    SBC USB printing
    900
    • chrishammundefined
      chrishamm administrators @peterwilli
      @peterwilli That error code means that DWS cannot get the file list from the requested path (even though it should have returned an HTTP error instead; I'll fix that). You could start a shell with the dsf user by running sudo -u dsf bash and then check if you can enter the mount point of the USB drive and list the files there. I suspect it's a permission problem.
      Duet software engineer
      peterwilliundefined 1 Reply Last reply Reply Quote 0
      • peterwilliundefined
        peterwilli @chrishamm
        @chrishamm Hi there
        dsf@raspberrypi:/home/pi$ cd /media/sd
        bash: cd: /media/sd: Permission denied
        It indeed seems to break when trying to access the folder. I'm currently in the process of finding out what happened and how to fix this error.
          peterwilli
          Excuse me to revive this thread, but took a long break after really not being able to fix this in a reasonable amount of time without getting too crazy.
          We finally solved it. The solution was:
          • The desktop was automounting the SD card. I finally unmounted using umount /media/pi/D2F1-AD5F
          • Then, I remounted using sudo mount -o rw,umask=0000 -t vfat /dev/sda1 /media/sd.
          • I also added dsf to the users group, but that may not be necessary.
          The only thing that's left to do is making sure it still auto-mounts, but with the right permissions and configuration.
          • chrishammundefined chrishamm referenced this topic
          • Tinchusundefined
            Tinchus
            I have similar / same error but cant see a solution: I want to upload a gcode I have on my usb stick. I plug the USB into the raspi, and I cant see it on the DWC interface.
            Im not skill on linux so, can anyobody lauch a hint on how to solve this?
            My intention is only load gcode from the USB drive, not printing from it
            • Tinchusundefined
              Tinchus
              I can see my USB being mounted on /media/pi/ but the interface DWC cant show me / find it..
                Phaedrux Moderator @Tinchus
                @tinchus said in SBC USB printing:
                Then why open it from DWC? Can you copy it on the Pi side?
                Tinchusundefined 2 Replies Last reply Reply Quote 0
                • Tinchusundefined
                  Tinchus @Phaedrux
                  @phaedrux I have the interface, I plug in the usb drive, then I go to files > upload Gcode, shouldnt I see the usb drive in order to look for the gcode and uploaded to the PI? That is what I cant do,
                  • Tinchusundefined
                    Tinchus @Phaedrux
                    @phaedrux It is a permissions problem because USB is mounted and I can see it on /media.
                    Permissions on /media are:
                    pi@PM8721-3:~ $ ls -all /media/
                    total 44
                    drwxr-xr-x 11 root root 4096 Jun 28 17:04 .
                    drwxr-xr-x 18 root root 4096 Jul 12 2021 ..
                    drwxr-x---+ 3 root root 4096 Jun 28 19:01 pi
                    lrwxrwxrwx 1 root root 4 Jun 28 17:04 usb -> usb0
                    drwxr-xr-x 2 root root 4096 Jun 28 17:04 usb0
                    drwxr-xr-x 2 root root 4096 Jun 28 17:04 usb1
                    drwxr-xr-x 2 root root 4096 Jun 28 17:04 usb2
                    drwxr-xr-x 2 root root 4096 Jun 28 17:04 usb3
                    drwxr-xr-x 2 root root 4096 Jun 28 17:04 usb4
                    drwxr-xr-x 2 root root 4096 Jun 28 17:04 usb5
                    drwxr-xr-x 2 root root 4096 Jun 28 17:04 usb6
                    drwxr-xr-x 2 root root 4096 Jun 28 17:04 usb7
                    The USB is mounted under /media/pi/
                    I change permisions on /media/pi folder to:
                    drwxrwxr-x+ 2 root root 4096 Jun 28 19:06 pi
                    Now I can see the contents of any USB I PLUG, but the interface cant do anything with it, because if I try to aluch a print from it, it says it has no roght.
                    How can I fix this foreever in order everytime the USB is mounted, the user and group of the USB folder is NOT root?
                      I'm only a rudimentary linux user as well. Will have to see what @chrishamm has to say.
                      Tinchusundefined 1 Reply Last reply Reply Quote 0
                      • Tinchusundefined
                        Tinchus @Phaedrux
                        @phaedrux is there any othrr way? It was working on 3.3, may be if we replicate permissions fron that version?
