    New heated enclosure printer
    230
    23.0k
    • cosengundefined
      coseng @Phaedrux
      @phaedrux OK, go tthe network working and can connecto via DWC and the fan modifications to the config.g are still there so hopefully the rest of the configuration is correct.
      The paneldue is still blank. Config.g is:
      ; Configuration file for Duet 3 (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.10 on Thu Apr 14 2022 23:29:28 GMT-0400 (Eastern Daylight Time)
      M550 P"hyperprinter" ; set printer name
      M669 K1 ; select CoreXY mode
      M564 H0 ; allow moves before homing
      ; Wait a moment for the CAN expansion boards to start
      G4 S2
      M552 P192.168.2.1 S1 ; enable network and set IP address
      M553 P255.255.255.0 ; set netmask
      M554 P192.168.2.20 ; set gateway
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0.1 S0 ; physical drive 0.1 goes forwards
      M569 P0.2 S0 ; physical drive 0.2 goes forwards
      M569 P121.0 S1 ; physical drive 121.0 goes forwards
      M584 X0.1 Y0.2 Z0.0 E121.0 ; set drive mapping
      M350 X128 Y128 Z8 E16 I1 ; configure microstepping with interpolation
      M92 X56.14 Y56.14 Z320.00 E837.00 ; set steps per mm
      M566 X500.00 Y500.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X50000.00 Y50000.00 Z1000.00 E1200.00 ; set maximum speeds (mm/min)
      M201 X10000.00 Y10000.00 Z50.00 E3000.00 ; set accelerations (mm/s^2)
      M906 X300 Y300 Z5900 E1500 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S20 ; Set idle timeout
      M572 D0 S0.03
      ; CLEARPATH STEPPER TIMING
      M569 P1 R1 T2
      M569 P2 R1 T2
      M208 X-300 Y-250 Z0 S1 ; set axis minima
      M208 X300 Y250 Z950 S0 ; set axis maxima
      M574 X2 S1 P"121.io2.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin 121.io2.in
      M574 Y1 S1 P"io1.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io1.in
      M950 S0 C"121.io0.out" ; create servo pin 0 for BLTouch
      M558 P9 C"121.io0.in" H5 F120 A1 T20000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X-2.31 Y-13.53 Z2.91 ; set Z probe trigger value, offset and trigger height
      M557 X-290:290 Y-240:224 S116 ; define mesh grid
      M308 S0 P"temp0" Y"pt1000" ; configure sensor 0 as PT1000 on pin temp0
      ; M307 H0 R0.379 K0.064:0.000 D4.11 E1.35 S1.00 B0 OLD FROM FIRST TUNING RUN
      M307 H0 R0.158 K0.054:0.000 D37.27 E1.35 S1.00 B0 ; FROM SECOND TUNING RUN WITH BED MOUNTED SENSOR
      M308 S1 P"temp1" Y"thermistor" T1000 ; configure sensor 3 as two 500 ohm thermistors in series on pin temp1
      M950 H1 C"out1" T1 ; create chamber heater output on out1 and map it to sensor 1
      M307 H1 R0.292 K0.731:0.000 D3.86 E1.35 S1.00 B0 ; FROM FIRST TUNING RUN
      M141 H1 ; map chamber to heater 1
      M143 H1 S150 ; set temperature limit for heater 1 to 150C
      M308 S2 P"121.temp0" Y"pt1000" ; configure sensor 2 as PT1000 on pin 121.temp0
      M950 H2 C"121.out0" T2 ; create nozzle heater output on 121.out0 and map it to sensor 2
      M307 H2 R1.544 K0.166:0.000 D6.33 E1.35 S1.00 B0 V23.1 ; FROM FIRST TUNING RUN
      M143 H2 S320 ; set temperature limit for heater 2 to 320C
      M950 F0 C"out4" Q500 ; create fan 0 on pin out4 and set its frequency
      M106 P0 C"Chamber 1" S1 H-1 ; set fan 0 name and value. Thermostatic control is turned off
      M950 F1 C"out5" Q500 ; create fan 1 on pin out5 and set its frequency
      M106 P1 C"Chamber 2" S1 H-1 ; set fan 1 name and value. Thermostatic control is turned off
      M950 F2 C"121.out2" Q500 ; create fan 2 on pin 121.out2 and set its frequency
      M106 P2 C"XY Extruder" S1 H-1 ; set fan 2 name and value. Thermostatic control is turned off
      M950 F3 C"out7" Q500 ; create fan 3 on pin out7 and set its frequency
      M106 P3 C"Water Cooler" S1 H-1 ; set fan 3 name and value. Thermostatic control is turned off
      M950 F4 C"121.out1" Q500 ; create fan 4 on pin 121.out1 and set its frequency
      M106 P4 C"Layer fan" S1 H-1 ; set fan 4 name and value. Thermostatic control is turned off
      M563 P0 S"xyhead" D0 H2 F2 ; define tool 0
      ; Custom settings
      M950 D1 C"spi.cs0+spi.cs2"
      Chris
      Cosentino Engineering
      • cosengundefined
        coseng @coseng
        @Phaedrux Even though the paneldue is blank I can access the files on the sd card.
        Chris
        cosengundefined 1 Reply Last reply Reply Quote 0
        • cosengundefined
          coseng @coseng
          OK, updated the paneldue firmwware through dwc and now it all seems good again. Phew! Thanks for the help. I wonder what happened.
          Chris
            When you updated the firmware to 3.4.1 did you manually update the dwc files to match?
            What firmware version was on there before?
            I think you figured it out but sounds like version mismatches.
            • cosengundefined
              coseng @Phaedrux
              @phaedrux Oops, no, but I did not do anything after getting it working again, wlll do that now. Previous version was 3.4.0 for the 6hc and dwc.
              Chris
                What PanelDue firmware did you land on?
                • cosengundefined
                  coseng @Phaedrux
                  @phaedrux I updated the paneldue and the 1LC toolboard to be 3.4.1 so all the components were at the same level. Happily printing away again. Thanks!
                  Chris
                  • cosengundefined
                    coseng
                    Oh yea! Finally after running this part about 20 times, here's a great final result. It is not the first white part, so was not a material swap fix.
                    It's just about as perfect a part as I can expect. The grooves on the backside are for 1/2" square steel tube for a small reinforcement frame that will be epoxied in and bolted inline with the two mounting holes so these parts will actually be used on the racetrack at up to 160mph.
                    The last few final changes were all thermal:
                    -added a layer fan, off for first 30% of build, then increasing to 75% at 75% of build.
                    -reduced the chamber temp as the build progressed, 50C to start, 45C midway, then 40C at 75%.
                    -increased minimum layer time from 10sec to 20 sec. Build time was 7hr2min.
                    My take away from all this testing is that although it is often said to use minimal layer cooling on ABS, I suspect that this is for machines without a good thermal enclosure, which seems to make a big difference. I think that my air/temp mixing in the chamber is not that good, or the thermal gradient is just too big to keep constant with a thin bellows top with a gap for the printhead, or my sensor positions are reading low, or all of the above. With a 50C chamber setpoint, the bed sensor reads is 93 (set for 90) and the SSR never goes on. With a 45C chamber the bed is 92, with a 40C chamber, 91. So I am getting great heat retention to the point of excess, where the chamber heaters are heating the bed. Which really just means I have to figure out those numbers for this printer. Or maybe the heater tuning should be with all configurations of the various heaters on and off, but then it gets pretty complex and more likely to mess things up.
                    Once things get up to temp they are quite stable so I don't want to mess with it too much. So I’m getting there. Hopefully a revised layer fan will reduce the amount of heat soak, for lack a better term, and allow me to do 10sec layers instead of 20sec. Or I’ll just print two parts at a time. But for now, it is 235/90/50 to start, then dropping to 230/90/45 at the midpoint, then 220/90/40 for the end. Max speed on the big layers is 150mm/s, down to about 40mm/sec on the small layers.
                    Thanks again to all for the help!
                    Chris
                    cosengundefined 1 Reply Last reply Reply Quote 1
                    • cosengundefined
                      coseng @coseng
                      Have a few good runs under my belt and am feeling pretty good about the settings. I revised the layer duct fan to blow a bit more and reduced the minimum layer time to 15 sec with no apparent change in the good results.
                      Still not quite sure I understand the thermal relationships going on. It takes setting the chamber temp to 35C for the bed heater to actually cycle. At 40C chamber or above it reads a couple of degrees over the setpoint of 90C, and continually reads 92 or 93.
                      @Phaedrux Is there some way to log or graph the activity of all the heater circuits to see what their duty cycles are? Maybe the good insulation and almost 80W of heat input from the printhead is enough to keep the chamber up to temp, as unlikely as that seems. At 50C chamber temp the outside surfaces are warm to the touch and the glass window pretty warm. At 35C chamber temp the outside surfaces or door window do not even feel warm.
                      The step in the airbox part is because it was being run with no supports even with completely horizontal overhangs to see how bad the bridging was. A blob developed at one overhang and hit the nozzle and shifted the bed a little but it kept printing. I only wanted the first couple of inches anyway to check the assembly, since that is where everything mounts to.
                      The marks on the back of the fairing parts are where I trimmed the ribs off but did not do a full finishing job. I'm very happy with the surface finish of the appearance surfaces. They have a consistent satiny appearance.
                      Now that I am feeling confident, one half of the gas tank/airbox cover is printing. Multiple smooth curvatures, some near vertical, some near horizontal. So far, so good. Projected to be a 13hr print and about halfway through. This is the first part with supports. I used the normal style as the tree support option resulted in a 2hr longer print time. Maybe I didn't tweak the settings optimally.
                      If that goes well, next I'll do the tailsection standing up, which is about 780mm tall, and really see how good the Z alignment, straightness, parallelism, etc are. I could print a large spiral vase box or cylinder and see quickly but that would be too easy!
                      Chris
                      Phaedruxundefined dc42undefined 2 Replies Last reply Reply Quote 0
                        Phaedrux Moderator @coseng
                        @coseng said in New heated enclosure printer:
                        Not that I'm aware of.
                          dc42 administrators @coseng
                          No, but you can read the PWM averaged over the last 20 seconds or so from the object model.
                          • cosengundefined
                            coseng @dc42
                            @dc42 OK, that is some info. How would I do that? Another option is to rig up an independent arduino logger. I guess if it is printing fine then no reason to fix it!
                            Chris
                              Is there a fan in the enclosure to stir the air?
                              I assume the chamber heater is below the bed, so possibly having a stronger effect on the bed thermistor directly above it.
                              • cosengundefined
                                coseng
                                The tank finished successfully and is a mostly a really good print.
                                The only issues are on the horizontalish areas where I think another inner wall or skin layer is needed.
                                I was pleasantly surprised with how easily the standard supports broke off and the finish under them is still pretty good. I think a bottom skin is also needed. It is completely internal so does not really matter but it is nice to have 100% nice parts.
                                I then went tall and tried the subframe, but with minimal supports, which ended up being a mistake.
                                One out of two legs printed fine, so this could still be used as a mockup and i am letting it finish. On hindsight, I was suspicious of the small islands with nothing joining them to the main brim but decided to run it anyway. I'll add some supports before rerunning it.
                                Chris
                                • cosengundefined
                                  coseng @Phaedrux
                                  @phaedrux There are two recirculation fans below the two heater/fans heater units that are on the negative YZ wall of the chamber. The top of the table has a thin self-adhesive FEP sheet and the bottom is the silicone foam insulated heater. The table does divide the chamber into two sections pretty well with only about 1" clearance around the outside.
                                  It is printing pretty consistently over 10+ hour runs, so at this point I'll think about it a little more, but just keep running with the same temp settings and not change the hardware at all. Maybe some slicer setting changes to correct those print gaps, since I strongly think those are slicer and not thermal or feed related. At the end of that 13hr print, the filament pinch wheel was completely free from any evidence of filament grinding/slippage, so am getting very positive filament drive.
                                  The prints are coming out fine, but I am having one issue that requires me to babysit the first two layers. On the fist layer, the filament sometimes stops feeding. I notice it by the spool feed stepper not doing its chirp to feed. With my filament feed setup I can give a little manual push to the filament, then it starts feeding fine again. This happens 3-4 times on the first layer, then not again during the rest of the print. Each time it happens I have to blow off the pinch area because there are a lot of filament shards. Once the first layer is finished it does not happen again and as mentioned, at the end of the print the filament pinch area remains completely clean of debris.
                                  The bed is flat. I test it at temp using a plunge indicator clamped to the printhead carriage and get about 0.05mm total variance. I tried using the BL Touch for bed mesh, but was getting hugely varying scans that did not correspond to a mechanical check with an indicator. Now I just use the BLTouch for Z homing and it seems to preform repeatably and I print with no bed mesh compensation.
                                  Also, FYI there is about 0.8mm difference in Z homing between hot and cold states.
                                  Chris
                                    Yeah that's definitely a slicer thing. The defaults in Cura don't handle shallow slopes like that very well. I think you want skin removal width and skin expand distance. More top/bottom layers could probably help too.
                                    Is it too much back pressure on the first layer? Too slow?
                                    cosengundefined 2 Replies Last reply Reply Quote 0
                                    • cosengundefined
                                      coseng @Phaedrux
                                      @phaedrux said in New heated enclosure printer:
                                      Good question! I don't know. Here are a couple of shots of it while printing the frist layer. It looks blobby, but the rest of the part comes out great.
                                      It sounds a little like the printhead is hitting some of these high spots when doing non-print moves. Maybe it is over-extruding a little for the first layer? The bed is flat and the thickness of the extrusion and these blobby results look consistent across the part.
                                      I'll dig a bit into looking at how the Cura skin settings work, thanks for the start.
                                      Chris
                                        Yeah definitely. That's a messy first layer. Should be flat and smooth. I think the filament has nowhere to go it's pushing out and causing back pressure. Either too close, or flow too high. If the subsequent layers look fine, then it's probably too close.
                                        If you don't want to mess with the probe distance just try cutting the first layer flow rate a bit.
                                        cosengundefined 2 Replies Last reply Reply Quote 1
                                        • cosengundefined
                                          coseng @Phaedrux
                                          @phaedrux If you don't want to mess with the probe distance just try cutting the first layer flow rate a bit.
                                          OK, that's what I will try for this next overnight print of the other tank half, also with some revised skin settings to eliminate those sloped surface gaps.
                                          Chris
                                          • cosengundefined
                                            coseng @Phaedrux
                                            @phaedrux Seems that the initial layer flow rate was set to 120%. I set it back to 100% and hopefully that will resolve the issues. Fingers crossed.
                                            Since printing ABS is going so well, I ordered a small spool of clear PC to see if it would be able to print a clearish windscreen.
                                            Chris
