    I could use some help
    682
    64.0k
    • fcwiltundefined
      fcwilt @A Former User
      @mac said in I could use some help:
      @fcwilt
      ; homeall.g
      ; called to home all axes
      ; generated by RepRapFirmware Configuration Tool v3.3.10 on Mon Jun 27 2022 06:45:01 GMT-0700 (Pacific Daylight Time)
      M98 P"homeZ.g"
      M98 P"homeX.g"
      Mpo P"homeY.g"
      ;G91                     ; relative positioning
      ;G1 Z5 F60               ; lift Z relative to current position
      ;G90                     ; absolute positioning
      This is what I put in homeall.g's place.
      So you where showing me the code from homeall.g - I misunderstood.
      That code you now have will work fine IF the individual homing files work.
      You can strip it down to this:
      ; homeall.g
      M98 P"homeZ.g"
      M98 P"homeX.g"
      M98 P"homeY.g"
      But don't test it until you have verified that homing each axis by itself is working.
        A Former User @fcwilt
        @fcwilt that's what I'm working on right now.
          A Former User @A Former User
          @fcwilt
          link text
          This the first effort to home X and Y.
          fcwiltundefined alankilianundefined 2 Replies Last reply Reply Quote 0
          • fcwiltundefined
            @fcwilt
            link text
            OK X is behaving very strangely.
            But as to Y:
            Is the Y endstop at the front of the machine or the back?
            • alankilianundefined
              alankilian @A Former User
              @mac I see that the Duet Mini 5+ does not have on-PCB pullups on the IO pins.
              You need to go to the RRF configurator and select "Active low with pullup" if you are using normally-open switches connected to ground as endstops.
              Without a pullup, every time a stepper motor starts moving, your machine will start to get signals indicating the endstop switch is being pressed.
                @fcwilt it’s at the back.
                  A Former User @alankilian
                  @alankilian sorry to disappear, texting on this iPhone 8’s a bitch. I’ll make that change and post a video of the results do you can see the results.
                  • fcwiltundefined
                    So you have a moving bed.
                    To get to the max end of Y the bed moves toward the front?
                    To get to the min end of Y the bed moves toward the back?
                    But stepping Y by minus 10 caused it to move toward the front?
                    elmoretundefined A Former User? 2 Replies Last reply Reply Quote 0
                    • elmoretundefined
                      elmoret @fcwilt
                      273 posts! 😮
                      • fcwiltundefined
                        fcwilt @elmoret
                        @elmoret said in I could use some help:
                        273 posts! 😮
                        A lot I know. We will get mac sorted.
                          @fcwilt yes, that is what’s happening. The bed did touch the endstop and then back off; that’s an improvement.
                          • fcwiltundefined
                            Here's the problem.
                            When you tried jogging Y by -10 it went toward the front? Correct?
                            But the homing moves were supposed to be:
                            • a minus move
                            • a plus move
                            • a minus move
                            Based on the jogging test it should have moved:
                            • toward the front
                            • toward the back
                            • toward the front
                            I think there are two problems:
                            • the normal/reverse setting for the Y stepper is wrong (see M569 P0...)
                            • the steps per mm are wrong - too few (see M92)
                            I would like you to:
                            • change the M569 setting from whatever it is to the other setting
                            • try the home Y test and observe the movements
                            • try the jogging test and verify the correct directions
                            • if the directions are correct find some means to measure a move of, say, 100mm and see if a 100mm jog moves that distance.
                              alankilian @fcwilt
                              @fcwilt said in I could use some help:
                              a minus move
                              a plus move
                              a minus move
                              toward the front
                              toward the back
                              toward the front
                              Since it's a bed-slinger in Y, isn't a PLUS move going to move the bed towards the FRONT? (Move the head towards the +y part of the bed.)
                              I may be confused.
                              • fcwiltundefined
                                fcwilt @alankilian
                                @alankilian said in I could use some help:
                                a minus move
                                a plus move
                                a minus move
                                toward the front
                                toward the back
                                toward the front
                                I may be confused.
                                Correct (about the move, not about being confused). 😉
                                But according to mac a minus jogging move was moving the beds towards the front. I can only go by what he posts.
                                  @fcwilt Y homes like it should. None of the + moves work. When I -10 it moves FORWARDS.
                                  A Former User? fcwiltundefined 2 Replies Last reply Reply Quote 0
                                    @mac
                                    ; Configuration file for Duet 3 Mini 5+ (firmware version 3.3)
                                    ; generated by RepRapFirmware Configuration Tool v3.3.10 on Mon Jun 27 2022 12:50:38 GMT-0700 (Pacific Daylight Time)
                                    G90                                                ; send absolute coordinates...
                                    M83                                                ; ...but relative extruder moves
                                    M550 P"Frankenstein's Cinderella"                  ; set printer name
                                    M552 S1                                            ; enable network
                                    M586 P0 S1                                         ; enable HTTP
                                    M586 P1 S0                                         ; disable FTP
                                    M586 P2 S0                                         ; disable Telnet
                                    M569 P0.0 S1                                       ; physical drive 0.0 goes forwards
                                    M569 P0.1 S1                                       ; physical drive 0.1 goes forwards
                                    M569 P0.2 S1                                       ; physical drive 0.2 goes forwards
                                    M569 P0.3 S1                                       ; physical drive 0.3 goes forwards
                                    M584 X0.0 Y0.1 Z0.2 E0.3                           ; set drive mapping
                                    M350 X16 Y16 Z16 E16 I1                            ; configure microstepping with interpolation
                                    M92 X80.00 Y80.00 Z4000.00 E420.00                 ; set steps per mm
                                    M566 X900.00 Y900.00 Z60.00 E120.00                ; set maximum instantaneous speed changes (mm/min)
                                    M203 X6000.00 Y6000.00 Z600.00 E1200.00            ; set maximum speeds (mm/min)
                                    M201 X500.00 Y500.00 Z200.00 E250.00               ; set accelerations (mm/s^2)
                                    M906 X600 Y600 Z600 E600                           ; set motor currents (mA)
                                    M84 S0                                             ; Disable motor idle current reduction
                                    M208 X0 Y0 Z0 S1                                   ; set axis minima
                                    M208 X220 Y220 Z240 S0                             ; set axis maxima
                                    M574 X2 S1 P"!^io5.in"                             ; configure switch-type (e.g. microswitch) endstop for high end on X via pin !^io5.in
                                    M574 Y2 S1 P"!^io6.in"                             ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin !^io6.in
                                    M950 S0 C"io3.out"                                 ; create servo pin 0 for BLTouch
                                    M558 P9 C"io3.in" H5 F120 T3600                    ; set Z probe type to bltouch and the dive height + speeds
                                    G31 P500 X15.875 Y0.625 Z2.5                       ; set Z probe trigger value, offset and trigger height
                                    M557 X5:190 Y5:215 S10                             ; define mesh grid
                                    M308 S0 P"temp0" Y"thermistor" T100000 B4092       ; configure sensor 0 as thermistor on pin temp0
                                    M950 H0 C"out0" T0                                 ; create bed heater output on out0 and map it to sensor 0
                                    M307 H0 B0 S1.00                                   ; disable bang-bang mode for the bed heater and set PWM limit
                                    M140 H0                                            ; map heated bed to heater 0
                                    M143 H0 S33                                        ; set temperature limit for heater 0 to 33C
                                    M308 S1 P"temp1" Y"thermistor" T100000 B4092       ; configure sensor 1 as thermistor on pin temp1
                                    M950 H1 C"out1" T1                                 ; create nozzle heater output on out1 and map it to sensor 1
                                    M307 H1 B0 S1.00                                   ; disable bang-bang mode for heater  and set PWM limit
                                    M143 H1 S100                                       ; set temperature limit for heater 1 to 100C
                                    M950 F0 C"out3" Q500                               ; create fan 0 on pin out3 and set its frequency
                                    M106 P0 S0 H-1                                     ; set fan 0 value. Thermostatic control is turned off
                                    M950 F1 C"out4" Q500                               ; create fan 1 on pin out4 and set its frequency
                                    M106 P1 S1 H1 T45                                  ; set fan 1 value. Thermostatic control is turned on
                                    M563 P0 S"optional" D0 H1 F0                       ; define tool 0
                                    G10 P0 X0 Y0 Z0                                    ; set tool 0 axis offsets
                                    G10 P0 R0 S0                                       ; set initial tool 0 active and standby temperatures to 0C
                                    M501                                               ; load saved parameters from non-volatile memory
                                    M911 S21 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
                                    • fcwiltundefined
                                      I understand about the jogging move.
                                      And since it is wrong you need to change normal to reverse or vice-versa in the M569 for the Y stepper.
                                      That should get jogging going in the right direction.
                                      IF it does try homing Y
                                        @mac
                                        ; homex.g
                                        ; called to home the X axis
                                        G91
                                        G1 H1 X-230 F3600
                                        G1 X15
                                        G1 H1 X-10 F360
                                        G90
                                        G1 X110 F3600 ; this just moves X to the centerline of the bed - doesn't matter where - it can be any place at all that suits you.
                                          @mac
                                          ; homey.g
                                          ; called to home the Y axis
                                          G91
                                          G1 H1 Y-230 F3600
                                          G1 Y15
                                          G1 H1 Y-10 F360
                                          G90
                                          G1 Y110 F3600 ; this just moves Y to the centerline of the bed - doesn't matter where - it can be any place at all that suits you.
                                            This post is deleted!
