    I could use some help
    682
    65.1k
      A Former User @A Former User
      @deckingman @droftarts @fcwilt
      Here’s something completely different:
      That antenna’s from one of my spare quadcopters that isn’t legal to fly anymore. I put it on the Duet Mini 5+ to see if it would work, and / or improve reception. In my opinion it improved reception a lot!
      Mac
        droftarts administrators @A Former User
        @mac sorry this change hasn’t gone to plan. Did you check the phases on the new motors? Can you take a picture of one of the new motors, of the wiring coming out, and the wiring of the Duet?
        Your config looks sensible. You rewired the endstops to NC?
          A Former User @droftarts
          @droftarts Hey, Ian, good to hear from you. I'll take some pictures and answer your questions in the next post.
          Mac
            @droftarts okay, here’s what I know at the moment. Since the y-axis was shuddering, I decided to test it. Here’s a picture of my first test.
            The wiring is black, green, blue, red. From the top of the board, which is where the wifi is, down. So that should be A+ (Black), A- (Green), B+ (Blue), B- (Red).
            When I short black and green, the bed is very hard to move.
            Here’s the thing that makes no sense! When I short blue and red, the bed is EASY to push back and forth.
            According to the information that came with these motors, blue and red are B+ and B-!
            I did not check the phases initially because I thought I had concrete written /printed info from the company I bought these motors from.
            Here’s a picture of the wiring. REM: the board is upside down.
            Mac
            fcwiltundefined droftartsundefined 2 Replies Last reply Reply Quote 0
            • fcwiltundefined
              fcwilt @A Former User
              @mac
              Hi Mark,
              A few things I want to ask:
              1st question:
              When you made that video, when facing the printer, the X endstop was at the left end of the X axis and the Y endstop was at the back of the printer.
              Has that changed?
              If it has not changed those endstops are at the min end of X and Y but the M119 is reporting the max end for X and Y.
              2nd question:
              Do the steppers have a connector as opposed to the wires being a permanent part of the stepper?
              3rd question:
              If the steppers do have a connector did you check the continuity of the cable with the duet connectors attached?
              A Former User? 3 Replies Last reply Reply Quote 0
                @mac do you ever get any “phase disconnected” errors in DWC? Because it really sounds like the blue or red wire are not making the connection. That would explain the axis just shuddering, and no resistance when you short it.
                  @droftarts @fcwilt the problem’s in the connectors I made. Out of three connectors tested, X, Y, and Z, Y shuddered, X and Z did nothing. That’s ten connectors out of twelve that are shite.
                  I’ve been working for 13 hours. Time to take a break.
                  Mac
                    A Former User @fcwilt
                    @fcwilt the motors are fine, the cables that came with them are fine. I checked. It’s the connectors I installed. 10 out of 12 are shite.
                    Mac
                    • fcwiltundefined
                      @mac said in I could use some help:
                      Mac
                      Hi Mac
                      Whenever you return to work perhaps you could find a way to make a video showing us how you are crimping those contacts onto the wire.
                      I've done hundreds of such crimps and I might mess up 1 out of 100.
                      Perhaps we can spot the problem you are having.
                      A Former User? 2 Replies Last reply Reply Quote 0
                        @fcwilt No, yes, no (sad face).
                        But we're over it, and we're at it again. I haven't eating in eight hours, so I'm going to have a cheese sandwich and then I'm turning in.
                        Maybe tomorrow we'll share some pictures of the Rat's Next that Frankenstein's Cinderella lives in.
                        Mac
                          @fcwilt If I had a camera I could hold in my mouth, I might do that.
                          I'll think about it.
                            Just so you know, X is working correctly, Y is going backwards, and Z is going backwards (with a pronounced jerk).
                            All things I can take care of.
                            This is the first good news I've had since I bought this board.
                            Mac
                              Here’s video of the first legit moves of my Duet3D Mini 5+
                              link text
                              Mac
                                @mac that’s great, nice and quiet too! Z problem looks like steps per mm, which I think you have set to 4000, so it is moving way more than 5mm, and so fast that it is skipping steps. Try 800, or possibly 400, which is more common for Z on these kinds of machines.
                                  @droftarts will do, thanks,Ian.
                                    @fcwilt I’ve never changed where any of the endstops are mounted. If I understand, in RRF, the X and Y endstops should be classified as “LOW”, not HIGH?”, correct?
                                    And if I change those High to Low classifications, M119 will report that when the are depressed, they will be at Min, not Max?
                                    RRF should change their Low and High to Min and Max, or, change their Min and Max to Low and High. The way RRF is now is creating confusion with how DWC reports the functions of endstops (min and max).
                                    Mac
                                      @fcwilt that is a very good idea, and I am going to make that video today. Thanks, Frederick!
                                      Mac
                                      • fcwiltundefined
                                        Yes
                                        Hopefully
                                        It couldn't hurt to be consistent.
                                          @fcwilt EXACTLY!
                                            @droftarts @fcwilt
                                            I tried to make a video, but it just didn't work out. There are enough crimping videos on youtube already also.
                                            We changed the steps from 4000 (which is the typical response according to Duet3D), to 400 (on Ian's advice).
                                            I tidied up the wiring with zip ties, and now we're back at it, testing this and that.
                                            Mac
