    sensorless homing random wrong direction
    1.6k
      droftarts administrators @moth4017
      @moth4017 No, S4 is for multiple motors on the SAME axis, ie like your Z axis. Use S3 for X and Y. See https://docs.duet3d.com/User_manual/Reference/Gcodes/M574
      Endstop type S4 means use motor stall detection (like S3) but if there are multiple motors, stop each one individually as it stalls. S3 means use motor stall detection but stop all relevant motors when the first one stalls.
      If you're using 1.8 motors, H200 is correct.
      Also see https://docs.duet3d.com/User_manual/Connecting_hardware/Sensors_stall_detection
      moth4017undefined 2 Replies Last reply Reply Quote 0
      • moth4017undefined
        moth4017 @droftarts
        @droftarts
        im not sure why the emergency stop button is causing this , ive just tried it again and its very repeatable
        press "emergency stop:
        home X , homes in wrong direction
        home X , homes in correct direction
        • moth4017undefined
          moth4017 @droftarts
          @droftarts
          S3 same results
            @moth4017 Not sure why emergency stop would cause that behaviour. One for @dc42 to look at?
            Have you tried increasing the motor current 5%? Use M913 rather than M906.
            moth4017undefined 1 Reply Last reply Reply Quote 0
            • moth4017undefined
              moth4017 @droftarts
              @droftarts @dc42
              hi thanks for all the help , ive tried changing motor currents and many things over the past few weeks, i was waiting for the latest update to see if that had fixed it , but still in the same boat .. so i think this is a @dc42 one .
                @moth4017 said in sensorless homing random wrong direction:
                M915 P0.0:0.1 S1 F0 R1 H200
                Looking back at your first post, you have the S parameter set to S1, which would typically make it more sensitive to stalls. You may want to try making it less sensitive, ie increase S. Try S3. You will need to balance this against motor current.
                • moth4017undefined
                  moth4017 @droftarts
                  @droftarts
                  i have tried changing current with the"S" value , i can give that another go tomorrow , but the "emergency stop" button thing is bugging me 🙂 why should that be so consist ant.
                  so in my stop.g macro i have
                  G28 X Y /macros/sensorless_Z
                  ;sensorless_z
                  M915 P0.4:0.5:0.6 S3 F0 R0 ; Configure Z-Axis Stall Detection
                  M906 Z300 ; Lower motor current
                  M574 Z2 S4 ; Configure Z-Axis stall detection homing
                  M400
                    That isn't a valid command, and the macro won't be running. If you want to run that macro after homing X and Y, you need M98 P"/macros/sensorless_Z"
                    • moth4017undefined
                      moth4017 @droftarts
                      @droftarts
                      i agree it looks invalid, but it runs.. changed it anyway
                      Still made no difference
                      im still getting the
                      etc etc
                      • moth4017undefined
                        moth4017
                        This post is deleted!
                        • moth4017undefined
                          moth4017
                          @droftarts
                          "Homing issue"= going randomly to the incorrect side
                          S1 current 200mA issue homing
                          S1 current 400mA issue homing
                          S1 current 500mA homing ok ( have my doubts on this value being ok)
                          S1 current 600mA issue homing
                          S5 current 200mA issue homing
                          S5 current 400mA homing ok ( have my doubts on this value being ok)
                          S5 current 500mA issue homing
                          S10 current 200mA issue homing
                          S10 current 400mA homing ok ( have my doubts on this value being ok)
                          S10 current 500mA issue homing
                          S15 current 200mA issue homing
                          S15 current 400mA homing ok ( have my doubts on this value being ok)
                          S15 current 500mA issue homing
                          s20 current 200mA issue homing
                          s20 current 400mA homing ok ( have my doubts on this value being ok)
                          s20 current 500mA issue homing
                          s20 current 600mA issue homing
                          s30 current 200mA issue homing
                          s30 current 400mA homing ok
                          s30 current 500mA issue homing
                          s30 current 1000mA homing ok
                          spent most of the Day testing values above, i still have the issue that the "emergency stop " button seems to toggle the homing direction, also tried changing Jerk to see if that would make any difference (800 and 400)
                          another observation if i Home X and it goes in the correct direction , then the stepper motors time out, (M84 X Y S20) and i home X again it also goes in the wrong direction.
                            dc42 administrators @moth4017
                            @moth4017 I can think of are three possible reasons why the motor may go in the wrong direction:
                            1. The driver is signalling a stall at the start of the G1 H1 X-350 homing move, so it skips that and proceeds directly to the G1 X150 move. This is the most likely explanation.
                            2. If the motor currrent is set very low and the motor is under load, it may move in the wrong direction.
                            3. If only one motor phase is connected then the motor will either vibrate or move in a random direction.
                            From your homex.g file:
                            M906 X600 Y600 ; Lower motor current
                            We recommend that you use M906 only in config.g. When you need to reduce motor current temporarily, use M913 instead to set a percentage of the current set by M906. Also, don't reduce the motor current until you want to do the stall homing. StealthChop calibration should be done at normal motor current.
                            G1 H1 X-0.2 F3000                               ; move a  little  for cal of sensorless homing / not stalled
                            G1 H1 Y-0.2 F3000    							; move a  little  for cal of sensorless homing / not stalled
                            M400											; make sure everything has stopped before we make changes
                            That's not a valid stealthChop tuning sequence. Use something like this instead (at normal motor current):
                            M17 X Y  ; enable X and Y motor drivers
                            G1 P140  ; pause to allow the drivers to characterise the motor
                            You can then reduce motor current (using M913) and do the stall homing move. 30% motor current is usually good.
                            However, there is the possibility that the motor may already be signalling a stall. So I recommend that after homing an axis, you back off a few mm and repeat the homing move. For example:
                            M913 X30  ; use X30 Y30 if the machine is CoreXY
                            G91
                            G1 H1 X-350                                     ; Home X-Axis
                            G1 H2 X10  ; back off a little (on a CoreXY machine use X10 Y10)
                            G1 H1 X-350                                     ; Home X-Axis again
                            M913 X100 ; restore motor current (use X100 Y100 is the machine is CoreXY)
                            HTH David
                            moth4017undefined pro3dundefined 2 Replies Last reply Reply Quote 0
                            • moth4017undefined
                              moth4017 @dc42
                              im still getting the wrong direct alternating after pressing the
                              "emergency stop" button.
                              new homex.g
                              ; homex.g
                              echo "start"
                              M569 P0.0										; Check status in console
                              M569 P0.1										; Check status in console
                              G91                                             ; relative positioning
                              M569 P0.0 S1 D3 V10                             ; set to stelth chop
                              M569 P0.1 S1 D3 V10								; set to stelth chop
                              M915 P0.0:0.1 S20 F0 R1 H200                    ; Configure Z-Axis Stall Detection
                              echo "stall detection setup"
                              M17 X										; Check status in console
                              M17 Y										; Check status in console
                              G1 P140
                              echo "lower motor current"
                              M913 X50 Y50									; Lower motor current %
                              G4 P150											; wait 150ms
                              M574 X1 Y2 S4									; Configure Z-Axis stall detection homing
                              echo "home x"
                              G1 H1 X-350 F6000								; Home Z-Axis actuators independently
                              G90 											; absolute positioning
                              G1 X150 F6000									; move to center of bed
                              ;revert back
                              echo "after revert back"
                              M913 X100  Y100                               	; Reset motor current %
                              M569 P0.0 S1 D2                                 ; reset motors back to spread cycle,
                              M569 P0.1 S1 D2									; reset motors back to spread cycle,
                                @moth4017 you haven't done the double homing move that I recommended. Assuming your machine is CoreXY, try this.
                                ; homex.g
                                echo "start"
                                M569 P0.0 S1 D3 V10                             ; set to stealth chop
                                M569 P0.1 S1 D3 V10								; set to stealth chop
                                M915 P0.0:0.1 S20 F0 R1 H200                    ; Configure Stall Detection
                                M17 X Y
                                G1 P140
                                echo "home x"
                                G1 H1 X-350 F6000
                                G1 H2 X20 Y20
                                G1 H1 X-350 F6000
                                ;revert back
                                • pro3dundefined
                                  pro3d @dc42
                                  Regarding M906/913 - You recommend using 913 in the homing file. 913 is a function of 906 and 913 is not an exact number so it does not make sense to use 913 as it does not tell you what current is being used unless you pull out a calculator. Why is it bad practice to use 906 in the homing file when this is what sets the motor current and then you know what currents will work?
                                  PS! I have the same machine as @moth and a fully working stallguard homing on all 5 axes (XYZUV) but I run a Duet wifi 2 with a Duex5 so different drivers. I have how ever experienced the same problems as @moth4017 before I started moving my printhead between homing X and Y. After I made the change of moving my printhead between homex an homey it has been working 100%
                                  ; homex.g
                                  ; called to home the X axis
                                  M915 P0:1 S4 F0 R0                            ; Configure Stall Detection
                                  M906 X750 Y750                                      ; Lower motor current
                                  G1 F9000
                                  G1 H1 X350                           ; Home Z-Axis independently
                                  M906 X1000 Y1000                                    ; Reset motor current
                                  G1 F12000 X155
                                  ; homey.g
                                  ; called to home the Y axis
                                  M915 P0:1 S4 F0 R0                            ; Configure Z-Axis Stall Detection
                                  M906 X750 Y750                                      ; Lower motor current by 50%
                                  G1 F9000
                                  G1 H1 Y-350                           ; Home Z-Axis actuators independently
                                  G1 Y160	; move to probe position midle bed (x155 y150)
                                  ; homeall.g
                                  ; called to home all axes
                                  M400
                                  M98 P/sys/homey.g  ;P define the parameter and is not part of the name
                                  M98 P/sys/homex.g  ;P define the parameter and is not part of the name
                                  M98 P/sys/homez.g  ;P define the parameter and is not part of the name
                                  Valkyrie DIY High Temp 3D Printer
                                  R&D - Engineering Designer - Viking 3D Printers
                                  https://vkingprinter.com/
                                  • moth4017undefined
                                    moth4017 @dc42
                                    hi did try double homing worked on X axis but not so good on Y , the Y axis seems to move in the x direction
                                    x home
                                    G1 H1 X-350 F6000
                                    G1 H2 X10 Y10
                                    G1 H1 X-350 F6000
                                    y home
                                    G1 H1 Y350 F6000
                                    G1 H2 X-10 Y-10
                                    G1 H1 Y350 F6000
                                      G1 H2 X-10 Y-10
                                      That line in homey.g needs to be changed because as it stands it will back off in the -X direction. I think the correct combination to back off in the -Y direction is: G1 H2 X-10 Y10
                                      • moth4017undefined
                                        moth4017 @dc42
                                        did some tests tonight with the "double bump" on homing , sometimes there was only a single bump , i did see it go 10mm in the wrong direction though, so didnt do the "G1 H1 X-350 F6000" , is this now down to tuning the "S" parameter and current?
                                        echo "home x"
                                        G1 H1 X-350 F6000
                                        G1 H2 X10 Y10
                                        G1 H1 X-350 F6000
                                        echo "Home Y"
                                        G1 H1 Y350 F6000
                                        G1 H2 X-10 Y10
                                        G1 H1 Y350 F6000
                                        • moth4017undefined
                                          moth4017
                                          So , im still getting a random wrong direction now and then but ill put that down to tuning the "S" parameter and current.
                                          if i switch the machine on and do a home X it always goes in the wrong direction can not remember it doing this in the previous version.
                                          • moth4017undefined
                                            moth4017
                                            solution and files here :- https://forum.duet3d.com/topic/28653/3-4-1-rc2-g30-turns-off-z-motors/14?_=1653704200634
