I could use some help
@fcwilt Y homes like it should. None of the + moves work. When I -10 it moves FORWARDS.
@mac
; Configuration file for Duet 3 Mini 5+ (firmware version 3.3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.3.10 on Mon Jun 27 2022 12:50:38 GMT-0700 (Pacific Daylight Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Frankenstein's Cinderella" ; set printer name ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0.0 S1 ; physical drive 0.0 goes forwards M569 P0.1 S1 ; physical drive 0.1 goes forwards M569 P0.2 S1 ; physical drive 0.2 goes forwards M569 P0.3 S1 ; physical drive 0.3 goes forwards M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z4000.00 E420.00 ; set steps per mm M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z600.00 E1200.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z200.00 E250.00 ; set accelerations (mm/s^2) M906 X600 Y600 Z600 E600 ; set motor currents (mA) M84 S0 ; Disable motor idle current reduction ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X220 Y220 Z240 S0 ; set axis maxima ; Endstops M574 X2 S1 P"!^io5.in" ; configure switch-type (e.g. microswitch) endstop for high end on X via pin !^io5.in M574 Y2 S1 P"!^io6.in" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin !^io6.in ; Z-Probe M950 S0 C"io3.out" ; create servo pin 0 for BLTouch M558 P9 C"io3.in" H5 F120 T3600 ; set Z probe type to bltouch and the dive height + speeds G31 P500 X15.875 Y0.625 Z2.5 ; set Z probe trigger value, offset and trigger height M557 X5:190 Y5:215 S10 ; define mesh grid ; Heaters M308 S0 P"temp0" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"out0" T0 ; create bed heater output on out0 and map it to sensor 0 M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S33 ; set temperature limit for heater 0 to 33C M308 S1 P"temp1" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin temp1 M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S100 ; set temperature limit for heater 1 to 100C ; Fans M950 F0 C"out3" Q500 ; create fan 0 on pin out3 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"out4" Q500 ; create fan 1 on pin out4 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 S"optional" D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined ; Miscellaneous M501 ; load saved parameters from non-volatile memory M911 S21 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
@mac said in I could use some help:
I understand about the jogging move.
And since it is wrong you need to change normal to reverse or vice-versa in the M569 for the Y stepper.
That should get jogging going in the right direction.
IF it does try homing Y
@mac
; homex.g ; called to home the X axis ; ; generated by RepRapFirmware Configuration Tool v3.3.10 on Mon Jun 27 2022 12:50:38 GMT-0700 (Pacific Daylight Time) G91 G1 H1 X-230 F3600 G1 X15 G1 H1 X-10 F360 G90 G1 X110 F3600 ; this just moves X to the centerline of the bed - doesn't matter where - it can be any place at all that suits you.
@mac
; homey.g ; called to home the Y axis ; ; generated by RepRapFirmware Configuration Tool v3.3.10 on Mon Jun 27 2022 12:50:38 GMT-0700 (Pacific Daylight Time) G91 G1 H1 Y-230 F3600 G1 Y15 G1 H1 Y-10 F360 G90 G1 Y110 F3600 ; this just moves Y to the centerline of the bed - doesn't matter where - it can be any place at all that suits you.
This post is deleted! -
@mac
; homeall.g ; called to home all axes ; ; generated by RepRapFirmware Configuration Tool v3.3.10 on Mon Jun 27 2022 12:50:38 GMT-0700 (Pacific Daylight Time) M98 P"homeZ.g" M98 P"homeX.g" M98 P"homeY.g" ; Uncomment the following lines to lift Z after probing ;G91 ; relative positioning ;G1 Z5 F60 ; lift Z relative to current position ;G90 ; absolute positioning
@mac That's where the code for my Duet3D Mini 5+ is today. Thank you to @droftarts , @fcwilt , and @alankilian for all their valuable contributions to this effort.
@mac
6/27/2022, 2:06:04 PM G28 Z Error: Failed to enable endstops 6/27/2022, 2:05:32 PM Warning: Driver 0.0 warning: phase B may be disconnected 6/27/2022, 2:05:32 PM G28 X Warning: Driver 0.0 warning: phase B may be disconnected
@mac
Well the warning about driver 0.0 would explain the noise and lack of proper movement.
@mac
; homez.g ; called to home the Z axis ; ; generated by RepRapFirmware Configuration Tool v3.3.10 on Mon Jun 27 2022 12:50:38 GMT-0700 (Pacific Daylight Time) G91 ; relative positioning G1 H2 Z5 F3600 ; lift Z relative to current position G1 H1 Z-245 F1800 ; move Z down until the endstop is triggered G92 Z0 ; set Z position to axis minimum (you may want to adjust this) ; Uncomment the following lines to lift Z after probing ;G91 ; relative positioning ;G1 Z5 F60 ; lift Z relative to current position ;G90 ; absolute positioning
I don't get it, mac.
I give you code to try and you end up with something rather different.
I really do know what I am doing.
@fcwilt I don't know how that happened, honestly. I absolutely don't remember seeing that in your code, or copying anything that looks like into my code.
Frankenstein's Cinderella, that's all I can suggest.
This extraordinarily long thread has the code you suggested in it. It was the first code you provided to me. I know where it is. So I will go and get it, and put it in the homez.g again.
Now we will see what happens.
@fcwilt @droftarts @alankilian
G91 ; relative movements G1 H1 Z-250 F3600 ; fast move toward Z endstop G1 Z10 ; backup off a bit G1 H1 Z-15 F360 ; slow move toward Z endstop G90 ; absolute movements G1 Z10 F3600 ; move to 10mm off the bed to allow X and Y movements
This is the correct homez.g @fcwilt provided. I have no idea where that other code came from.
You been drinking?
Anyway, have you changed the rotation of the Y stepper so the jogging operations move it in the right direction?
I'm still anxious to verify that the S setting is the problem there.
@fcwilt I'm going to work on that now.
Mac
@droftarts @fcwilt @alankilian
In the config.g now:
Our change:
M569 P0.0 S1 ; physical drive 0.0 goes forwards M569 P0.1 S0 ; physical drive 0.1 goes backwards M569 P0.2 S1 ; physical drive 0.2 goes forwards M569 P0.3 S1 ; physical drive 0.3 goes forwards
@alankilian @droftarts @fcwilt
On the X-axis, the printhead's chattering up a storm. When I 119 it, this is what I get:
6/27/2022, 4:18:07 PM M119 Endstops - X: not stopped, Y: not stopped, Z: no endstop, Z probe: not stopped
@Mac
I guess the X-motors toast.
6/27/2022, 4:13:45 PM G28 X Warning: Driver 0.0 warning: phase B may be disconnected
@mac
It's more likely just a bad connection.
Did you get a chance to change the rotation of the Y axis and then test jogging?
; Endstops M574 X2 S1 P"!^io5.in" ; configure switch-type (e.g. microswitch) endstop for high end on X via pin !^io5.in M574 Y2 S1 P"!^io6.in" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin !^io6.in M574 Z2 S1 P"!^io2.in" ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin !^io2.in
I pulled the connector off of Driver_0, and put a short length of wire in the first two holes, then the second two holes. When I turned the X-motor, both phases resisted my efforts. So the phases are both there, but I guess that doesn't mean much?
Above is a change I made. The listing for the Z-endstop disappeared, I guess (I don't know). So I re-entered it, saved the config, and there it is now.
6/27/2022, 4:50:03 PM M119 Endstops - X: not stopped, Y: not stopped, Z: not stopped, Z probe: not stopped 6/27/2022, 4:50:01 PM M119 Endstops - X: not stopped, Y: not stopped, Z: not stopped, Z probe: not stopped 6/27/2022, 4:49:54 PM M119 Endstops - X: not stopped, Y: not stopped, Z: not stopped, Z probe: not stopped 6/27/2022, 4:44:54 PM Connection established 6/27/2022, 4:44:48 PM Connection interrupted, attempting to reconnect... HTTP request timed out 6/27/2022, 4:44:36 PM Upload of config.g successful after 0s 6/27/2022, 4:40:53 PM M119 Endstops - X: not stopped, Y: not stopped, Z: no endstop, Z probe: not stopped
You can see by the entries in the Console that the Z-endstop is now present (again). On the lowest line you can see that there was "no endstop" previously.
Mac
