Problems setting up stall detection
I am trying to set up stall detection without sensorless homing (I have microswitches) but the printer seems to be ignoring me, as there is no expected response. The documentation says "Once your print is going and stall detection is flashing in the console.." but I don't get any such indication. I don't get any messages in the console either. It's like I've missed a basic step, but where? This coding is really at the limit of my experience so I may have missed the obvious.
I have:
- set up as stated in the documentation, as far as I can tell.
- Created a rehome.g file and saved to system files
- made changes to my SuperSlicer START and END custom codes
- Tweaked M906, M201, M566 in config.g
- Tested several prints with different slicing parameters but none has made any difference
Board: Duet 3 Mini 5+ (Mini5plus)
Firmware: RepRapFirmware for Duet 3 Mini 5+ 3.4.0 (2022-03-15)
Duet WiFi Server Version: 1.26X and Y Motors: Nema 17 48mm, 1.8 degree/step
undefined TomF referenced this topic
Where are you enabling stall detection? It's commented out in your config.g
;M915 X Y S3 R1 F1 ; stall detection
Only in your slicer start gcode?
I think you've misunderstood the point of the rehome,g file. Yours just has the M915 command in it again. This file should also contain some commands to actually rehome the axis. Like G28 XY.
When you force a stall during a print what actually happens?
Thanks for the feedback.
I had M915 enabled in config.g but it didn't make any difference. The documentation doesn't say to change anything in config other than modify the speed, acceleration, etc., so I then commented the M915 command out. Now I know, I'll enable it again.
I understand there's more to rehome but haven't done so yet as there is no response to the basics like 'stall detection enabled'. I'll add the home XY instruction anyway and try again.
I made those changes to config and rehome and still no response. When I force a stall of the X or Y axis, it just stalls and carries on from it's new location. There is no message in console, there's no 'stall detection' flashing in the console. Basically no indication that anything is different from before.
Updated files:
See the notes in M915 documentation
In RRF v3.4 and later there is no longer a distinction between R2 and R3; both cause an event to be created when the driver stalls. To handle the event, RRF calls driver-stall.g passing the stalled local driver number in param.D and the CAN address of the board concerned in param.B. File rehome.g is no longer used. If file driver-stall.g is not found then the print is paused without running pause.g and the error is reported.On my system I have in config.g
M915 H240 X Y S3 R2 ; set stall detection for X & Y axis. driver-stall.g will be run. if !exists(global.InMacro) ; macro used to check if we're already in a macro to avoid running triggers multiple times global InMacro = false else set global.InMacro = false
And in driver-stall.g I have the code below.
;0:/sys/driver-stall.g ; check if a driver stall is already being acted on. if global.InMacro = true echo "Driver stall macro already running - no further action taken" M99 ; exit macro set global.InMacro=true if job.file.fileName!= null ; check if we are printing echo " A driver stall has occured on driver " ^ param.D echo "Layer shifting may have occured at X:",move.axes[0].machinePosition, "Y:", move.axes[1].machinePosition, "Z:", move.axes[2].machinePosition G4 P5 ; if a tool is selected and the heater is up to temp we'll retract if heat.heaters[tools[max(state.currentTool,0)].heaters[0]].current > heat.coldRetractTemperature G10 G1 F1800 ; reduce speed before homing G28 X Y ; if a tool is selected and the heater is up to temp, we'll un-retract if required. if (heat.heaters[tools[max(state.currentTool,0)].heaters[0]].current > heat.coldExtrudeTemperature) && (tools[max(state.currentTool,0)].isRetracted) G11 G4 S1 set global.InMacro = false
You may have to tune the settings to get reliable results.
Thanks! I had missed the part about rehome.g being 'discontinued' and driver-stall.g being used instead when R2 (or R3) is called.
That said, I haven't called either R2 or R3 yet. I'm still on R1 "just log it" and the root of my problem is that there is no console report when I force a stall, or at any other time. There is no message flashing in the console - I am simply getting no response whatsoever to my attempts to implement stall detection.
As I understand it, with R1, the driver-stall.g is not needed.
But once I get past this current hurdle, then I certainly will need to go to R2 and the fun really starts. I'm struggling to understand what you have done in the driver-stall.g file because I'm not very experienced in gcode and macros are above my level. Your comments in the file are very helpful and I see what you are doing but not sure about the details. Are the macros necessary in config.g? And in driver-stall.g? Is it possible to just have the M915 H240 X Y S3 R2 line in config, and G28 XY in driver-stall.g?
@tomf
Yes, you could just have those two commands -
@owend
Do you get a stall detection message flashing in the console?
When a stall occurs or if you force a stall, do you get a message in the console?
