HELP! Can't log in to both machinesWIFI passwords!?
58
3.3k
    FuseDeep @infiniteloop
    @infiniteloop
    My android phone is asking for a password now.
    MODS/tech supremos, I really need to know how to get round either phantom network key request/password or a reset of the board and keep my machine set up!
    Definitely no password on fusedeep but now always asked for key, not sure about point6 machine but do not have the password anway (and sd card well tucked away currently).
    Must get both machines working properly ASAP.
    Thanks Rich
    undefined 1 Reply Last reply 16 Jun 2022, 16:19 Reply Quote 0
      Stephen6309 @FuseDeep
      @fusedeep On the duet, do you have a SSID/password set up for the wifi connection and does that work?
        FuseDeep
        DEFINITELY no gcode passwords on either set up.
        Just checked.
        So, my laptop now seems to be looking for a "network security key" (different to password) and, oddly, my android phone won't connect to either without a password (so won't connect).
        i did add a password to FuseDeep but it did not connect properly. Now removed (via SD card direct edit.
        Plus putty not connecting and YAT borked ages ago.
        Am in real trouble here!
        undefined 1 Reply Last reply 16 Jun 2022, 17:10 Reply Quote 0
          infiniteloop @FuseDeep
          @fusedeep said in HELP! Can't log in to both machinesWIFI passwords!?:
          And...putty is not connecting (yat won't install) so cannot simply check things.
          Sorry, missed this one. Putty (or yat, or DWC, …) won't work because you've lost your local WiFi network - which, until now, was managed by your laptop (as a "software router"). Without this, your WiFi devices cannot communicate.
          As I already told you, I see two options:
          1. get your laptop to connect to the router (no idea how, sometimes you can find the initial password on the back of the router). Or you reset the router and re-configure it from scratch.
          2. configure the Duet in WiFi access point mode (you got the proper link from @Stephen6309), then, try to connect from your laptop or your phone.
          As I've learned, you don't have a physical router, so option #1 now means to re-establish the routing functionality of your laptop…
          If you don't recall the "network security key", how shall I? Forget the passwords on the Duets, it's the (local) network that matters. Currently, you don't have any.
          Be happy that you can control one of your printers locally. On the other one ("point6", I guess?), you can try option #2, but be warned: it takes some time to properly set up the Duet as a WiFi access point.
            fcwilt @FuseDeep
            @fusedeep
            Do you by any chance have a standalone WiFi access point?
            With that you could setup the Duets as typical WiFi clients.
            undefined 1 Reply Last reply 17 Jun 2022, 09:13 Reply Quote 0
              So I seem to recall from your past threads that you use the Duet in Access Point mode where the Duet creates the network and your laptop connects to the Duet SSID. This is likely what it's asking for as a password.
              Can you share your config files with us here?
              If you can't recall what the password was for the the SSID, you can simply create a new one.
              Take a deep breath. Panic never helps. I'm confident we can get you back up and running.
              Here is the information for getting access point mode working:
              https://docs.duet3d.com/User_manual/Reference/Gcodes#m589-configure-access-point-parameters
              Do you have an M589 command in your config.g? That's where the password is set.
              The M551 password is something else and you don't need or want to set one there right now. So if your config still has that, remove it.
              undefined 2 Replies Last reply 17 Jun 2022, 09:17 Reply Quote 1
                FuseDeep @fcwilt
                @fcwilt Nope, never ever have had.
                Always worked fine til my laptop wifi borked.
                  FuseDeep @Phaedrux
                  @phaedrux
                  I tried another different laptop and it also wanted network security key for both machines this morning, no idea if this is usual as I don't think I have tried to connect before with another.
                  I may have had a key (?) or not, either way, need to refresh both duet boards, ascertain key and get them running asap.
                  Have done the big print I needed but wanted to do a load of info sheet holders today on the point6...
                  Point6 M2 desktop 3dprinter config file
                  ; Configuration file for Duet WiFi (firmware version 3.3)
                  ; generated by RepRapFirmware Configuration Tool v3.3.10 on Wed Apr 20 2022 11:07:59 GMT+0100 (British Summer Time)
                  M550 P"DUET 0.6mm HB / Son.im" ; set printer name
                  M552 S1 ; enable network
                  M586 P0 S1 ; enable HTTP
                  M586 P1 S0 ; disable FTP
                  M586 P2 S0 ; disable Telnet
                  M92 X88.89 Y88.89 Z400.00 E420.00 ; set steps per mm
                  M84 S30 ; Set idle timeout
                  M208 X200 Y250 Z185 S0 ; set axis maxima
                  M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
                  M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
                  M574 Z1 S1 P"zstop" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin zstop
                  M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
                  M557 X15:200 Y15:195 S20 ; define mesh grid
                  M307 H0 R0.227 K0.317:0.000 D10.46 E1.35 S1.00 B0
                  ; enable bang-bang mode for the bed heater and set PWM limit
                  M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned on
                  M106 P1 S1 H1 T40 ; set fan 1 value. Thermostatic control is turned off
                  M563 P0 D0 H1 F0 ; define tool 0 // M563 P0 D0 H1 F0 added T0
                  M552 S2
                  T0
                    FuseDeep @Phaedrux
                    @phaedrux
                    Config file for 2m tall 3dprinter.
                    Basically need to sort new key and get it running
                    ; generated by RepRapFirmware Configuration Tool v2.1.4 on Mon Dec 30 2019 12:38:09 GMT+0000 (Greenwich Mean Time)
                    M550 P"FuseDeep" ; set printer name
                    M569 P0 S0 ; physical drive 0 goes backwards
                    M569 P2 S0 ; physical drive 2 goes backwards
                    M569 P4 S1 ; physical drive 4 goes forwards
                    M584 X0 Y1:4 Z2 E3 ; set drive mapping
                    M92 X53.33 Y53.33 Z4266.67 E406.47 ; set steps per mm
                    M203 X6000.00 Y6000.00 Z180.00 E5000.00 ; set maximum speeds (mm/min) RG was 2700
                    M201 X500.00 Y500.00 Z2.00 E500.00 ; set accelerations (mm/s^2) RG was 250
                    M906 X1350 Y1600 Z1600 E1350 I30 ; set motor currents (mA) and motor idle factor in per cent
                    M208 X620 Y550 Z1440 S0 ; set axis maxima
                    M574 X1 Y1 Z1 S1 ; set active high endstops
                    M558 P0 H5 F120 T3000 ; disable Z probe but set dive height, probe speed and travel speed
                    M140 H-1 ; disable heated bed
                    M305 P1 T100000 B4725 C7.060000e-8 R4700 ; set thermistor + ADC parameters for heater 1
                    M106 P0 S0 I0 F500 H1 T45 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
                    M563 P0 S"TITAN Extruder" D0 H1 F0 ; define tool 0
                    ; Custom settings
                    M552 S2
                    undefined 1 Reply Last reply 17 Jun 2022, 09:49 Reply Quote 0
                      oliof
                      The Configuration for the Wifi is not stored in config.g but in the wifi chip.
                      You will need to do the following:
                      a) connect to the printer via serial console
                      b) Set a new password for the access point mode using M589
                      c) save the new password somewhere safe for reference
                      d) enable the access point mode using M552 S2
                      e) use the password set using M589 when your computer prompts you for a network security key
                      Let us know how this works out.
                      undefined 1 Reply Last reply 17 Jun 2022, 10:46 Reply Quote 0
                        droftarts administrators @FuseDeep
                        @fusedeep you are running M552 S2 on both machines at the end of config.g. This puts both machines in ‘accesss point’ mode, so the laptop connects directly to the WiFi of each machine. At some point you will have set this up with M589. In that command you specify the SSID (the name of the network) and a password. It is this password that your laptop appears to have forgotten. If you didn’t write the password down, you need to connect via USB, and send M589 with SSID and password to set up the Duet access point. You can also do this by writing the commands into a macro called runonce.g, which will run and then delete itself at startup (so make a copy in case it doesn’t work). See https://docs.duet3d.com/en/User_manual/Machine_configuration/Networking#configuring-duet-in-wifi-access-point-mode
                        The commands in a macro would be:
                        M552 S0 ; sets WiFi to idle
                        G4 S5 ; wait 5 seconds for WiFi to turn off
                        M589 S"DuetSSID" P"password" I192.168.0.1
                        G4 S5 ; wait again
                        M552 S2 ; enable access point
                        undefined 3 Replies Last reply 17 Jun 2022, 10:36 Reply Quote 1
                          FuseDeep @droftarts
                          @droftarts
                          Hi, thanks for the information.
                          Can i do this directly in the sd card edit?
                          Yat is borked and putty playing up (I am not an IT expert either, consoles freak me out when they don't work).
                          Rich
                          undefined 1 Reply Last reply 17 Jun 2022, 11:03 Reply Quote 0
                            FuseDeep @droftarts
                            @droftarts
                            I have 2 duet running. Should the ssid label for each be different, Yes, only use ad hoc.
                            Rich
                              FuseDeep @oliof
                              This post is deleted!
                                FuseDeep @droftarts
                                @droftarts
                                My gut feeling is this has nothing to do with M589 etc.
                                It never had one and my android phone won't connect with the M589 password either.
                                It's something else imo.
                                  Yes. Create a text file with the Gcode commands I listed earlier. Save it on your local machine as "runonce.g". Copy it to the SD card from one of the printers, in the "sys" folder. Return SD card to machine, turn on machine, give it a minute, then try and connect.
                                  Do one at a time, giving them different SSID names and IP addresses (I think, from memory, you gave them both the same IP address before; this could be where it's got confused). The password can be the same for both, though.
                                  FYI: File runonce.g is supported from RRF3.1.0 and later. If this file is present at startup, it is run after running config.g and activating the network, and then deleted. So I hope you're not on RRF 2.x!
                                  undefined 2 Replies Last reply 17 Jun 2022, 11:11 Reply Quote 0
                                    FuseDeep @droftarts
                                    @droftarts
                                    But, I have put the M859 code line directly and nothing will connect using that pasword.
                                    What is the difference using a one time widget?
                                    undefined 1 Reply Last reply 17 Jun 2022, 11:21 Reply Quote 0
                                      FuseDeep @droftarts
                                        @fusedeep You need to turn off the Access Point (with M552 S0), change the SSID/password (with M587), then turn it back on again. The macro does this for you.
                                        If you're able to do this with a serial terminal (putty/YAT), you don't need to use a macro.
                                        Save the file as a .txt file, then edit the name and replace '.txt' with '.g'.
                                        undefined 2 Replies Last reply 17 Jun 2022, 11:32 Reply Quote 0
                                          FuseDeep @droftarts
                                          @droftarts
                                          I have added;
                                          To my point 6 (with my password) and it won't accept the password.
                                          Nor will my phone.
                                          Or my other laptop.
                                          They keep asking for NETWORK SECURITY KEYS, I don't think this is anything to do with gcode passwords and a fundamental password deep in duet that is either borked or I forgot.
                                          It's a real problem people.
                                          I was nervous about going wifi, and this is exactly why...
                                          undefined 1 Reply Last reply 17 Jun 2022, 11:52 Reply Quote 0
                                          38 out of 58
