    How do I remove the pin of the 6-pin Molex connector?
    Smart effector for delta printers
    4.5k
    • bbergerundefined
      bberger
      How do I get the pin out of this mess?
      Rushmere3Dundefined fcwiltundefined deckingmanundefined Adrian52undefined 4 Replies Last reply Reply Quote 0
      • Rushmere3Dundefined
        Rushmere3D @bberger
        @bberger Molex pins are a pain, you need to get down the sides on the pins to push the tabs in.
        Follow my adventures in 3D Printing, laser cutting and electronics. https://linktr.ee/Rushmere3D
        • fcwiltundefined
          fcwilt @bberger
          @bberger
          There should be a tool you can obtain to remove those.
          • bbergerundefined
            bberger
            Which direction are the pins? Left/Right or Top/Bottom if you view the connector from the bottom and the connector pin is at the top?
              deckingman @bberger
              @bberger You can buy a tool for about £20 GBP. Alternatively, this might help https://www.youtube.com/watch?v=IFR9Wnslruk
              • Adrian52undefined
                Adrian52 @bberger
                @bberger I think the best thing I bought for the smart effector is a pre-wired strain relieved molex lead from digikey - no problems for a couple of years.
                • zaptaundefined
                  zapta
                  The connector looks like a Molex microfit 3 (?).
                  I use the Molex tool HT60923A aka 0011030043. It's easy to remove once you get the technique, inserting from the front on the right and left sides of the pin and on each side, rotate it a little back and forth to release the pin. It works for both male and female Microfit 3.
                  https://duckduckgo.com/?q=molex+HT60923A&atb=v88-4_g&iax=images&ia=images
