed.
            Phaedrux Moderator @trublu89
            both work fine one minute then one of the points wont trigger.
            You mean that it will move to the probe points but randomly the probe doesn't trigger? Meaning a nozzle crash? An error message?
            You can test and calibrate your probe following this: https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_testing
            • trublu89undefined
              trublu89 @Phaedrux
              @phaedrux it won't even crash it will just stop before reaching it. And sometimes the margin of error is -9.
              Now I'm getting a temperature excursion error I'm printing at 230 it will jump to 250 I paid tuned several times. Tried with fan on didn't realize the fan comes on with the newer firmware.
              • fcwiltundefined
                fcwilt @trublu89
                What do you mean by "reaching it" - what does "it" refer to?
                • trublu89undefined
                  trublu89 @fcwilt
                  @fcwilt
                  right before it tries to trigger it will just stop and error out probe was not triggered during move.
                  • fcwiltundefined
                    fcwilt @trublu89
                    @fcwilt
                    That is usually caused by starting to probe to far from the bed.
                    Does the probe move smoothly towards the bed?
                    • trublu89undefined
                      trublu89 @fcwilt
                      @fcwilt
                      I have the ir probe and my lead screws are independent driven by motors.
                        The offsets for the probe look suspect
                        G31 P500 X0 Y0 Z0.192
                        There is no X Y offset from the nozzle so the firmware doesn't know where the probe actually is. And the trigger height seems very small.
                        Have you gone through this yet? https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_testing
                        ;Lead screw position
                        M671 X45:45:485:485Y45:424:424:45  s5
                        This command to define your lead screw positions may not be registering correctly because there is a missing space between the X and Y values and an extra space before the S.
                        Can you also post your homeall.g and config-override.g?
                        It would also be nice to see the results of sending M122 and M98 P"config.g" in the gcode console.
                        Does this happen consistently in the space spot? Or totally randomly?
                        What is your bed surface? The IR probe can be sensitive to reflective or multicolor surfaces. You can try and eliminate this by putting a plane piece of white paper on your bed.
                        It would also be good to get some close up photos of the IR probe itself incase it is damaged in some way.
                        trublu89undefined 1 Reply Last reply Reply Quote 1
                        • trublu89undefined
                          trublu89 @Phaedrux
                          @phaedrux
                          I didn't realize there was a gap in my m671
                          That's how I came up with .192 homing to where the paper grabbed the nozzle and g92 z=0 g30 s1 to get the mean results.
                          ; homeall.g
                          ; called to home all axes
                          ; generated by RepRapFirmware Configuration Tool v3.3.10 on Fri Dec 17 2021 18:35:59 GMT-0600 (Central Standard Time)
                          G1 H2 Z5 F108000        ; lift Z relative to current position
                          G1 H1 X-565 Y-535 F1800 ; move quickly to X or Y endstop and stop there (first pass)
                          G1 H1 X-565             ; home X axis
                          G1 H1 Y-535             ; home Y axis
                          G1 X5 Y5 F108000        ; go back a few mm
                          G1 H1 X-565 F360        ; move slowly to X axis endstop once more (second pass)
                          G1 H1 Y-535             ; then move slowly to Y axis endstop
                          G90                     ; absolute positioning
                          G1 X32 Y50 F108000      ; go to first bed probe point and home Z
                          G30                     ; home Z by probing the bed
                          ; config-override.g file generated in response to M500 at 2022-05-14 23:47
                          ; Heater model parameters
                          M307 H1 R1.925 K0.303:0.261 D5.51 E1.35 S0.90 B0 V12.2
                          ; Workplace coordinates
                          G10 L2 P1 X0.00 Y0.00 Z0.00
                          G10 L2 P2 X0.00 Y0.00 Z0.00
                          G10 L2 P3 X0.00 Y0.00 Z0.00
                          G10 L2 P4 X0.00 Y0.00 Z0.00
                          G10 L2 P5 X0.00 Y0.00 Z0.00
                          G10 L2 P6 X0.00 Y0.00 Z0.00
                          G10 L2 P7 X0.00 Y0.00 Z0.00
                          G10 L2 P8 X0.00 Y0.00 Z0.00
                          G10 L2 P9 X0.00 Y0.00 Z0.00
                          What is the config overide g? I never really looked in there.
                          M122
                          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.0 (2022-03-15 18:58:31) running on Duet WiFi 1.02 or later + DueX5
                          Board ID: 08DGM-956GU-DJMSN-6JKF2-3S86L-TBRVG
                          Used output buffers: 3 of 24 (16 max)
                          Static ram: 23868
                          Dynamic ram: 74744 of which 0 recycled
                          Never used RAM 13468, free system stack 184 words
                          Tasks: NETWORK(ready,12.4%,247) HEAT(notifyWait,0.0%,332) Move(notifyWait,0.0%,364) DUEX(notifyWait,0.0%,24) MAIN(running,87.0%,440) IDLE(ready,0.5%,30), total 100.0%
                          Owned mutexes: WiFi(NETWORK)
                          Last reset 00:02:37 ago, cause: power up
                          Last software reset at 2022-05-14 19:46, reason: User, GCodes spinning, available RAM 13264, slot 0
                          Error status: 0x00
                          Aux0 errors 0,0,0
                          Step timer max interval 0
                          MCU temperature: min 29.6, current 36.9, max 37.2
                          Supply voltage: min 12.3, current 12.4, max 12.5, under voltage events: 0, over voltage events: 0, power good: yes
                          Events: 0 queued, 0 completed
                          Driver 0: standstill, SG min n/a
                          Driver 1: standstill, SG min n/a
                          Driver 2: standstill, SG min n/a
                          Driver 3: standstill, SG min n/a
                          Driver 4: standstill, SG min n/a
                          Driver 5: standstill, SG min n/a
                          Driver 6: standstill, SG min n/a
                          Driver 7: standstill, SG min n/a
                          Driver 8: standstill, SG min n/a
                          Driver 9: standstill, SG min n/a
                          Driver 10:
                          Driver 11:
                          Date/time: 2022-05-15 16:48:09
                          Slowest loop: 135.24ms; fastest: 0.19ms
                          === Storage ===
                          Free file entries: 10
                          SD card longest read time 1.2ms, write time 60.6ms, max retries 0
                          DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
                          === MainDDARing ===
                          === AuxDDARing ===
                          Bed heaters -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
                          Segments left: 0
                          Movement lock held by null
                          HTTP is idle in state(s) 0
                          Telnet is idle in state(s) 0
                          File is idle in state(s) 0
                          USB is idle in state(s) 0
                          Aux is idle in state(s) 0
                          Trigger is idle in state(s) 0
                          Queue is idle in state(s) 0
                          LCD is idle in state(s) 0
                          Daemon is idle in state(s) 0
                          Code queue is empty
                          === Filament sensors ===
                          Extruder 0 sensor: ok
                          === DueX ===
                          Read count 1, 0.38 reads/min
                          === Network ===
                          Slowest loop: 111.91ms; fastest: 0.00ms
                          HTTP sessions: 1 of 8
                          - WiFi -
                          Network state is active
                          WiFi firmware version 1.26
                          WiFi MAC address 5c:cf:7f:76:72:b4
                          WiFi Vcc 3.39, reset reason Turned on by main processor
                          WiFi flash size 4194304, free heap 24952
                          WiFi IP address 10.0.0.18
                          WiFi signal strength -66dBm, mode 802.11n, reconnections 0, sleep mode modem
                          Clock register 00002002
                          Socket states: 4 0 0 0 0 0 0 0
                          	M98 P"config.g"
                          HTTP is enabled on port 80
                          FTP is disabled
                          TELNET is disabled
                          It stops before reaching it in the rear right corner I adjusted the screw manually and eventually it will still do it.
                          The build surface I have is buildtak.
                            Is there anything unique about that corner? Can you try putting the plain white paper there?
                            • trublu89undefined
                              trublu89 @Phaedrux
                              @phaedrux nope is there a way to just move one z motor instead of all?
                              • fcwiltundefined
                                fcwilt @trublu89
                                Have you tried Auto Bed Leveling?
                                Docs where bed leveling is discussed
                                How do the Z steppers connect to the bed? Do the connections have any give? Are the kinematic connections?
                                • trublu89undefined
                                  trublu89 @fcwilt
                                  @fcwilt this is g29 initially and then g29 with s1 at startup code right?
                                  • fcwiltundefined
                                    fcwilt @trublu89
                                    @trublu89
                                    G29 is related to Mesh Bed Compensation which is a feature used during printing to try and adjust for an uneven bed.
                                    G32 is related to Auto Bed Leveling which is a feature used before printing to level the bed. Since you have multiple Z steppers you may be able to use Auto Bed Leveling but it depended on how much "flex" you have in the connections from the Z lead screws to the bed. The firmware probes the bed with your Z probe and attempts to adjust the Z steppers individually to level the bed.
                                    Here is a link to a quick-and-dirty video showing the Auto Bed Leveling feature leveling the bed on my printer. I designed the printer to support bed leveling and I use kinematic mounts to connect the Z belts to the bed. The mounts allow a lot of "flex" so the Z steppers are free to adjust the bed without any binding.
                                    Auto Bed Leveling Video
                                    trublu89undefined 2 Replies Last reply Reply Quote 0
                                    • trublu89undefined
                                      trublu89 @fcwilt
                                      @fcwilt I have the flexible z couplers.
                                      • trublu89undefined
                                        trublu89 @fcwilt
                                        @fcwilt also what would cause temperature excursion. I have paid tuned several times with and without the fan on.
                                          What error exactly are you getting and when are you getting it? Did you save the results of the PID tune and have it loaded again at startup? This is usualy done by sending M500 after the tuning to save it to config-override.g and then adding M501 to the end of config.g to load that file at startup.
                                          • trublu89undefined
                                            trublu89 @Phaedrux
                                            @phaedrux I didn't add the 501 I just entered m500.
                                            It said temperature excursion went from 230 to 250. I think the fan might have been too high I tried to make it to where it cuts on but low not on high but it still is 60 or 80 percent.
