    I could use some help
    682
    64.0k
      A Former User @fcwilt
      @fcwilt thanks very much. hopefully, I'll be printing the next time we speak.
      • fcwiltundefined
        fcwilt @A Former User
        @mac said in I could use some help:
        Did you get Z homing to work?
          @fcwilt Let's talk later. If I make a video of it, I'll send you a link.
            This post is deleted!
              A Former User @A Former User
              @fcwilt
              G91                      ; relative positioning
              G1 H2 Z5 F3600           ; lift Z relative to current position
              G1 H1 X225 Y225 F1800    ; move quickly to X and Y axis endstops and stop there (first pass)
              G1 H2 X-5 Y-5 F3600      ; go back a few mm
              G1 H1 X225 Y225 F360     ; move slowly to X and Y axis endstops once more (second pass)
              G90                      ; absolute positioning
              G1 X-10.875 Y4.375 F3600 ; go to first bed probe point and home Z
              G30                      ; home Z by probing the bed
              This is the code that's in the system. It doesn't look like your suggestion? So I'm not sure how to proceed.
              • fcwiltundefined
                @fcwilt
                As I mentioned that is the code for homing with a Z probe.
                You have a Z endstop switch as well so you can use that, instead of the Z probe, and get quicker and simpler homing.
                We discussed getting rid of that code and replacing it with my code.
                What happened to doing that?
                A Former User? 2 Replies Last reply Reply Quote 0
                  @fcwilt
                  ; homeall.g
                  ; called to home all axes
                  ; generated by RepRapFirmware Configuration Tool v3.3.10 on Mon Jun 27 2022 06:45:01 GMT-0700 (Pacific Daylight Time)
                  M98 P"homeZ.g"
                  M98 P"homeX.g"
                  Mpo P"homeY.g"
                  ;G91                     ; relative positioning
                  ;G1 Z5 F60               ; lift Z relative to current position
                  ;G90                     ; absolute positioning
                  This is what I put in homeall.g's place.
                    @fcwilt link text
                    The is Z homing again.
                    • fcwiltundefined
                      @fcwilt
                      ; homeall.g
                      M98 P"homeZ.g"
                      M98 P"homeX.g"
                      Mpo P"homeY.g"
                      So you where showing me the code from homeall.g - I misunderstood.
                      That code you now have will work fine IF the individual homing files work.
                      You can strip it down to this:
                      ; homeall.g
                      M98 P"homeZ.g"
                      M98 P"homeX.g"
                      M98 P"homeY.g"
                      But don't test it until you have verified that homing each axis by itself is working.
                        @fcwilt that's what I'm working on right now.
                          @fcwilt
                          link text
                          This the first effort to home X and Y.
                          fcwiltundefined alankilianundefined 2 Replies Last reply Reply Quote 0
                          • fcwiltundefined
                            @fcwilt
                            link text
                            OK X is behaving very strangely.
                            But as to Y:
                            Is the Y endstop at the front of the machine or the back?
                            • alankilianundefined
                              alankilian @A Former User
                              @mac I see that the Duet Mini 5+ does not have on-PCB pullups on the IO pins.
                              You need to go to the RRF configurator and select "Active low with pullup" if you are using normally-open switches connected to ground as endstops.
                              Without a pullup, every time a stepper motor starts moving, your machine will start to get signals indicating the endstop switch is being pressed.
                                @fcwilt it’s at the back.
                                  A Former User @alankilian
                                  @alankilian sorry to disappear, texting on this iPhone 8’s a bitch. I’ll make that change and post a video of the results do you can see the results.
                                  • fcwiltundefined
                                    So you have a moving bed.
                                    To get to the max end of Y the bed moves toward the front?
                                    To get to the min end of Y the bed moves toward the back?
                                    But stepping Y by minus 10 caused it to move toward the front?
                                    elmoretundefined A Former User? 2 Replies Last reply Reply Quote 0
                                    • elmoretundefined
                                      elmoret @fcwilt
                                      273 posts! 😮
                                      • fcwiltundefined
                                        fcwilt @elmoret
                                        @elmoret said in I could use some help:
                                        273 posts! 😮
                                        A lot I know. We will get mac sorted.
                                          @fcwilt yes, that is what’s happening. The bed did touch the endstop and then back off; that’s an improvement.
                                          • fcwiltundefined
                                            Here's the problem.
                                            When you tried jogging Y by -10 it went toward the front? Correct?
                                            But the homing moves were supposed to be:
                                            • a minus move
                                            • a plus move
                                            • a minus move
                                            Based on the jogging test it should have moved:
                                            • toward the front
                                            • toward the back
                                            • toward the front
                                            I think there are two problems:
                                            • the normal/reverse setting for the Y stepper is wrong (see M569 P0...)
                                            • the steps per mm are wrong - too few (see M92)
                                            I would like you to:
                                            • change the M569 setting from whatever it is to the other setting
                                            • try the home Y test and observe the movements
                                            • try the jogging test and verify the correct directions
                                            • if the directions are correct find some means to measure a move of, say, 100mm and see if a 100mm jog moves that distance.
