    I could use some help
    682
    64.0k
      A Former User @A Former User
      @droftarts the print head's six inches off the bed
      • fcwiltundefined
        fcwilt @A Former User
        @mac said in I could use some help:
        @droftarts new M119: X not stopped, Y not stopped, Z at min stop, Z probe not stopped
        Great!
        Notice that it says Z at min stop - was the Z endstop switch actually closed when you ran the M119?
        • fcwiltundefined
          I just asked a related question about the Z endstop switch.
          Now you need to find a way to execute the M119 while both the X and Y endstop switches are closed - maybe with a bit of tape or a rubber band?
            A Former User @fcwilt
            @fcwilt the only thing that would close the z endstop is if the X axis came down and closed it.
              @fcwilt wait, fcwilt? not droftarts? jeeze you guys are ganging up on me!
              A Former User? fcwiltundefined 2 Replies Last reply Reply Quote 0
              • fcwiltundefined
                OK that's good to know.
                If the white wire is actually connected to the NO connection of the Z endstop switch it should not be indicating Z at min stop.
                Find a way to close the Z endstop switch and execute M119.
                I want to see if it still reports Z at min stop or if it reports something different.
                  @droftarts @fcwilt if we're going to work on this together, I need to know you two are in agreement before I do anything.
                  Do you both agree that I should tape X and Y closed? Then M119 again?
                  fcwiltundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                  • fcwiltundefined
                    No - it just gets confusing when posts overlap in time.
                    I'm typing, your typing, droftarts is typing - and things get a bit out of order - time wise.
                    • fcwiltundefined
                      Mac! You've cut me to the quick! Have you no faith in me! 😉
                      I've only been doing this stuff for years.
                        @fcwilt @droftarts I closed the z-endstop with my left finger, and hit M110 Send with my right finger. M119 reported Z: at end stop, Z probe: not stopped.
                        I'm not making this up, guys.
                          @fcwilt @droftarts I'm just trying to be respectful to Ian and you.
                            droftarts administrators @A Former User
                            @mac I’m not able to reply promptly now, I’m away from my computer. @fcwilt knows what he’s doing, though please keep it simple, Frederick!
                            • fcwiltundefined
                              fcwilt @droftarts
                              @droftarts said in I could use some help:
                              I try to keep it simple, I really do.
                                @fcwilt @droftarts
                                M569 P0.0 S1                                       ; physical drive 0.0 goes forwards
                                M569 P0.1 S1                                       ; physical drive 0.1 goes forwards
                                M569 P0.2 S1                                       ; physical drive 0.2 goes forwards
                                M569 P0.3 S1                                       ; physical drive 0.3 goes forwards
                                M584 X0.0 Y0.1 Z0.2 E0.3                           ; set drive mapping
                                M92 X40.00 Y40.00 Z2000.00 E420.00                 ; set steps per mm
                                M350 X16 Y16 Z16 E16 I1                            ; configure microstepping with interpolation
                                M566 X900.00 Y900.00 Z60.00 E120.00                ; set maximum instantaneous speed changes (mm/min)
                                M203 X6000.00 Y6000.00 Z600.00 E1200.00            ; set maximum speeds (mm/min)
                                M201 X500.00 Y500.00 Z200.00 E250.00               ; set accelerations (mm/s^2)
                                M906 X600 Y600 Z600 E600                           ; set motor currents (mA)
                                M84 S0                                             ; Disable motor idle current reduction
                                  @mac M92 cut and pasted to before M350, board rebooted.
                                    @fcwilt okay, I get it, let's continue on, shall we, Frederick?
                                    • fcwiltundefined
                                      I know you are not. I have complete faith in you.
                                      So as far as you can see M119 reports that same for the Z endstop switch regardless of it being pressed closed or not?
                                      Interesting.
                                      How about doing the same for the X and Y endstop switches. You can press just one at a time and execute the M119 for each one. It is not necessary to press them both at the same time.
                                      What we want to verify is that M119 reports the correct thing for both states of the endstop switches, pressed and not pressed.
                                        @fcwilt I just ran M119 again, it's reporting: X not stopped, Y not stopped, Z at min stop, Z probe not stopped.
                                          @fcwilt I just verified that with the z-endstop pushed down, M119 is reporting the same information as above.
                                          • fcwiltundefined
                                            OK let's leave Z for now and test X and Y.
