sensorless homing random wrong direction
@moth4017 said in sensorless homing random wrong direction:
Are the motors moving the wrong way because it is wrongly detecting a stall and then moving 150mm (line 25 in your homex.g), or is it actually homing -350mm in the wrong direction (line 20)?
I don't think you are running the tuning move correctly. See: https://docs.duet3d.com/en/User_manual/Connecting_hardware/Motors_tuning#stealthchop-tuning (though this does need a little updating).
You must execute the proper tuning sequence after switching to stealthChop. This means: apply motor current, pause for more than 130ms, then execute a move at reasonable speed.
Rather than this (line 14-16 in homex.g):
G1 H1 X-0.2 F3000 ; move a little for cal of sensorless homing / not stalled G1 H1 Y-0.2 F3000 ; move a little for cal of sensorless homing / not stalled M400 ; make sure everything has stopped before we make changes
M400 just waits for the current move to finish, so may not give a long enough pause. Use
M17 X Y Z ; enable XYZ motors G4 P150 ; wait 150ms
After this tuning needs a reasonable length move at reasonable speed to tune, ie a homing move. A 0.2mm move may not be long enough to tune stall detection.
X or Y axis will move the correct way when they do the stall detection calibration ,
but then randomly move in the opposite direction to home. -
but then randomly move in the opposite direction to home.It's unlikely to move 'randomly', unless there is an issue with wiring. In your homex.g, X and Y move -0.2mm, then homes X-350, then moves X+150. If the stall is detected without moving (the second X-350 move), it should move 150 in the other direction. Or does it try to move 350mm in the 'wrong' direction? Are subsequent moves in the 'wrong' direction?
@droftarts
wiring ok , if i used the machine movement controls 100% perfect
just done a test it moves 150 in the wrong direction so it looks like its not doing the -350.
manual moves going in the correct way.
@moth4017 Okay, that means it is too sensitive to stalls. Either the tuning move is not working (did you do the change I suggested earlier?) or you need to revisit the sensitivity values.
also added the wait time now as suggested in the article and the move for calibration to 1.2mm but still the same issue
tried the following
S1 H200 works for end stops , does random wrong direction
S10 H200 works for end stops , does random wrong direction
S15 H200 works for end stops , does random wrong direction
S1 H400 crashies for end stops ,
S1 H300 crashies for end stops ,
S1 H250 crashies for end stops , -
Hi , ive just done this in a 100% repeatablepress "emergency stop:
home X , homes in wrong directionpress "emergency stop:
home X , homes in correct directionpress "emergency stop:
home X , homes in correct directionetc etc
@moth4017 Don't bother with a short tuning move. To tune stealthChop (which is what is being tuned, not stallGuard), you enable the motor, wait >130ms, then move a reasonable distance at a reasonable speed, ie the homing move. See the 2209 datasheet, page 35 (6.1 automatic tuning) https://www.trinamic.com/fileadmin/assets/Products/ICs_Documents/TMC2209_Datasheet_V105.pdf
You are using 'S4' in your endstop configuration. This is for 'Multiple motor'. Change
M574 X1 S4
andM574 Y1 S4
to use S3 instead. Not sure of the effect of this if you are only using one motor. Using stall detection on Z is much more difficult, because of the torque on leadscrews.You are also dropping your motor current using M906 rather than M913. Not sure of the effect of that, either.
Finally, are you using 1.8 degree or 0.9 degree motors? This affects the H parameter in M915.
If the stealthChop tuning works correctly, all you should need to do is find a good value for M913.
@droftarts
my Z homing working perfectly 3 motors on gear boxes belt driven.Core XY configuration 1.8Deg Motors all round
the X and Y are the only ones playing up. i think i have been told to use S4 as its multiple motors driven at the same time, is this not correct? -
@moth4017 No, S4 is for multiple motors on the SAME axis, ie like your Z axis. Use S3 for X and Y. See https://docs.duet3d.com/User_manual/Reference/Gcodes/M574
Endstop type S4 means use motor stall detection (like S3) but if there are multiple motors, stop each one individually as it stalls. S3 means use motor stall detection but stop all relevant motors when the first one stalls.
If you're using 1.8 motors, H200 is correct.
Also see https://docs.duet3d.com/User_manual/Connecting_hardware/Sensors_stall_detection
im not sure why the emergency stop button is causing this , ive just tried it again and its very repeatable
home X , homes in correct direction -
S3 same results
@droftarts @dc42
hi thanks for all the help , ive tried changing motor currents and many things over the past few weeks, i was waiting for the latest update to see if that had fixed it , but still in the same boat .. so i think this is a @dc42 one . -
M915 P0.0:0.1 S1 F0 R1 H200
Looking back at your first post, you have the S parameter set to S1, which would typically make it more sensitive to stalls. You may want to try making it less sensitive, ie increase S. Try S3. You will need to balance this against motor current.
@droftarts
i have tried changing current with the"S" value , i can give that another go tomorrow , but the "emergency stop" button thing is bugging mewhy should that be so consist ant.
so in my stop.g macro i have
G28 X Y /macros/sensorless_Z;sensorless_z
M915 P0.4:0.5:0.6 S3 F0 R0 ; Configure Z-Axis Stall Detection
M906 Z300 ; Lower motor current
M574 Z2 S4 ; Configure Z-Axis stall detection homing
M400 -
That isn't a valid command, and the macro won't be running. If you want to run that macro after homing X and Y, you need
M98 P"/macros/sensorless_Z"
@droftarts
i agree it looks invalid, but it runs.. changed it anywayStill made no difference
im still getting the
etc etc -
This post is deleted!
