    e3d TC coupler motor is not moving and homing C has no errors?
    596
    • VoodooBaneundefined
      VoodooBane
      I am not sure that "General discussion" is the correct place. I apologize in advance for this
      So I home the x >y >z> then I home the C axis no errors but the motors does not rotate at all.
      Also when I try the unlock or lock coupler macro nothing moves. What am missing?
      Here is my config file... I know my 3-axis z is not set up nor are my tools plugged in but please ignore that. (unless this is why the coupler motor is not moving at all)
      ; Configuration file for Duet WiFi (firmware version 3.4.0)
      ; General Global Preferences and critical Drive Configuration Section -  These must come before all else.
      ;M80																	; ATX ON
      G4 P2000																; Hold your Horses.  Add a little time to allow things to settle and complete.
      G90  																	; send absolute coordinates...
      M83  																	; ...but relative extruder moves
      G21																		; Set units to Millimeters
      M550 P"Cube 3D Printer Duet" 											; set printer name -  change this to whatever you'd like
      M584 X1 Y0 Z7:8:9 C2 E3:4:5:6 										    ; set drive mapping to each axis --- *EDP* - 1 The "Z2:5:6" would be
      																		;  Note the M567 commage later. These are related and connected. This command must always come before a number of other commands.  Refer to https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview
      M575 P1 S1 B57600														; Start Serial Com with PanelDue
      M669 K1																	; Select CoreXY mode
      ; Network Configuration Section
      M552 S1 																; enable network
      M587 S"DAHWIFI" P"Nandina95"											; Add a WiFi host network to the remembered list.
      M586 P0 S1 																; enable HTTP
      M586 P1 S0 																; disable FTP
      M586 P2 S0 																; disable Telnet
      ;Stall Detection
      ;M915 Z S6 F0 H200 R3													; Z axis
      ;M915 E S6 F0 H400 R3													; Extruder
      ;M915 X Y S3 F0 H400 R3													; X / Y Axes, S=lower values more sensitive R3=pause&rehome.g&resume print
      ; Drives - Establish the Drive designation and the direction they turn.
      ; Validate these settings as a first step.
      ; If your wiring differs, you can fix the direction here instead of rewiring.
      M569 P0 S0																; X axis
      M569 P1 S1 																; Y axis
      M569 P2 S1 																; Coupler MAY HAVE TO INVERT TO S1!!!
      M569 P3 S1 																; Tool 1 Extruder
      M569 P4 S1 																; Tool 2 Extruder
      M569 P5 S0																; Tool 3 Extruder
      M569 P6 S0																; Tool 4 Extruder
      M569 P7 S0																; z-axis: mid left
      M569 P8 S0																; z-axis: front right
      M569 P9 S0																; z-axis: back right
      M671 X-64:206:206 Y60:-25:120 S15										; Set up three Z-axis location
      																		; *EDP* - 1  This tells the Duet the physical location of the center of the leadscrews.
      																		; for reference the order/sequence of defined coordinate positions MUST correspond to
      																		; the order of axis drives that was specified above in the M584 gcode 1 - left, 2 - front right and 3 - rear right
      M92 X200.00 Y200.00 Z200.00 C200 E562:562:562:562 						; set steps per mm, based on using 1.8 degree steppers for X/Y/Z
      M350 E16:16:16:16 I1 													; configure micro-stepping with interpolation
      M350 C16 I0
      M350 X16 Y16 Z16 I1
      M566 X400.00 Y400.00 Z8.00  C2 E200:200:200:200 						; set maximum instantaneous speed changes (mm/min)
      M203 X35000.00 Y35000.00 Z1200.00 C10000 E5000:5000:5000:5000 			; set maximum speeds (mm/min) *EDP*
      M201 X3000.00 Y3000.00 Z100.00 C500 E2500:2500:2500:2500 				; set accelerations (mm/s^2)
      ;M204 P2000 T4000														; set printing and travel acceleration
      M906 X1300 Y1300 Z800 C500 E500:500:500:500 I30 						; set motor currents (mA) and motor idle factor in per cent
      M84 S30  																; Set idle timeout
      ; Axis Limits NEED CHANGING FOR TC. CONSERVATIVE GUESS NOW for XY
      M208 X-14 Y0 Z0 S1 														; set axis minima
      M208 X330 Y265 Z350 S0 													; set axis maxima
      ;--> print size: 300x300x400
      M574 Y1 P"xstop"														; X min active low endstop switch
      M574 X1 P"ystop"  														; Y max active low endstop switch Was S0 before TC
      M574 Z0																	; No z endstop
      M574 C1 S3																; Stall detect coupler at low end of its range
      ;Z-probe
      M558 P8 C"zstop" H3 F120 I0 T20000      							    ; set Z probe type to switch IF WORKS, CHANGE TO F360 I0 T20000. MAYBE CHANGE I0 TO C"!..." TO INVERT?
      G31 P200 X0 Y0 Z0	 													; set Z probe trigger value, offset and trigger height Z0.9 seems to be a bit too close for pla
       Stall detection
      ;M915 C S6 F0 H200 R0													; Coupler
      ; Configure Heaters and Sensors
      ; Bed Heater:
      M308 S0 P"bedtemp" Y"thermistor" A"Bed Heater" T100000 B3950			; Configure bed temperature sensor -
      M950 H0 C"bedheat" T0 													; Define heater 0 (bed heater) - bind the bed_heat pin and Temp Sensor0		together as defined above as "P0" gain 115.8, time constant 171.5, dead time 2.2, max PWM 1.00, calibration voltage 24.1, mode PID
      M143 H0 S120															; set temperature limit for heater 0 to 120C
      ;M307 H0 ;A115.8 C171.5 D2.2 V24.1 B0									; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0																	; Informs the firmware that bed heater 0 (implied, because no P parameter is provided) uses heater 0.
      ; Tool  0:
      M308 S1 P"e1temp" Y"thermistor" A"T0" T100000 B4725 C0.0000000706  		; Configure extruder_0 temperature sensor. Attach sensor to e0_temp refer to wiki. Trianglelabs thermistor.
      M950 H1 C"e1heat" T1 													; Define heater 1 (hot-end E0) - bind the "e1_heat" pin (default first extruder) and Temp Sensor 1 together, as defined above as "P1"
      M143 H1 S280  															; set temperature limit for heater 1 to 280C
      ;M307 H1 A425.3 C182.6 D5.1 V24.1 B0									; tuning parameters from 6.2.21: Heater 1 model: gain 425.3, time constant 182.6, dead time 5.1, max PWM 1.00, calibration voltage 24.1, mode PID
      ; Tool  1:
      M308 S2 P"e2temp" Y"thermistor" A"T1" T100000 B4725 C0.0000000706  		; Configure extruder_0 temperature sensor. Attach sensor to e0_temp refer to wiki. Trianglelabs thermistor.
      M950 H2 C"duex.e2heat" T2 												; Define heater 1 (hot-end E0) - bind the "e1_heat" pin (default first extruder) and Temp Sensor 1 together, as defined above as "P1"
      M143 H2 S280  															; set temperature limit for heater 1 to 280C
      ;M307 H2 A516.5 C163.7 D5.6 V24.2 B0									; tuning parameters from: date 6.2.21
      ; Tool  2:
      M308 S3 P"e3temp" Y"thermistor" A"T2" T100000 B4725 C0.0000000706  		; Configure extruder_0 temperature sensor. Attach sensor to e0_temp refer to wiki. Trianglelabs thermistor.
      M950 H3 C"duex.e3heat" T3 												; Define heater 1 (hot-end E0) - bind the "e1_heat" pin (default first extruder) and Temp Sensor 1 together, as defined above as "P1"
      M143 H3 S280  															; set temperature limit for heater 1 to 280C
      ;M307 H3 A480.8 C171.0 D5.7 V24.2 B0									; tuning parameters from: date 6.2.21
      ; Tool 3:
      M308 S4 P"e4temp" Y"thermistor" A"T3" T100000 B4725 C0.0000000706  		; Configure extruder_0 temperature sensor. Attach sensor to e0_temp refer to wiki. Trianglelabs thermistor.
      M950 H4 C"e0heat" T4 													; Define heater 1 (hot-end E0) - bind the "e1_heat" pin (default first extruder) and Temp Sensor 1 together, as defined above as "P1"
      M143 H4 S280  															; set temperature limit for heater 1 to 280C
      ;M307 H4 A588.5 C179.1 D7.9 V24.1 B0									; tuning parameters from: date 6.2.21
      ; Fans (all duex fans are on 24V)
      M950 F1 C"duex.fan3"													; T1 HF
      M950 F2 C"duex.fan7"													; T1 PCF
      M950 F3 C"duex.fan4"													; T2 HF
      M950 F4 C"duex.fan8"													; T2 PCF
      M950 F5 C"duex.fan5"													; T3 HF
      M950 F6 C"fan0"															; Cave: 24V -- T3 PCF
      M950 F7 C"duex.fan6"													; T4 HF
      M950 F8 C"fan2"															; Cave: 24V -- T4 PCF
      M106 P1 S255 H1 T50														: T1 HF
      M106 P2 S0																; T1 PCF
      M106 P3 S255 H2 T50														: T2 HF
      M106 P4 S0																; T2 PCF
      M106 P5 S255 H3 T50														: T3 HF
      M106 P6 S0																; T3 PCF
      M106 P7 S255 H4 T50														: T4 HF
      M106 P8 S0																; T4 PCF
      ; Set up the Tools, which combine heaters, fans, and sensors to work as one Tool.
      ; Tool 0
      M563 P0 S"T0" D0 H1 F2
      G10 P0 X-9 Y39 Z-5														; Set Nozzle offset
      G10 P0 R0 S0															; Reset initial tool 0 active and standby temperatures to 0C
      ; Tool 1
      M563 P1 S"T1" D1 H2 F4
      G10 P1 X-9 Y39 Z-5														; Set Nozzle offset
      G10 P1 R0 S0															; Reset initial tool 0 active and standby temperatures to 0C
      ; Tool 2
      M563 P2 S"T2" D2 H3 F6
      G10 P2 X-9 Y39 Z-5														; Set Nozzle offset
      G10 P2 R0 S0															; Reset initial tool 0 active and standby temperatures to 0C
      ; Tool 3
      M563 P3 S"T3" D3 H4 F8
      G10 P3 X-9 Y39 Z-5														; Set Nozzle offset
      G10 P3 R0 S0															; Reset initial tool 0 active and standby temperatures to 0C
      ; Advanced calibrations:
      ;M593 F50																; cancel ringing at 50hz https://forum.e3d-online.com/threads/accelerometer-and-resonance-measurements-of-the-motion-system.3445/
      ; Pressure advance
      M572 D0 S0.2															; pressure advance T0
      M572 D1 S0.2															; pressure advance T1
      M572 D2 S0.2															; pressure advance T2
      M572 D3 S0.2															; pressure advance T3
      M911 S23 R24 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"						; set voltage thresholds and actions to run on power loss
      ;M376 H15																; bed compensation taper
      ;Tool Offsets (!ESTIMATED! offsets):
      ; V6-tool: X-9 Y39 Z-5 <<<<<<<<< same as V6
      ; Volcano-tool: X-9 Y39 Z-13.5
      ; Hemera-tool: X-37.5 Y43.5 Z-6
      G10 P0 X-9 Y39 Z-5														; T0 -5 is large distance to bed
      G10 P1 X-9 Y39 Z-5														; T1
      G10 P2 X-9 Y39 Z-5														; T2
      G10 P3 X-9 Y39 Z-5														; T3
      ;deselect tools
      T-1
      ;M501																	; Store parameters. Deprecated?
      Please help? I am totally stumped.
      Thank you.
      Rushmere3Dundefined gloomyandyundefined fcwiltundefined 3 Replies Last reply Reply Quote 0
      • Rushmere3Dundefined
        Rushmere3D @VoodooBane
        @voodoobane
        I'd firstly for ease of use move your M584 to after you drive definitions.
        And I can't see any axis limits for the coupler?
        Follow my adventures in 3D Printing, laser cutting and electronics. https://linktr.ee/Rushmere3D
        VoodooBaneundefined 1 Reply Last reply Reply Quote 1
        • gloomyandyundefined
          gloomyandy @VoodooBane
          @voodoobane The normal setup on an e3d toolchanger is not to have any sort of endstop for the C axis. Instead the motor is just driven until it hits the physical stop (the homec.g file will normally reduce the motor current during this process). It looks like you have a stall detection endstop defined. Perhaps that is causing problems. DC42 published his toolchanger configuration here: https://github.com/Duet3D/RRF-machine-config-files/tree/master/E3D_Tool_Changer/dc42-duet3-centreZero-2Titan-2Hemera/sys
          I have something very similar setup on my TC and it seems to work fine...
          • fcwiltundefined
            fcwilt @VoodooBane
            @voodoobane
            Stall detection does not work for the coupler stepper.
            Here are the relevant bits from my code:
            ; from config.g file
            ; C (tool coupler) (M92 is set so G1 commands are in degrees)
            M92  C182.044      ; ( 32 steps-per-rev (stepper) * 64 (gearbox) * 2 (gears) * 16 (microsteps) ) / 360
            M203 C5000         ; max speed (mm/min) (default 300) (suggested 5000)
            M201 C500          ; acceleration (mm/s^2) (default 20) (suggested 500)
            M566 C2            ; max instant speed change (jerk) (mm/min) (default 12) (suggested 2)
            M906 C500          ; motor current (mA) (stepper rating 400mA RMS per phase) (suggested 500)
            M350 C16 I1        ; 16x microstepping with interpolation
            M208 C-41:225      ; set axis min/max values (determined by testing)
            ; --- homeC.g ---
            ; --- compute max C rotation ---
            var cmin = move.axes[3].min
            var cmax = move.axes[3].max
            var ctot = {var.cmax} - {var.cmin}
            ; --- home C ---
            M400                     ; wait for any moves to finish
            M913 C50                 ; insure "normal" stepper current
            G91                      ; relative moves
            G1 H2 C{-var.ctot} F5000 ; turn CCW to limit of rotation
            G92 C-41                 ; set logical position (determined by testing so unlocked is 90, locked is 180)
            M98 P"tool_unlock.g"     ; turns to 90
            ; --- tool_lock.g ---
            M400          ; wait for moves to finish
            M913 C100     ; increase current to improve locking
            G90           ; absolute moves
            G1 C180 F5000 ; turn to locked position
            M913 C50      ; restore current to normal
            ; --- tool_unlock.g ---
            M913 C100     ; increase current to improve unlocking
            G1 C90 F5000  ; turn to unlocked position
            • rjenkinsgbundefined
              rjenkinsgb
              I agree with Rushmere3d, you need to add some limits for C.
              I have 0 and 500 on mine.
              M208 X-14 Y0 Z0  C0 S1 														; set axis minima
              M208 X330 Y265 Z350 C500 S0
              And this is my home C file:
              ; homec.g
              ; called to home the C axis (coupler)
              ;G91
              M400
              G92 C499
              M400
              M913 C60		; MOTOR TO 60% CURRENT
              G1 H1 C0 F2000
              M400
              G92 C0
              ;G90
              M913 C100			; MOTOR TO 100% CURRENT
              G1 C0 F10000
              ;Open Coupler
              M98 P"/macros/Coupler - Unlock"
              I have the lock position as C33 and unlock as C125
              Robert J.
              Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
                VoodooBane
                I will try this guys!
                  VoodooBane @Rushmere3D
                  @rushmere3d
                  All I see is the homeC.
                  But no I have another problem
                  Is it normal if this isn't all set to have the Home C tell me the wiring is wrong? I have a 2nd motor just in case. and it gives me the same error. I double-checked my wiring and everything. I do not understand it is saying my wiring is bad. could s0 and s1 be a factor? I have little information about this tool changer motor.
                  VoodooBaneundefined dc42undefined 2 Replies Last reply Reply Quote 0
                    VoodooBane @VoodooBane
                    @voodoobane I checked the A and B poles and they are correct.
                      dc42 administrators @VoodooBane
                      @voodoobane said in e3d TC coupler motor is not moving and homing C has no errors?:
                      What message are you seeing, and what firmware version are you using?
                      VoodooBaneundefined 2 Replies Last reply Reply Quote 0
                        VoodooBane @dc42
                        @dc42 I using Version 3.4
                          VoodooBane @dc42
                          @dc42 I figured it out... Driver 2 is bad...
                            How did you determine that?
