    Duet 3 mini 5+ screeching noise when moving stepper motors
    25
    1.4k
    • Ray.Rundefined
      Ray.R
      config.g
      Hi, im new to 3d printing and even newer to using RepRap firmware. I googled solutions for the problem that I was having and the only thing I found close to my issues was a forum topic called "controlling a cetus 3d with a duet3d 0.8.5". I tried applying their configuration files to my current system but for whatever reason, the board still sounds like tea pot kettle when I move any of the stepper motors. When i first turn on the machine in idle, the machine is quite but, as soon as i move any of the stepper motors, the machine begins to make a high pitch screeching and continues to do so until I turn off the machine. It sounds like the screeching is coming from the board itself but,I could he mistaken and the it could be the stepper motors making the noise. I am currently using my Cetus Mk3 with the duet mini. The board is being directly powered by a 350w 24v psu. Is there anything that I am missing here or should be looking out for?
      jay_s_ukundefined DIY-O-Sphereundefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @Ray.R
        @ray-r what stepper motors are you using? make/model please
        and can you post your config.g
        Ray.Rundefined 1 Reply Last reply Reply Quote 0
        • DIY-O-Sphereundefined
          DIY-O-Sphere @Ray.R
          @ray-r
          M350 X256 Y256 Z256 E16 I1                               ; configure microstepping with interpolation
          M92 X1280.00 Y1280.00 Z1280.00 E690.00                   ; set steps per mm
          Microstepping is uncommon high....
          (UTC+1)
            Stick to x16 microstepping with interpolation enabled. Experiment later if you want.
            What is your firmware version? Can you please send M122 and copy paste the results here?
            • mikeabuilderundefined
              mikeabuilder
              I'm working on that kind of sound on a machine myself and I'm sure it's because the motor is "skipping steps" = not moving when commanded to move. In my case, I believe I've got a bad motor (because I think I've eliminated all other options).
              Also agree with @Phaedrux that 256 interpolation is way too much. As interpolation step quantity increases, the holding torque for each microstep decreases and you might be in a place where you just don't have the power to turn the motors. Also be sure to adjust your your steps per mm when you change your M350 number.
              fcwiltundefined Ray.Rundefined 2 Replies Last reply Reply Quote 0
              • fcwiltundefined
                fcwilt @mikeabuilder
                @mikeabuilder said in Duet 3 mini 5+ screeching noise when moving stepper motors:
                If the M92 is setup for 16x micro-stepping and the M350 occurs after it in the config.g file there is no need to change M92 regardless of what values you try in M350.
                The firmware does the necessary calculations and adjusts M92 "internally", so to speak.
                • Ray.Rundefined
                  Ray.R @jay_s_uk
                  @jay_s_uk Im using moons motors type:17HT4003-02N(I believe the stepper motors are made special for the Cetus because I already looked for the model number online). I have the version 1.01 of duet mini 5+ Wifi. The config file is in the top line. Im not sure how to show the whole config on the page.
                  • Ray.Rundefined
                    Ray.R @Phaedrux
                    @phaedrux The only reason I put such a high microstepping is because as I mentioned above, I found a post on this forum with the config files for the cetus and I copy and pasted most of the config. I originally started at 32 but it still gave the loud noise. I will try lowering ever further. Here is the results of the M122 command.
                    M122
                    RepRapFirmware for Duet 3 Mini 5+ version 3.4.1 (2022-06-01 21:06:56) running on Duet 3 Mini5plus WiFi (standalone mode)
                    Board ID: 4J3NN-Q396U-D65J0-40KMS-3413Z-760H1
                    Used output buffers: 3 of 40 (13 max)
                    Static ram: 103684
                    Dynamic ram: 109888 of which 12 recycled
                    Never used RAM 28128, free system stack 206 words
                    Tasks: NETWORK(ready,10.7%,267) HEAT(notifyWait,0.0%,358) Move(notifyWait,0.0%,363) CanReceiv(notifyWait,0.0%,942) CanSender(notifyWait,0.0%,372) CanClock(delaying,0.0%,339) TMC(notifyWait,0.7%,114) MAIN(running,85.7%,412) IDLE(ready,2.0%,29) AIN(delaying,0.9%,274), total 100.0%
                    Owned mutexes: WiFi(NETWORK)
                    Last reset 00:00:11 ago, cause: software
                    Last software reset at 2022-06-28 17:45, reason: User, GCodes spinning, available RAM 28128, slot 0
                    Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
                    Error status: 0x00
                    MCU revision 3, ADC conversions started 11579, completed 11579, timed out 0, errs 0
                    Step timer max interval 752
                    MCU temperature: min 31.7, current 32.6, max 32.6
                    Supply voltage: min 24.1, current 24.2, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                    Events: 0 queued, 0 completed
                    Driver 0: standstill, SG min 0, read errors 0, write errors 1, ifcnt 19, reads 567, writes 9, timeouts 0, DMA errors 0, CC errors 0
                    Driver 1: standstill, SG min 0, read errors 0, write errors 1, ifcnt 19, reads 567, writes 9, timeouts 0, DMA errors 0, CC errors 0
                    Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 19, reads 567, writes 9, timeouts 0, DMA errors 0, CC errors 0
                    Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 19, reads 566, writes 9, timeouts 0, DMA errors 0, CC errors 0
                    Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 19, reads 567, writes 9, timeouts 0, DMA errors 0, CC errors 0
                    Driver 5: not present
                    Driver 6: not present
                    Date/time: 2022-06-28 17:45:24
                    Cache data hit count 22382075
                    Slowest loop: 11.27ms; fastest: 0.13ms
                    === Storage ===
                    Free file entries: 10
                    SD card longest read time 3.3ms, write time 0.0ms, max retries 0
                    DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
                    === MainDDARing ===
                    === AuxDDARing ===
                    Bed heaters -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
                    Segments left: 0
                    Movement lock held by null
                    HTTP is idle in state(s) 0
                    Telnet is idle in state(s) 0
                    File is idle in state(s) 0
                    USB is idle in state(s) 0
                    Aux is idle in state(s) 0
                    Trigger is idle in state(s) 0
                    Queue is idle in state(s) 0
                    LCD is idle in state(s) 0
                    SBC is idle in state(s) 0
                    Daemon is idle in state(s) 0
                    Aux2 is idle in state(s) 0
                    Code queue is empty
                    === CAN ===
                    Messages queued 99, received 0, lost 0, boc 0
                    Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 18 (min 18), ts 56/0/0
                    Tx timeouts 0,0,55,0,0,42 last cancelled message type 30 dest 127
                    === Network ===
                    Slowest loop: 17.05ms; fastest: 0.00ms
                    HTTP sessions: 1 of 8
                    • WiFi -
                      Network state is active
                      WiFi firmware version 1.26
                      WiFi MAC address d8:bf:c0:15:09:ca
                      WiFi Vcc 3.35, reset reason Power up
                      WiFi flash size 2097152, free heap 25224
                      WiFi IP address 192.168.1.162
                      WiFi signal strength -55dBm, mode 802.11n, reconnections 0, sleep mode modem
                      Clock register 00002002
                    • Ray.Rundefined
                      Ray.R @mikeabuilder
                      @mikeabuilder Just lowered the interpolation to 16 and I would move the motors at all or at least it struggled to move them. I originally had it set to 32 and it worked moving the motors but the mainboard is making a loud noise, or at least it sounds like its the mainboard.
                        Please post your full config.g as well. If you're using an ancient config you found online it's unlikely to be updated for 3.4.1.
                        • Ray.Rundefined
                          Ray.R @Phaedrux
                          @phaedrux That makes sense. 20220628_180132.mp4 here is a quick video of the noise generated by the board (only when the stepper motors are active). My current configuration
                          ; Configuration file for Duet 3 Mini 5+ (firmware version 3.3)
                          ; generated by RepRapFirmware Configuration Tool v3.3.10 on Sun Jun 26 2022 16:52:21 GMT-0700 (Pacific Daylight Time)
                          M550 P"CETUS MK3" ; set printer name
                          M551 P"" ; set password
                          M552 S1 ; enable network
                          M586 P0 S1 ; enable HTTP
                          M586 P1 S0 ; disable FTP
                          M586 P2 S0 ; disable Telnet
                          M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
                          M350 X32 Y32 Z32 E32 I1 ; configure microstepping with interpolation
                          M92 X180.00 Y180.00 Z180.00 E690.00 ; set steps per mm
                          M566 X900.00 Y900.00 Z600.00 E600.00 ; set maximum instantaneous speed changes (mm/min)
                          M203 X12000.00 Y12000.00 Z12000.00 E7200.00 ; set maximum speeds (mm/min)
                          M201 X150.00 Y150.00 Z150.00 E800.00 ; set accelerations (mm/s^2)
                          M906 X400 Y400 Z450 E1200 I10 ; set motor currents (mA) and motor idle factor in per cent
                          M84 S30 ; Set idle timeout
                          M208 X180 Y180 Z175 S0 ; set axis maxima
                          M574 X2 S1 P"io5.in" ; configure switch-type (e.g. microswitch) endstop for high end on X via pin io5.in
                          M574 Y2 S1 P"io6.in" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin io6.in
                          M574 Z2 S1 P"io2.in" ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin io2.in
                          M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
                          M557 X15:165 Y15:165 S50 ; define mesh grid
                          M140 H-1 ; disable heated bed (overrides default heater mapping)
                          M308 S0 P"temp0" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 0 as thermistor on pin temp0
                          M950 H0 C"out1" T0 ; create nozzle heater output on out1 and map it to sensor 0
                          M307 H0 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
                          M143 H0 S300 ; set temperature limit for heater 0 to 300C
                          M950 F0 C"out3" Q500 ; create fan 0 on pin out3 and set its frequency
                          M950 F1 C"out4" Q500 ; create fan 1 on pin out4 and set its frequency
                          M106 P1 S0 H1:0 T45 ; set fan 1 value. Thermostatic control is turned on
                          M563 P0 D0 F0 ; define tool 0
                            Does the sound stop when you de-energize the motors with M84?
                            They are starting up in Spreadcycle mode, you can try switching them over to stealthchop mode. That will likely drop the idle noise, but you'll have to configure the speed to switch over to spread cycle again.
                            I think it's likely just the way those motors are going to work with these drivers.
                            https://docs.duet3d.com/en/User_manual/Connecting_hardware/Motors_tuning
                            Take a look there, specifically the M569 portion where you'd set spreadcycle and stealthchop.
                            • Ray.Rundefined
                              Ray.R @Phaedrux
                              @phaedrux yes it does. I will try to implement that into my printer thank you very much for the help. Just out of curiosity, why does the noise happen from this board? I've ran the machine with its original mainboard, as well as a Mellow Fly E3, and they both sounded alot better in this situation. Is it the stepper motors or something?
                                They may be using stealthchop by default.
                                • Ray.Rundefined
                                  Ray.R @Phaedrux
                                  @phaedrux I enabled stealth chop and its still making the noise, albeit more quite but, it is still significantly louder than expected.
                                  deckingmanundefined 2 Replies Last reply Reply Quote 0
                                    deckingman @Ray.R
                                    @ray-r Why are the motor currents for XY and Z only one third of the current for the extruder? We could really do with knowing the specification of the motors.
                                      deckingman @Ray.R
                                      @ray-r Also, having only 10% holding current on 400 mA means it'll be 40mA which will do next to nothing in terms of holding position. Set it to 50% and see if that makes any difference to the sound you hear.
                                      • Ray.Rundefined
                                        Ray.R @deckingman
                                        @deckingman I would to provide information on the stepper motors but, unfortunately there is no information on these stepper motors. I already looked online for the model number/manufacturer but there is no info. Ill add a picture of the stepper motor for reference. 20220629_050123.jpg
                                        • Ray.Rundefined
                                          Ray.R @Phaedrux
                                          @phaedrux So what are my options here? Do i need to replace the stepper motors or is this going to happen with any system that I plug into the Duet 3?
                                            deckingman @Ray.R
                                            @ray-r Are the model numbers the same on the axes motors as the extruder? If they are, then it would reasonably safe to assume that you could make the motor current the same for all of them - i.e. increase it to 1200mA. I'm not saying it will cure your problem, but it might.
